Question about HP OfficeJet K80 All-In-One InkJet Printer
My scanner will not scan a picture. There is no
My scanner will not scan a picture. There is no cable pluged into the back of the scanner; I don't know for sure if this could be the problem.
Am I able to scan a picture into my computer. I have windows 7, the model is a mfc-5440cnz and do you need ink to do this? thank you for help
The best way to scan images to save on yourcomputer is to use the scanner software on the computer. Not the scan functionon the scanner.
You don't say what type of scanner software you have but usually scannersoftware works this way:
1) Place photo on scanner
2) Open scanner software
3) Using the software, Initiate scan
4) Name the Scanned item and save it to your desired location/folder
Note: some applications will automatically save to --My Documents--My Pictures
5) Repeat process for each pic to be scanned
Also, if you are just scanning, it should not matter what the ink situation is.
May 01, 2011 | Brother MFC 240C All-In-One InkJet Printer
When I try to scan it says no application associated with this event. I've reloaded the scan program and rebooted the computer but no luck.
I have a CanoScan9900F and I never had any problem before. I have a MacBookPro with MacOSX and I use CanoScanToolbox when I want to scan.Never had any problems but all in a sudden I get message:
"Cannot communicate with scanner. Cable may be disconnected. Check Status. Scanner driver will be closed."
I tried a different USB-cable, but no result. My worries are that the scanner is broken. As I recall it, the scanner used to make a short "scan" sound when the electric cord is pluged in. What do you think or suggest? Please help me out?
Best Regards Tess
Nov 07, 2010 | Canon CanoScan 4200F Flatbed Scanner
On a Fujitsu fi-6230 I keep getting an error occured communicating with scanning device. please ensure that the scanning device is connected properly and try again.. i have to keep uninstalling and...
This a USB scanner and it supports the following OS's: Microsoft® Windows® 2000 Professional / Microsoft® XP (32 bit/64 bit) / Microsoft® Windows Server™ 2003 (32 bit/64 bit) / Microsoft® Windows Vista™ (32 bit/64 bit). IF, the usb cable is connected in the front usb connectors go ahead and plug it in the back usb ports since sometimes the front usb ports are either to slow or not connected. Additional, after pluging the the scanner on the back usb ports restart your computer and then proceed reinstalling the drivers for it.
Mar 25, 2010 | Lenovo 3000 J Series 1.80G VBE PC Desktop
Problem is apparently HP solutions center. I have a 6940 printer and 4850 scanner. I finally got the printer to work, but it reinstalls the printer drivers at every startup. When I try to scan, the link...
Try uninstalling the drivers for the scanner and the printer. Restart the computer without either the scanner or printer pluged in. After restart install the drivers and only plug up the USB cable for each device when asked by the software.
Jan 21, 2010 | HP OfficeJet 7410 All-In-One InkJet...
Plugged in barcode scanner. it blinks continously. won't scan
You might try turning the register off, confirming the scanner is pluged in and the screws tight then turning the register back on. You might also chek that none of the pins on the scanner plug have been bend.
May 24, 2009 | Sharp Office Equipment & Supplies
Scanning error - cannot scan error code 2,155,0 ???
i found this while i had the same error msg... apparently its actully the USB cable where its does not suffice
here is the link : http://www.fixyourownprinter.com/forums/printer/49111
Thanks
Sanjieev
Jan 13, 2009 | Office Equipment & Supplies
When I scan back screen comes up blue and words and numbers are
http://fixunix.com/hewlett-packard/101142-scanjet-5400c-dead.html
following this link i've found resetting instructions for this scanner:
1.. Disconnect the USB cable and the power cable from the
scanner. Make sure the power cable is still connected to the
power source.
2.. Press the Scan and Email buttons at the same time, while
plugging the power cable back into the scanner. The scanner will
enter a Demo Mode.
3.. Press the Cancel button on the scanner to start the test.
4.. To end the test, disconnect and reconnect the power cable
without holding the buttons down.
I've had exactly the same problem with my scanjet 5400c (blue distorted images) but after resetting the scanner (see instuctions posted above) the problem was fixed
Dec 18, 2008 | HP Scanjet 5400c Flatbed Scanner
Twain Complient
twain data transfetr error help please
Oct 20, 2008 | Canon CanoScan LiDE 70 Flatbed Scanner
Scanner
Plug a scanner into your pc,usually by usb cable. Follow all instructions included with scanner including installing drivers (software) For flatbed scanners you would lay your picture on the scanner glass,close the top and push "scan" either on the scanner or in the software provided with your scanner. The software you will install will allow you to pick the location of where the pictures will be saved to. On the other hand,if the pictures are still in your camera,you can just transfer them to your pc. via a usb cable.
Aug 11, 2008 | Lexmark X2500 All-In-One Printer
HP OfficeJet K80 All-In-One InkJet Printer Logo
104 people viewed this question
Seeker5211
Seeker5211
