Question about GE GSS25JFM Side by Side Refrigerator
I have a side by side that does not hold temperatures. It stays at zero then goes to 10 degresss than back to zero
  • GE Master
  • 3,361 Answers
That is normal operation. The temperature will increase when the compressor is off. When the compressor cycles on,the temperature will decrease.
Posted on Sep 28, 2009
I have a KitchenAid Refrigerator Model Number: KBFC42FTS. Bottom drawer freezer over cools -10 degrees.
Does that unit have a low temperature monitor built in? Maybe that is what is making the noise when your temps dip to -10 degrees. Actually, that is great because the lower the temps the longer you can keep food in the freezer so I would not be overly concerned about that aspect. BTW, have you tried to isolate the source of the humming noise?
Sep 19, 2017 | KitchenAid Refrigerators
Temperature gauge stays at zero until stuck on traffic then goes to 70 then back down to zero when driving again checked coolant and its fine???
The thermostat housing body needs to be replaced which regulates water coolant through engine to radiator.
Feb 19, 2015 | Cars & Trucks
Volume goes to zero
sounds like you need to replace the buttons on the side of the tv. I can get you a part number if you will supply me with the full model code and version of your tv.
Dec 31, 2013 | Samsung LN32A540 32 in. LCD HDTV
I have a Fridgidaire model FFUS2613LSO that beeps 3 times about every 30 minutes or so which has been happening for about 2 weeks.
Hi katelynn_did - When the refrigerator is beeping or buzzing, it may be a warning sign of a possible malfunction or an unsafe, interior temperature. Typically, that is correct, to silence the buzzer, you can depress the ALARM OFF button. However, since you have already tried unplugging the unit and issue persists, it could possibly be experiencing a communication problem with the temperature control/board, faulty internal sealed system or wiring failure. I would recommend connecting with a professional appliance tech for a clear-cut diagnosis.
Apr 17, 2013 | Frigidaire FFUS2613L Side by Side...
Just bought this scope and want to use on my rem 243,will it hold a zero once zeroed in?
The ability of a scope to hold it's adjustment is pretty much pre- determined by the quality of the scope itself...Better scopes hold adjustments better than cheap ones. Same goes for the mounts...a good mount will not loosen up or change point of aim.
If you are using a good quality scope and good mounts, once sighted in, unless you drop the weapon or have it shipped as 'baggage" on a long distance hunt, It should stay reasonably zeroed.
A 243 is not known as a "shoulder buster" so recoil should not affect adjustments.
243's are generally used in long range shooting. Therefore changes in temperature and normal use can change point of impact...so can changing the ammo you use. Therefore I don't recommend not checking accuracy before taking any weapon into the field. Wether you are using a $40 scope or a $1000 one, you owe the animal you are shooting, your very best attempt to take it down with one well placed shot. Checking zero at the anticipated shooting distance is the best way to insure that.
Dec 20, 2010 | Chevrolet 3500 Cars & Trucks
I keep setting my thermostat but it automatically goes back to same temperature no matter what i set it at
If it is a programmable thermostat, it will only stay at a certain temp until it reaches it or on a set time, then it goes back to the scheduled program temperatures. Most programmable thermostats do have a hold feature that allows you to hold the temp to a certain setting, but if you don't set it to permanent hold, then it does what you described. Hopefully this helps some or guides you in the right direction. Good luck!
Mar 12, 2010 | Heating & Cooling
With compressor running, low side pressure starts out about 15 psi then goes to a little below zero. i have added r134 freon until low side reached 10 to 12 psi. pressure stays there for a while then goes...
Wow, it would seem like you have a leak there on the low side. You add and it goes goes back to equal on the low side again. The gauge could be off just a bit. Have you pulled a vacum test on the unit? Sounds like you should pull everything out, vacum and the weigh in the correct charge at this point assuming that you do not have a leak or can find and fix it.
Nov 15, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Sub zero fridge doesnt turn off
If your temperatures are OK, then you have a bad thermostat control.
Feb 22, 2009 | Sub-Zero 650 / O Bottom Freezer...
Temperature goes up
do you hear any fans running?  by the temp staying cold on the drawers whih are in the lower area of the freezer it indiates to me that the fans are inoperable. to test open freezer door then push in light switch by hand and listen for the fans to come on. if it turns out you have bad motor you most likely will have to call a sub zero dealer to have repaired. messge me back with any questions peyton
Jan 28, 2009 | Sub-Zero Freezers
GE GSS25JFM Side by Side Refrigerator Logo
53 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
