Question about Refrigerators
Freezer is working but not getting very cold, cleaned condensor
''where is the model number located for an imperial side by side refrigerators''
  • 82 Answers
If it's like the rest; it's inside the fridge to the right behind one of the drawers.
hth
Posted on Sep 29, 2009
Freezer has warm spots. All around freezer is hot to the touch. Compressor is hot, coils are clean, condensor fan is running.
Thats normal.
The condenser coils are located just inside of your exterior cabinet walls on the sides and top.
So the freezer gets cold inside and heat has to be released from the condenser coils.
If this is something new, you may have a problem with the defrost timer
Sep 11, 2011 | Kenmore Side by Side Refrigerator
The freezer side is not keeping food frozen. Every three minutes I hear something turn on and it runs for about xx seconds. The model number is ASD2626HES. The refrigerator side seems fine.
Check the temperature setting
Assure that there is enough room for air flow in the freezer or freezer
Check for air flow restrictions in vents
Test the temperature control
Clean the condensor coils
Check the door seals
Test the door switch
Test defrost heater
Test defrost timer
Test evaporator fan
Check for a clogged drain tube
Check for refrigerant leak
Freezer is too cold
Freezer is noisy
Hissing and popping is normal, it is the defrost heater.
Check that the freezer is level
Check the drain pan
Check the condensor fan
Check the evaporator fan
Inspect the compressor mounts
Freezer runs continuously
Defrost the freezer
Freezer starts and stops frequently
Check the outlet voltage
Test the condensor fan
Test the compressor relay
Test the overload protector
Test the compressor motor
Freezer does not defrost automatically
Test the defrost timer
Test the defrost heater
Test the defrost thermostat
Freezer has an unpleasant odor
Remove spoiled food
Clean freezer interior with a solution of h
Clean freezer interior with a solution of hot water and baking soda
Clean the door seals
Remove breaker strips and check for wet insulation
Water on floor outside of freezer
Check the drain pan
If you have an ice-maker, check the water supply hose going into and coming out of the water inlet valve
Water inside the freezer
If you have an ice-maker, check freezer and ice-maker for level
Hope this solved the problem, Take care....
Sep 19, 2010 | Amana ASD2626HE Stainless Steel Side by...
Refridgerator side not getting cold model gss201epaww
make sure the damper vent door located between the freezer and refrige compartments is opening and letting in cold air from the freezer,if they ice up they can stick shut and not allow air flow,this door is behind a plastic grille an a hair dryer works great to defrost them
Apr 30, 2010 | Refrigerators
My side by side refrigerators is not getting cold enough in th freezer part
CHECK YOUR CONDENSOR FAN IN THE BACK IT MAY BE BAD OR STUCK, ALSO CLEAN THE CONDENSOR, IF THATS OK CHECK TO SEE IF YOUR FREEZER FAN IS RUNNING, IT MAYBE A DEFROST PROBLEM IF ITS FROSTED UP .
Dec 26, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ge tpx21pr side by side refig/freezer Freezer is not cold enough
If your unit is NOT a static condensor, (the type with cooling fins and tubes on the outside of the back of the unit) If the door seals are okay and sealing properly, you might need to service the forced air condensor components located at the rear lower area, usually behind a fiber board cover. Remove the cover and look for dust on the condensor fins and fan blades. If clogged, carefully brush, vacuum, or blow the dust out, opposite the direction of the fans natural air flow direction. (You don't want to lodge the debris further into the condensor fins.)..Be sure to unplug the unit first.
Jul 31, 2009 | Refrigerators
Subzero 561 Fridge side works, Freezer side working fine
Sounds like a cold control. It is located behind the panel and can be ohmed out to check for proper operation. You need to remove the light shield then after the shelves have been taken out remove the two screws that hold the fan shroud in place. This will allow back panel to come for so you can check the cold control. It should read as a short in all positions except off when the cap tubes have come to ambient temp. If you get the back off and see ice on only a small portion of the evaporator you have a sealed system problem and need a qualified technician.
Nov 24, 2008 | Sub-Zero 685/S Stainless Steel Side by...
Cold fridge but not freezer
try DEFROSTING the fridge and restart it after COMPLETELY defrosting it.
May 05, 2008 | Fisher and Paykel Active Smart E522B...
Refrigerators Logo
55 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
