Question about Casio Watches
I have a Casio Model 2519, A179W, with "10-year Battery", about 3 years old. The watch is "fixated" on "Wednesday Sep. 16, at 19:25:42".It has not moved since then. Is this a battery problem? Since these Casio's are about $15 at the Casio in Hong Kong, is it worth repairing it? Could only be battery? If battery is discharged, how come it shows time and date with good contrast, but it does not "move" or illuminate any longer? Thank you for your advice. Sincerely, Dr. JC DETATA.
5 Suggested Answers
SOURCE: Watch stops
i have no solution but i cant even get mine open, how do i open this? rich@potterandco.com
Posted on Dec 26, 2007
SOURCE: geneve gold wrist watch
if no possible joints can be seen at back it can be open through glass.find an expert on watches.
Posted on Mar 22, 2008
  • 5 Answers
SOURCE: Casio pro-trek PRG-60T Buttons no longer activate anything.
Is the battery indicator on L (Low). If so only timekeeping will work. Check out the manual which tells you that.
Try sticking the watch in a window to charge it till the battery indicator gets to H (may take up to 10 days for a very run down battery). If that doesn't work it send it to Casio for a battery change. Cost of change just over 20GBP sterling.
Posted on Feb 19, 2009
  • 2501 Answers
SOURCE: how to adjust ******** Casio 2519 A179W watch
I presume that you have not got any instructions for the watch.
You can download a copy for your watch if you go to the Casio web site (casio.com), select "support", then "manuals", then "watches" and then after "agreeing" , select "watch manuals archive" and put in the information off the back of your watch.
Posted on Jan 20, 2010
CASIO G-SHOCK 200 (G-7500)
The first thing I have to recommend it to unscrew it and remove the battery for a few minutes and then insert it back.
If this has solved your problem please rate this solution as "Solved" otherwise please ask us here again for more possible solutions.
Thank you :)
Oct 12, 2007 | Casio G-SHOCK 200M DW5600E1V Wrist Watch
Ive got a Casio 2735 wva-105h watch that Ive had since 2004. Its Been 10 years and still havent needed to change the battery yet and still fully functional. Is it Solar or anything like that? How is i
Hi Paul
Yes this has a battery, it sounds like you are one of the lucky ones that hasnt needed to change it yet, there life span is approximatley 10 to 15 years before they need changing, so either yours is in the 15 year catagory or its comming up for a change...hope that helps
Nov 25, 2014 | Casio Watches
GW-1500A Casio has to be sunlight every day otherwise it stops
Hi gregbrands,
If your watch is several years old, I would recommend sending it back to Casio for service and battery replacement. Contrary to what you may hear about solar-powered watches, the rechargeable batteries do not always last for 10-20 years. I've seen some go out in 2-3 years. This is a shorter lifespan than most standard lithium watch batteries.
You may have an authorized Casio service center near you also. If not, contact Casio at the following numbers:
For Repair support in USA at 1-800-706-2534 during regular business hours (currently Monday-Friday 9:00a.m. - 5:00pm EST, Saturday / Sunday 10:00 a.m. - 8:00 p.m.) For Technical support in USA at 1-800-435-7732 during regular business hours (currently Monday-Friday 9:00 a.m. - 8:00pm EST for all products, Saturday / Sunday 10:00 a.m. - 8:00 p.m)
The cost of your watch well justifies this kind of service, plus, they will assure it remains waterproof up to its specifications.
Let me know if I can help further.
Thanks, Bill
Sep 15, 2010 | Casio GW1500A-1AV G-Shock Atomic watch
I need to set my day and date to the correct year on my G-SHOCK G-3110. I'm currrently showing Tuesday 3/02/10. The correct date should read Wednesday 3/03/10.
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all CASIO watch manuals. Rate me, please.
Mar 04, 2010 | Casio G-Shock 800D 7V watch
How to adjust ******** Casio 2519 A179W watch
Jan 20, 2010 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
I have a casio illman...watch wr-50.. its a telememo world time 3 alarms countdown ith a 10 year battery...i need the instruction on how to set the watch
Go to the Casio site "casio.com".
Select "support", then "manuals", then "watches",
Accept terms and conditions,
Then select "watch manual archive"
enter the number off your watch and click on "search"
Jan 18, 2010 | Casio G-Shock GW300CA-1V Wrist Watch
Casio 2688 Wave Ceptor - No Display
On the solar charge watches, they use a chargeable Lithium battery. It is NOT an off the shelf regular battery! It is best to send the watch to the factory service rep in your area for a battery change.
In many of these models the battery is using solder contacts to the circuit board. The person changing the battery will require the original spec battery, and be equiped to do surface type soldering.
When working on this watch, the factory service will change the seals and do a pressure water resistance test. The regular corner watch service store is not equiped to do this type of testing.
Normaly, the battery in solar watches should last more than 5 years. Some are going past 10 years!
Jerry G.
Feb 23, 2008 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
Light
My watch had the same problem and i could never figure out what it was so i just lived with it for a couple of years. then, just recently even when my watch was getting plenty of sun the battery would die in the evening and shut off at night. so i replaced the battery and evrything works great. even the light which leads me to believe the solar panel is just a gimmick. i have an old g-shock watch that i bought in 1989 and it still works and is on the origional battery. my gw 300 is about 5 years old and needed a battery. i guess 5 years on a battery is prety good but i would rather have it last for 19 years like my old one.
Jan 24, 2008 | Casio G-Shock GW300CA-1V Wrist Watch
Watches Logo
295 people viewed this question
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Ansel Alberto
Ansel Alberto
Are you a Casio Watch Expert? Answer questions, earn points and help others
