Question about Akai PT4298HD Rear Projection Television
AKAI PT5492 no power - only timer comes on
My AKAI PT5492 rear projection TV has been working fine since 2001 and yesterday, without warning, it would not turn on. The timer light did go on and will now not go off. In addition, there is a clicking sound every few seconds. I unplugged the unit until I can determine what to do. Thanks- -Fred
yambo
  • 230 Answers
SOURCE: Akai PT5492
I can help you. Call me  910-8936663
Posted on Oct 27, 2007
Jon865
  • 6 Answers
SOURCE: akai pt5492
This could be one of many different issues. Main flaw with these units are as follows:
Blue picture tube leaks coolant onto neck board and mainboard causing problems.
Posted on Mar 11, 2008
scott201201
  • 170 Answers
SOURCE: Akai PT50DL24 50 in DLP Rear Projection TV-NO PIC OR SOUND
check for popped or raised tops on caps in power supply. also try unplugging set for 5 minutes and resetting it. How about does your color wheel spin up? if your color wheel don't startup then your tv will also shut down. also check all fans they all should be running at turn on. if all fails i would say its your light engine.
Posted on Apr 10, 2008
SOURCE: akai pt5492
just had tv repair man here said it was the sweep module @ $500 to repair
Posted on Apr 29, 2008
ahhsoo69
  • 167 Answers
SOURCE: Akai PT5492 54"
HELLO IT SOUNDS LIKE YOU HAVE A BAD FLY TRANSFORMER. . THAT NEEDS TO REPLACED. "GOOD LUCK"
Posted on Jul 27, 2008
I have a 56'' AKAI PT5492 projection screen i turn it on and have green bowed lines on top of screen
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs.
To get fixed either call in a local TV repair company or goto sites such as www.TvRepairKits.com to get a repair kit with instructions.
Oct 15, 2010 | Akai PT5492S 54" Rear Projection...
2002 akai 54in. rear projection tv wont turn on
Unplug,replug the tv back an hour later.The tv should reset itself.More problems repost,see if i can help u.
Feb 20, 2010 | Akai PT5492S 54" Rear Projection...
Akai tv model PT5492 has real bad orange tint that will not go away, with any adjusting.
it souds like your blue and green tube are getting weak and will need to be replaced
unfortunately they are no longer avail I would think about retireing that set
Dec 10, 2009 | Akai PT5492S 54" Rear Projection...
Akai tv
Not if it doesnt have HD on it all HD Ready Sets have it printed on TV.
Dec 27, 2008 | Televison & Video
Akai PT5492 54"
Jul 22, 2008 | Akai PTH5498 54" Rear Projection...
Akai pt4298hd rear proj tv
Unit may be in timer mode. Check menu settings
Apr 22, 2008 | Akai PT4298HD Rear Projection Television
Won't turn on
If you're using a DVD player or other component using the Component cable hookup, try unplugging that from the mix, unplug the power cord for the TV from the wall and wait 15 seconds and plug it back in, then power the TV back on. Mine used to do this and I gave up on the component cable option and went back to composite (RCA).
Feb 09, 2008 | Akai PT5598HD 55" Rear Projection...
No power to the television
Dont know if this will help, try leaving it unplugged over night, thaught I saw that solution in a blog somewhere a while ago.
Dec 23, 2007 | Akai PT5598HD 55" Rear Projection...
Akai pt5492
Dec 17, 2007 | Akai PT5492S 54" Rear Projection...
Akai PT5492
Oct 15, 2007 | Akai PT5492S 54" Rear Projection...
Akai PT4298HD Rear Projection Television Logo
132 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
