Question about Whirlpool Cabrio 7.0 Cu. Ft. Super Capacity Plus 7-Cycle Gas Dryer - White
5 fuse links 2 themistors in 2 years ....
I think we have a problem...... vent is clear and when it blows the link the clothes are so hot my wife can't touch them. The elastic in our clothes has deteriated so bad we have thrown clothes away. I am afraid we have a fire hazard in our home.... any else having this problem or does anyone have the answer?
    President:
  • Whirlpool Master
  • 1,922 Answers
Have you replaced the cycling switch on the unit?
Posted on Sep 29, 2009
Whirlpool dryer wed5700swo. only about 2 years old, not drying as good as it used to. think i blew a thermal fuse because the vent was clogged. there is a thermal fuse with 4 wires in the lower left...
The cycling or operating thermostatis often the problem when a dryer runstoo hot, but there are also other things that can make it run hot also.
Here is a tip that I wrote that gives more details about why a clothes dryer will get too hot.
Clothes Dryergetting too hot
heatman101
Aug 07, 2011 | Whirlpool Dryers
When I turn on the dryer, the top gets VERY hot within about 2 minutes. When I look inside, you can see the heating element is red. I checked the vent and it is clear. I did notice that there was some...
if the lint is damp then the air isn't moving out the vent line,unplug the dryer, go outside and make sure the hood is clear, then go back inside and remove the vent line from the back of the dryer,if the vent line is long i use a leaf blower to blow out the line,just stick it into the vent line and blow it so all the lint will go outside,if you could have someone watch the outside and they can let you know when the line is clear,also the duct that the lint filter slides into should be cleaned out and you should vacuum out where the motor is,you have an open flame inside the dryer and the lint can and will catch fire if it's not cleaned out,i do this to my dryer once a year,the clothes dry on time,no fires and the parts in the dryer last longer from being cleaned and the dryer isn't overheating and damaging the motor and other parts from running to hot.let me know how you make out
Oct 29, 2010 | GE DVLR223 Dryers
41799980100 Kenmore Laundry Center dryer themal fuse blows
you need to clean out the dryer.the thermal fuse is a safety switch so you don't have a fire when the dryer is running to hot.blow out the vent line with a leaf blower,unplug the dryer and make sure the outside vent is clear.next you need to clean out the duct that the lint filter slides into and vac out the inside of dryer where the motor is,do this once a year,your clothes will dry on time,no fires and you'll save on parts.let me know how you make out
Apr 19, 2010 | Kenmore 62802 Electric Dryer
Not drying clothes like it use to. Have to run two or three times to get clothes dry.
you need to clean out the dryer.unplug the dryer.remove the vent line and blow it out with a leaf blower if it's a long run.make sure the outside vent is clear.next clean out the duct that the lint filter slides into and vac out the inside of dryer where the motor is.do this once a year and your clothes will dry on time,no fires and you'll change less parts if the dryer isn't running hot from blocked ducts.let me know how you make out
Apr 03, 2010 | Kenmore 62802 Electric Dryer
I have a kenmore HE2 dryer and matching washer. It is 3 years old. It works and eventually clothes do dry. It does heat up. But it doesn't heat up as hot as it used to and it takes twice as long to dry...
Make sure you check your exhaust line and where the air blows to the outside. If your exhaust vent or hose is bent or restricted it will take a very long time to dry the clothes. Sometimes the vent flap on the outside exhaust is stuck shut. Clear dryer exhaust venting is critical for proper operation. Several companies offer a vent cleaning service where they completely clean out the exhaust lines.
Feb 02, 2010 | Kenmore HE2 Plus Front Load Washer
Whirlpool gas dryer, no heat and no flame
check you thermal fuse with an ohm meter if selected only air and close the door and no air comes from the rear where the vent hooks up clear the vent blower housing then check the thermal fuses on the units exaust assy inside the unit
Aug 19, 2009 | Dryers
Maytag electric dryer model mde308dayw not heeting up
CHECK YOUR WALL VENT AND DRYER VENT AND MAKE SURE THEY ARE CLEAR,ALOT OF THE TIME IF BLOCK THEY HOLD THE DAMP HOT AIR IN THE DRYER AND WILL TAKE FOREVER TO DRY,IF NOT THAT IT CAN ONLY BE YOUR HEATER BOX OR HEATER BOX FUSE,IF YOU HAVE A METER YOU CAN CHECK BOTH,LET ME KNOW-MIKE
Dec 06, 2008 | Dryers
Whirlpool Cabrio 7.0 Cu. Ft. Super Capacity Plus 7-Cycle Gas Dryer - White Logo
96 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
