Question about GE Refrigerators
A hose is leaking on G.E. fridge - to water dispenser, I think
G.E. TPX24SRYA BS built-in refrigerator has a leak in a hose, at the back of the refrigerator. It's accesseb by unscrewing and removing a fiber-type cover at the bottom of the back. On the right side are vent holes for the exhaust; the leaking area is on the left side. There is insulation of some sort on the left side of the fiber cover, over the area where I am having the leak.
I think it is the hose to the water dispenser in the door. The hose appears to be a translucent plastic with a dark braid; I can see about 1/4" between the braid and its connector. The connector is a white, female connector made of white plastic; it screws up and onto a light blue fitting.
When the water dispenser in the door is pressed, a strong stream of water shoots out. It looks like it is coming from the translucent hose, immediately below the white connector, but I guess it could be the connector and the stream is finding its way out this way.
When I first discovered it, the white connector didn't seem tight. I was just able to get my fingers in and turn it, maybe a full revolution. It felt like it could tighten more, but I wasn't sure.
I couldn't find a schematic on the net, and G.E.'s 800 number could only send me two schematics ("Fresh Food Section" and "Unit Parts") that didn't show the hose.
I'm afraid to try disassembling the area; I've got a picture of the hose that my wife posted on a shared drive that I am having troubles opening.
  • Jyackle5
    Jyackle5 May 11, 2010
    Ok you tighten the hose as tight as you can by finger. Now take off the fiber board and take a wrench to the fitting an do another 1/4 to 1 full turn to tighten it the rest of the way. Do not over tighten it and crack it. You just want it snug where you can not back it off easy. If you have another nut below the one you are tightening put another wrench on it to hold in place to support from turning.
    Good Luck
  • GE Master
  • 1,606 Answers
It sounds like someone has repaired this hose , due to the connectors . There should be no connectors except for 1 , below the freezer door . This hose can get hot from the compressor heat , and break .
My suggestion , would be to replace the water resivoir in the refrig section , behind the bottom crispers . This resevoir has a hose that goes completely to the water valve , without any connectors , and a hose that goes to the coupling under the freezer door , for the water dispensor . If you remove the bottom kick plate , the hose from the door , goes about 8 " to the coupling which connects to the line from the resevoir .
Posted on Sep 29, 2009
I have a great model # tpx24srya-bs refrigerator and when the icemaker is on it leaks water from I don't know where. When Ice makers off there's no leak.
There is a solenoid valve and a plastic water hose that connects to the ice maker. Looking at the rear of the unit you can see where the plastic tubing connects from behind the air shield into the solenoid. A second hose connects from the solenoid to the water inlet connection on the wall. The connection to the wall is probably OK because it would leak with the ice maker off if it did,
It is the hose that goes up from the solenoid through a hole at the upper right top that is the most likely culprit.
Look for water coming from a failed hose at or near the solenoid valve connection where the ambient heat is the highest. It is the heat of the hot air that deteriorates the hose. Replace the hose.
After ten years many are known to fail?
"Protect floor before rolling filled refrigerator out from the wall!" The weight will scar the floor from the wheels including hardwood floors!!"
Hope this helps?
Nov 07, 2016 | Refrigerators
Water dispenser beep-beep
I am wondering about the hose you shoved in and the leak stopped. Is the hose you pushed in buckled where it hooks on or is there a buckled spot where the water comes out of the fridge. Just a guess.
Mar 03, 2017 | Hotpoint HSS25GFP Side by Side...
Water dispenser leaks when getting water . This is Frigidare refrigerator , is it the valve on back ?
Hello Marie Baxter: If you suspect the water dispenser is leaking, make sure it is the hoses coming from the filter and not the actual filter.
Sometimes the clamps on the hoses for fridge water filters can come loose or the hose itself could crack; in which case the hose would need replacing (or tightening the clamp), and not the filter.
If you clearly find the filter is leaking, the best thing to do is make sure it is installed properly.
If it is securely in place, then you may just have a defective filter and changing it will solve the leaking.
You will need to remove the filter, which is typically located in the back of the refrigerator and inspect it to see what condition it is in.
•For instance, if it is black or looks dirty, you probably will want to replace it.
•Moreover, when there is a leak or a clog, you will notice a dramatic decrease in the output of the water dispenser tab, which is another sign there may be a leak in the water filter. If you know the water filter in your refrigerator is leaking, then you can take the water filter out and see if it has anything loose on it, but typically if it is leaking, it probably is best to replace the water filters for refrigerators.
•This is especially true if you use the filtered water from the refrigerator as your main home water filter systems.
•Moreover, if it has been awhile since you changed the filter; it can become clogged over time, which can cause it to leak.
When you are faced with having a leaking filter refrigerator water unit, it helps to think through the pros and cons of fixing the leak vs. replacing the refrigerator water filter.
Apr 19, 2013 | Electrolux 25.9 Cu. Ft. Side-by-Side...
GE SIDE BY SIDE FRIDGE HAS WATER LEAKING ON FLOOR FROM FREEZER SIDE
There is hole behind the freezer panel that the water should drain thru . Use a small hose in the hole and blow thru to cleam drain .
Aug 14, 2012 | GE Refrigerators
Water is leaking from under the refrigerator Model # GI7FXCX. What could be the cause
It could be one of three things. The door front water dispenser hose is cracked or broken. The freezer is defrosting and the base catch pan is not in place or you have a spill in the fridge you are not aware of. I will assume it is not the latter, so you need to pull the fridge out from the wall and check the area beneath it from an approx on the leak. Check the hoses for the water dispenser by running your fingers along them and if they are wet, you have found your leak. You need just replace the hose and it will solve your problem. If this is not the case, check the base pan for a hole. It is normal for some condensation to come out of your fridge, not a lot, but some. Check if the pan has a leak in it and you can replace if necessary. I would be real inclined to think the water dispenser is causing the problem.
By the way your model number is GI7FVCXWY
May 23, 2011 | Whirlpool Refrigerators
Kenmore 253.52632200 refrigerator water dispenser leak. The water dispenser in front of the door leak water slowly. Sometime it leak a lot and sometime it does not leak
You need to replace the water dispensing solenoid valve located in the back of the fridge and your problem will be solved.
Dec 12, 2010 | Kenmore Refrigerators
Water leak From Back Of Fridge
hi that small hose is going in to the ice maker. buy a small clamp at the hardware store, and clamp the plastic hose holder. thanks the appliance doc
Oct 16, 2008 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Ge refridgerator model gsl25jfpe bs
I have a gsl25jfpe bs ge regrigerator and the baffle motor that controls air flow from the freezer to the refrigerator is out. This had been causing everthing in the fridge to freeze and cause the water to stop working due to water freezing in the storage tank. The baffle is in the back top of the fridge covered with a plastic cover. Remove plastic cover to check baffle function.
Jul 19, 2008 | Refrigerators
I think I would think about getting a new one. It would cost more to fix it and then you may not get it back together so it wouldn't leak.
Dec 21, 2007 | Refrigerators
Fridge is leaking
Your plastic line which carries water to the dispenser has a crack in it.  Activate the dispenser and have another person pinpoint the lead and splice two pieces together with plastic connector.
Oct 15, 2007 | Amana ACD2232HR Side by Side Refrigerator
Refrigerators Logo
425 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
