Question about Toshiba Satellite A15-S127 Notebook
I have a A15-S127 Toshiba laptop. It was not working. I bought a Windows XP pro OS to install. It did not want to install. I wiped the drive and tried F2 F8 Del. and it will sometimes start to load the program> it reaches a point and stops at an Error. If I keep at it it will get past that one and will continue on until it stops at another. I have gotten as far as it actaully starting to load windows up to 65% then it stopped again. Why would a new program have so many errors? So I am guessing I have a hardware problem. Any Thoughts would be appreciated. Lee
  • 1 more comment
  • Lee Seliga Sep 29, 2009
    Hi and thanks, One of things I did was clean the disc. Its brand new. I do have a spotmau repain program that auto boots and it run fine but cant help without the OS.. Harddrive? Lee
  • Lee Seliga Oct 04, 2009
    Hi Jamil sorry to take so long. I have ordered another Os. I am going to try a linus program because they are cheap. I found by holding esc. while powering up I have access to the control menu, althought that has not helped yet. I have a Spotmau repair disc and it boots up fine so the drive is ok. I am hoping its a bad disc, although the disc was fifty bucks! Lee
  • Jamil Ahsan
    Jamil Ahsan May 11, 2010
    Hi Lee, 1. I believe XP cd you are using has some scratches or it has some bad sectors. Have you tried to use another OS CD? 2. Secondly, it could be a defective CD-ROM itself. I will recommend you to try another Windows XP CD first. Let me know if this helped. Regards, Jamil Ahsan
    Brigadier General:
  • 4,088 Answers
You need to get into 'setup' (watch the screen as it starts) and delete the hard drive, then reinstall it. Be sure to save and exit. When windows starts to install, it will see an un-formatted drive and offer to format it. Select 'NT' file type and let it proceed. Windows will install as on a fresh drive.
Posted on Sep 29, 2009
  • 34 Answers
Hi. Try to download any linux, i.e. Mandriva. Install it on USB stick (4GB), its very easy. Then you can start you computer from it. You can use one of the software included in linux to check hard drive or just simple fill the hard drive to full with some data (movies, music, photos...) and look for any errors or speed decreases. The normal format, not the quick one, can be helpfull as well.
Posted on Oct 13, 2009
How do i load o/s on a15-s127
Try WinXP SP3(bootable disk)
or else enter BIOS, make sure your sata controller is set to ATA, not AHCI. Otherwise the computer wont see the drive when trying to install XP in some cases
Apr 21, 2012 | Toshiba SATELLITE A10 A15 A20 A25 A35 A40...
I have a Toshiba Satellite A15-S127
Support site for that LAptopp is here http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=411405&rpn=PSA10U&modelFilter=A15-S127&selCategory=3&selFamily=1073768663
  • If this solutions solves you problem, please do not forget to rate my solution.
  • If not, then please comment back so I can help some more
Mar 31, 2010 | Toshiba Satellite A15-S127 Notebook
Wont accept new windows system. harddrive has
If the issue is getting the OS into the drive, see if you can access the BIOS and see if the hard drive can be detected. If it is not detected you may have a bad disk.
Sep 27, 2009 | Toshiba Satellite A15-S127 Notebook
Lan driver
try and find the "recovery" CDs, the second CD usually has all the drivers, where u can install the driver from it.
Jun 16, 2009 | Toshiba Satellite A15-S127 Notebook
Toshiba satellite A15 S127 pc notebook -how to set up CMOS: I cannot get into CMOS setup screen at boot up. I tried DEL, F5, F7, F8, etc. The reason I am trying this is as follows; I removed the original...
how to get into CMOS, simplly put F1, OR F2, F10,F12, OR DEL key, but very depend on your laptop itself.
tips, whatever key you need, will show on the boot up screen , like : type Fxxxxx for setup, Fxxxxxxxxx for boot up device order .
for your laptop, may have chance that you laptop too old, some model of ram are not fully compareable.
Jan 14, 2009 | Toshiba Satellite A15-S127 Notebook
Formatting HDD
Sounds like you need to run a scan disk,
at c: prompt type " scandsk /f " or chkdsk /f
This will find and fix bad sectors then you should able to format disk
Jun 04, 2008 | Toshiba Satellite A15-S127 Notebook
Toshiba Satellite A15-S127: Memory does not show up
Is the BIOS up to date? if not you can download latest BIOS update from support.toshiba.com
Mar 12, 2008 | Toshiba Satellite A15-S127 Notebook
Sound Problem
You need to install the driver for Sound device that compatible with XP. Since you have indicated the model Satellite A15-S127, I am attaching the link that you can download sound driver for XP.
Here is the link;
http://www.csd.toshiba.com/cgi-bin/tais/su/su_sc_dtlViewDL.jsp?soid=441097&moid=411405&rpn=PSA10U&BV_SessionID=@@@@1379779449.1203596264@@@@&BV_EngineID=cccfadedgfgdhehcgfkceghdgngdgnn.0&ct=DL&all_docs=false
Please post to inform the outcome.
Good Luck
Feb 21, 2008 | Toshiba Satellite A15-S127 Notebook
Toshiba Satellite A15-S127 DVD driver
thats may be because you don't have a dvd .is just a cd drive
Dec 27, 2007 | Toshiba Satellite A15-S127 Notebook
Toshiba Satellite A15-S127 Notebook Logo
297 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
