Question about Xerox Phaser 4500 (YB) Laser Printer
I re-filled my ink cartridges for the hp 4500 and the machine still tells me low ink or no ink, whats up>? does it not take re-filled cartridges?
How do i find ink levels in Windows 8 for HP Office Jet J4580
It depends on what type of ink cartridge you have installed.....with HP genuine ink cartridges and HP Solution center installed, everything should be there. However, if you get an HP integrated ink cartridge refilled (i.e. HP 60, 61, 74, 75, 901, 92-98....currently offered at Costco or Frys today) or if you buy a remanufactured/compatible HP ink cartridge, the ink levels will not be displayed nor can they be reset (HP has a smart chip embedded within the nozzle plate at base of ink cartridge which counts the drops and then registers as empty).....so you'll just need to live with it and ignore 'ink low', 'non-genuine', 'counterfeit' messages and similar while you are using these types of aftermarket supplies. The first video below provides an overview of the 'low ink' phenomena.
NOTE: These types of 'SEVERE' cartridge errors (i.e. "refer to documentation" / "incompatible cartridges", "print cartridge(s) problem" etc.) typically indicates the internal micro-electronics of the HP #901 / 901XL cartridge are damaged. The cartridge's electrical wire runs at rear and lower side of the ink cartridge are very delicate and are somewhat susceptible to ink attack over time, which can lead to premature failures. In addition, the older the cartridge the higher the chance of an internal electrical failure. I suggest you first run a 'Tap 41' diagnostic test to check cartridges electrical health (this is a forced test); you may also bypass the error (temporarily) on all models which use HP 901 cartridges. Refer to Inkjet411 youtube videos below:
HP Officejet J4500 J4600 4500 Printer Error Messages -HP 901 & 901XL Cartridges
http://www.youtube.com/watch?v=RivHgvWCkJ8
HP 901 & 901XL Ink Cartridge Alerts - Low Ink Warnings:
http://www.youtube.com/watch?v=hzLM5mlkTt4
HP Officejet J4500 J4600 4500 Printers Tap 41 Diagnostics - HP 901 Incompatible Print Cartridges: http://www.youtube.com/watch?v=S6uATgXxQlE
HP Officejet J4500 J4600 4500 Cartridge Error Bypass - HP 901 Cartridge Errors: http://www.youtube.com/watch?v=I4-m_RLdRE4
HP 901 Ink Refilling & Cartridge Care Tips - Everything you need to know: http://www.youtube.com/watch?v=jTtNj6rN4g4
Apr 12, 2013 | HP OfficeJet J4580 All-In-One InkJet...
ATASCO HP OFFICEJET J4585
When you get an HP integrated ink cartridge refilled (i.e. HP 60, 61, 74, 75, 901, 92-98....currently offered at Costco or Frys today) or if you buy a remanufactured/compatible HP ink cartridge, the ink levels cannot be reset (HP has a smart chip embedded within the nozzle plate at base of ink cartridge which counts the drops and then registers as empty).....so you'll just need to live with it and ignore 'ink low', 'non-genuine', 'counterfeit' messages and similar while you are using these types of aftermarket supplies. The first video below provides an overview of the 'low ink' phenomena.
Additionally, severe cartridge error (i.e. "refer to documentation" / "incompatible cartridges", "print cartridge(s) problem" etc.) typically indicates the internal micro-electronics of the HP #901 / 901XL cartridge are damaged. The cartridge's electrical wire runs at rear and lower side of the ink cartridge are very delicate and are somewhat susceptible to ink attack over time, which can lead to premature failures. In addition, the older the cartridge the higher the chance of an internal electrical failure. I suggest you first run a 'Tap 41' diagnostic test to check cartridges electrical health (this is a forced test); you may also bypass the error (temporarily) on all models which use HP 901 cartridges. Refer to Inkjet411 youtube videos below:
Feb 22, 2013 | HP OfficeJet J4580 All-In-One Laser...
The exclamation mark is on and the screen is flickering hp j4580 officejet all in one
A flashing exclamation mark is typically associated with a sever cartridge error (i.e. "refer to documentation" / "incompatible cartridges", "print cartridge(s) problem" etc.) typically indicates the internal micro-electronics of the HP #901 / 901XL cartridge are damaged. Have you tried replacing the ink cartridge with a new HP genuine cartridge to confirm?
NOTE: The cartridge's electrical wire runs at rear and lower side of the ink cartridge are very delicate and are somewhat susceptible to ink attack over time, which can lead to premature failures. In addition, the older the cartridge the higher the chance of an internal electrical failure. I suggest you first run a 'Tap 41' diagnostic test to check cartridges electrical health (this is a forced test); you may also bypass the error (temporarily) on all models which use HP 901 cartridges. Refer to Inkjet411 youtube videos below:
Jan 10, 2013 | HP OfficeJet J4580 All-In-One Laser...
How to reset ink levels from HP J4580 printer refilled 901 wont show ink level comes up as empty
slowly off and on the printer for five times without cartridge, printer saves data of cart of last 5 only so next time it reads full ink..
Jan 10, 2010 | HP OfficeJet J4580 All-In-One Laser...
Hp officejet j4680, incompatible cartridge
It is not necessary to buy another cartridge my friend, you can repair it. let me show you how... just take a towel paper, pour some water on and slide the cartridge slowly on, repeat this action 3 times and then slide the cartridge on another towel paper without water slowly and get the cartridge back in the printer.
good luck
Jul 02, 2009 | HP Officejet J4680 InkJet Printer
HP J4500 color cartridge error
Take the cartridge out and clean the contacts off with something (ie: pencil eraser, your thumb...) That worked for me! I couldn't find a solution anywhere even after chatting with online tech support from HP. Quick and painless! I hope this helps...
May 31, 2009 | HP OfficeJet J4580 All-In-One Laser...
My hp officejet j4580 says incompatible black ink cartridge
I've been in print cartridge hell since I bought a J4580.
I spent an hour on chat with HP customer service and was able to resolve the problem by partially resetting the printer. Here's how:
  • Make sure your print cartridges are installed.
  • Unplug the machine, wait 20 seconds
  • Press and hold the # and 3 keys
  • Plug the machine back in
  • You'll see a reset message on the machine, release the # and 3 keys
  • Follow the prompts to set the language and location
Cross your fingers, hopefully your printer will print now!
Apr 11, 2009 | HP OfficeJet 6110 All-In-One InkJet...
HP printer
chances are the cartridge is installed incorrectly, please be patint caused this is sometimes annoying. pls there is no oter way around it. good luck
Jul 21, 2008 | HP Officejet 5610 All-In-One InkJet...
Xerox Phaser 4500 (YB) Laser Printer Logo
82 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
