Question about Canon ZR800 Mini DV Digital Camcorder
Pictures have lines
3 months ago my pictures started having lines on it
When I video tape we are getting thick solid gray bars that go horizontally across the picture.
  • Kiwipinetree Dec 20, 2007
    Yep, I've got the same problem on my DCR-HC32 and would like to know the cause and solution please.
  • computeress Jan 29, 2008
    I too have the horizontal gray bar problem with my GL2 camera. I tried the Radio Shack head cleaner and it has not improved the problem.
Some people say that winter storage does this.it is ,apparently,to do with moisture and the residue it causes when it dries.to all of you i recommend putting your cameras in a sun-lit window for 20 minutes a day for 3 to 5 days.if it does not work,try a tape head cleaner.
Posted on Apr 05, 2009
Gray horizontal lines in video playback
dear ,
i Jasdeep working in superb broadcast as an lengineer .and for this problem i can suggest u the following things :
1. Play back the cleaning tape for 10 sec. only then use it.
actually this problem occurs when the head get clogged (i.e, dirty ) it REC. only single band and shows the same in play back too.
Jun 27, 2009 | Sony Handycam DCR-HC42 Mini DV Digital...
Horizontal grey lines running whe camcorder in play mode
Its symptoms of dirty / clogged video head. Please use Sony video head cleaning tape to clean video head.
Jan 28, 2009 | Sony Handycam DCR-TRV140E Digital...
I have a sony handycam - dcr-pc109e. When viewing a tape, there are grey horizontal bars across th screen that have just appeared. I cannot seem to get rid of them. Any ideas please?
Gray horizontal lines appears when video heads in camera got dirty / clogged.
Use good quality video cleaner cassette to clean video heads, problem will resolve.
Dec 16, 2008 | Cameras
Help!
Someone here recommended on another post to put the lense cap on & videotape the blackness in a quiet room for 5-10 mins. I tried this as a last resort & it worked. When I played back the tape, no more skipping or gray lines. I had 4-5 SOLID gray lines with skipping video & audio in between on every tape I put in. I think the person who helped me solve this said that it was a result of the tape alignment going off.
Apr 02, 2008 | Canon ZR800 Mini DV Digital Camcorder
Horizontal lines on playback on my camocorder samsung sc-d353
Someone here recommended on another post to put the lense cap on & videotape the blackness in a quiet room for 5-10 mins. I tried this as a last resort & it worked. When I played back the tape, no more skipping or gray lines. I had 4-5 SOLID gray lines with skipping video & audio in between on every tape I put in. I think the person who helped me solve this said that it was a result of the tape alignment going off. My camera is a Canon zr80 digital camcorder. (Called Canon, they had me reset it & then recommended sending it in).
Feb 21, 2008 | Samsung SC-D353 Mini DV Digital Camcorder
Canon camocorder thick gray lines on ever recording
Supreemwun,
Canon support was of no help. They ****! To fix the problem this is what I figured out.
  1. Before you start filming what you want record or just advance the tape 10 secs or so.
  2. Record/ video whatever you planned.
  3. Now when the thick grey lines come up on play back don't freak out.
  4. Simply rewind the tape to the beginning and record briefly in the blank portion at the beginning (careful not to tape too long as to tape over your intended recording).
  5. Rewind and play the thick grey lines should now be gone.
How did I figure this out just a fluke. No cleaning, no spray pretty simple. At first did not understand it but it works EVERYTIME for me. I'll deal with it until I get around to buying a new HD video camera and it won't be a Canon. Hope this helps.
Jan 13, 2008 | Canon ZR100 Mini DV Digital Camcorder
On playback, the video has gray lines across it
Someone here recommended on another post to put the lense cap on & videotape the blackness in a quiet room for 5-10 mins. I tried this as a last resort & it worked. When I played back the tape, no more skipping or gray lines. I had 4-5 SOLID gray lines with skipping video & audio in between on every tape I put in. The person who helped me solve this said: "the speed isn't linked with the last time you recorded on it. Frames have an A/B part to them. If A is hitting B instead of A, a line appears. I would try the head cleaner first, then blacken your used tape (keep lens cap on and record in a quiet room) and try that."
Dec 28, 2007 | Sony Handycam DCR-HC21 Mini DV Digital...
Gray lines on clips while previewing
Hello Nick, please purchase special mini DV tape for head cleaning. After a treatment with this tape you can check if there is an improvement with other tapes. If you need more info please advice. Arpi
Aug 12, 2007 | Sony DCR-PC55 Mini DV Digital Camcorder
Horizontal pixel line
I have seen this B4 here is a link that may help. http://www.wikihow.com/Fix-a-Stuck-Pixel-on-an-LCD-Monitor
Mar 31, 2007 | Samsung SyncMaster 240 T 24.1" Flat Panel...
Wide Horizontal lines on playback
Wide bands in the playback video indicate a clogged or defective video head assembly. If your cleaning tape appears to resolve the problem, the heads are getting contaminated. I would not use the same tape in this unit. Try cleaning the heads and then use a brand new tape to avoid clogging the drum assy again. If this does not resolve the problem, the drum assembly will have to be replaced. Hope this helps. Joe Weibel customelectronics.org
Feb 19, 2007 | Sony DCR-HC26 Mini DV Digital Camcorder
Canon ZR800 Mini DV Digital Camcorder Logo
399 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
