Question about Konica Minolta DiALTA Di200 Copier
My copier makes dirty copies.. how can i clean the machine, it is not on the glass
    Guru:
  • 389 Answers
Send you get fat service documentation Minolta Di200.
Shall is thanked if tell to FiXya about me.Good luck!
http://files.mail.ru/MMS9BH
Posted on Sep 29, 2009
Dirty copy result even if i replace a new drum
There are small wires that charge the drum to transfer image. Not sure if they are in drum unit or not on this machine. If the transfer chargers are dirty they will cause a dirty or voided copy. Make sure document glass is clean. Unplug machine check for these small wires if dirty gently clean with cotton swab or soft towel. Hope this helps
Mar 02, 2014 | Kyocera FS-1135MFP Copier require feeder
Samsung scx452f when making a copy on the scan glass the copy comes out covered by a toner to dark, when making a copy on the ADF the copy comes out good. what is the problem ?
Step 1:
Good day...
Before we start first make sure the machine is turn-off for our safety process.
Question: 1. Did you try to change the other toner cartridge?
Step 2:
Possible cause and way to check Toner Change Problem & No more Printing:
- Dirty Sensor (check all the sensor)
- Dirty Glass (check all the glass)
- The cartridge is not properly installed
- Full Waste Toner section
- The corona wire is dirty or broken (Inside the cartridge)
- The transfer Unit is dirty or broken (Inside the cartridge)
- Broken gear motor connected into the drum section
- If they have developer include in this model try to check it and
repalce if empty
- Broken Fuser Film
- Broken Fuser Lamp
- Broken or dirty Cleaning Blade Section
- Check if they have also chips include in the cartridge
Step 3:
Check all the possible cause and try to clean or replace the parts if broken.
Let us know if the problem is solve.
Sorry for my english
Feb 19, 2013 | Samsung SCX 4521F All-In-One Laser Printer
My copies comes out faintly. pls wat is/ are the cause(s) ?
the light copies on these machine can be result of dirty optics. On digital machine when the optics are dirty the copy is light.
You should remove copy glass and clean the lenses and mirrors and glass with glass cleaner and polish it verry well.
Also the problem can be dirty laser unit.Worn developer, worn drum, charge roller,...
Hope that helps!
Aug 24, 2010 | Ricoh Aficio 1035 Copier
Copy darkness problem canon image runner 2830
Did you try to clean beneath the copy glass?
On digital machines, when the copy glass or optics are dirty, copy becomes verry light.
How many copies do you have? pres 123 button.
It also could be that you need to change the toner station, by the book it goes 300000 copies.
But I bet on dirty copy glass and dirty scanner assy.Clean the glass with glass cleaner and polish it with dry cloth.
Jul 25, 2010 | Canon imageRUNNER 2870 Copier
My copy machine is D 861 digita.when i make a copy
If you're using the automatic document feeder (ADF) to scan the document, make sure the ADF scanner area is very clean. This is the area of the platen glass to the right side. Also make sure that you don't have reduction set on the copy size.
Jan 18, 2010 | Canon ImageClass D861 Printer
Copies are printing out light on the top half of page
The developer needs to be changed in your copier. It should be done by a service technician since the the toner developer sensor has to be recalibrated and all developer has to be removed out of the machine including the mag roller. If it isn't done properly the problem will continue.
Mar 19, 2009 | Gestetner Copier
Ask
Make on copy in the dockfeeder,and one copy on the platen glass.If you only have a line on the one copy make by the dockfeeder,the small glass next to the platen glass is dirty.Clean with spirits.
Let me know.
Oct 31, 2008 | Canon imageRUNNER 400S Copier
Failure to print properly
Is the machine a digital machine? If so there is a slight chance that the reason for the problem is that the mirrors are dirty under the copy glass. Remove glass and using glass cleaner on a soft cloth clean mirrors. Do not remove mirrors........
Clean copy glass and replace. If problem still there poss developer change or drum unit but most common is optic section. Also clean a **** glass in the machine. Open the door and you will notice a glass rod sticking out just above the drum unit. Remove clean and reinstall.
Hope this helps
Thanks Jason
Aug 16, 2008 | Canon Office Equipment & Supplies
Bad copies
This seems an easy one the first problem you are getting is that the paper pickup rollers are worn or just dirty easy way to clean them is to place one piece of paper in the tray and at the leading edge spay on some cleaning fluid about a inch wide. Then press the copy button and the machine will jam. Open the door and repeat a few more times. Once finished remove sheet of paper from tray and wipe dry.
The other problem is merely down to dust on the copy mirrors. Remove the top glass normally two screws on the right hand side of the copy glass. Once removed glass place in safe place. In the machine use a cloth on the mirrors you can use windowlene or some other kind of glass cleaner. (DO NOT REMOVE MIRRORS) clean all then clean glass and replace the copy should be clean. (NOTE!!!!! There should be about six mirrors so make sure you clean them all)
Oh and be careful machine should be off when doing above.
Hope this helps
J
Dec 25, 2007 | Office Equipment & Supplies
Brother MFC-5440CN Printer Problem
If this only happens when you are copying.
1. Your scanner glass is dirty. Open the lid, use windex to clean the flatbed. Look on the left side. You should see a strip of glass, with the scanner sitting under it. This strip is used when the document feed is being used. Make sure it is clean. Most common problem is getting a little whiteout or the sticky residue from scotch tape on this glass, which causes lines down your copies.
Clean it with alcohol which will dissolve the sticky stuff and the whiteout.
If this does not solve the problem, the CCD scanner in your machine might be going bad.
Oct 24, 2006 | Brother MFC-5440CN All-In-One InkJet...
Konica Minolta DiALTA Di200 Copier Logo
87 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
