My PC is not booting!!
My PC is not booting after I booted it without RAM. I have reinstalled my RAM and rejig it on both slot;also checked all connections, removed cmos battery for sometime also, still it's not booting, it's showing no sign of failure like beep etc. It just tries to boot automatically when i power on my PC but monitor shows no signal.
  • 329 Answers
First try to boot with new ram or try your ram in other cpu to confirm that its due to ram problem or something else......then try to replace your cmos battery or chk it with multimeter whether its working or not then try to change SMPS with new one............
Posted on Sep 29, 2009
Please need your help. When i put on my laptop( acer tmp 453) the screen is totally black. Happened after removing RAM and hard disk
Did you put the RAM back in? A PC will not boot without RAM. If you put the ram back in and its still doing it i would try reseating the RAM module(s) or trying different slots.
Dec 23, 2016 | Acer Computers & Internet
Computers doesn't startup and has no beep
remove the RAM chip and start the computer without the ram chip inserted and see if you get beeps if yes the motherboard/bios is ok, even if you dont get to hear any beeps, try rubbing the edge of the ram which goes into the ram slot using a Eraser and then reinsert the same back in Ram slot and then see if you can at least get to bios and see if hard disk is detected as windows boots from hard disk if yes check if you can boot to windows if no may need to reinstall windows.please reply with results so that can help
Feb 22, 2012 | Foxconn (945G7MA-8KS2) Motherboard
My pc will not boot up with both ram memslots filled take on ram out either one dosnt matter and it works fine put it bacvk in and locks aftwer boot or not boot at all
Hello
You need to seperate the ram sticks.Im assuming you have 4 slots.Color coded.Say 2 blue 2 white.
So 1 stick goes in white slot and the other goes in blue slot.
Or if you have 2 slots and while using both ram sticks you still can not boot up.This is beacause one of the sticks is different then the other.Read the ifno on the sticks.Something is not the same.
Sep 27, 2011 | HP COMPAQ Presario SR5510F Athlon 64 X2...
I was cleaning my HP Compaq dx2000 mt and forgot to put on the ram chips and turned it on and it beeped 5 times and a red led flashed 5 times, I put back the ram chips and turn it on and it doesn't...
Done it myself, RAM should have booted up after reinstalling the RAM.
Need to check very close on the RAM slots and make sure the the one slot on the btton of the RAM stick is directly down into the slot guide as can be forced but end clip would not set.
If this does not solve your problem I would suggest resetting the CMOS of your computer as it may have locked it out, CMOS finds all devices installed on the mainboard and addresses them to prepare for boot.
I am sending you a link to the HP support manual page for your review for how to clear the bios and boot back up to reset the CMOS up again. You might have reset your time and Date.
Let me know if good to go or if you still cannot boot or have the "Orange" led.
Please go to the HP link below by coping and pasteing into your web browser. The LED listing and CMOS resetting is on page #2 on the right side of the Adobe PDF document..
Goog Luck
http://h20000.www2.hp.com/bc/docs/support/SupportManual/c00068577/c00068577.pdf
Aug 29, 2011 | HP Compaq dx2000 Microtower PC Desktop
Will not boot up.
1. check your video card it may not be seated in the pci slot provided on the mother board or it may have lost the driver set. This will require a re-install of the video card. If the video card is on the mother board this will require another video graphic card to be install via the pci slot or pci express graphics slot compatible with your PC.
Apr 07, 2010 | E-Machines eMachines Desktop PC
Inspiron 1501 wasnt booting so reseated memory ram one at a time. it will boot with 1 memory ram but not 2. any suggestion
check both memory slots with the same stick of ram. Possibillity :bad slot or bad ram stick.
Oct 31, 2009 | Dell Inspiron 1501 Notebook
Laptop doesn't recognize new ram
I would guess that you need PC 133. Some manufactures that were using SDram at the time required PC133 while others would require but allow you to use PC100.
This is the requirement for your laptop from www.crucial.com
Each memory slot can hold SDRAM, PC133 with a maximum of 256MB per slot.*
Hope this helps
Apr 09, 2009 | Gateway Computers & Internet
Ram upgrade
you need to make sure the ram is compatable, it looks like an old machine so chances are its using sdram pc100,
check the ram your trying to make sure its not pc133. let me know what each piece of ram has on its sticker
Mar 23, 2009 | Dell OptiPlex GX200 PC Desktop
Dell Latitude D600 - RAM not recognized
One of the DIMMS might be incompatible or faulry.
Put one DIMM in at a time to determine which is not working.
If they both work separately then it appears they are incompatible together. Try to get the DIMMs from the same manufacturer, with the same specs.
Mar 08, 2009 | Dell Latitude D600 Notebook
Acer travelmate 2003lc will not boot with new ram
512MB (FT64MSD64V3F)
200 Pin Dimm - SDRAM - 2.5V - DDR - PC2700 (PC-333) - Non-ECC
is the correct type of RAM for your laptop.
Have you tried booting with all combinations.
512 in slot 1 --- Boots
move same dimm to slot 2 (on it's own) and try booting.
boot with 256mb in slot 1 and known to be good 512 in number 2
This laptop should allow up to 2GB RAM. So I don't belive it is an issue with the mother board not seeing the amout of RAM. I think it could either be flaky dimm or your slot 2 is damaged
Aug 23, 2008 | Acer TravelMate 2300 Notebook
Computers & Internet Logo
81 people viewed this question
David Payne
David Payne
