Question about Cameras
I dropped my sx100IS in water, and now the battery keeps dying. Any ideas?
Tip
Dropped the cell phone or mobile in water
Dropped the cell phone in water
If you would have accidently dropped your cell phone in water or it fell in water you can try fixing it be these below tips
1. Remove the battery of the mobile and try drying it with a hair dryer
2. Put the cell phone in a raw rice container for a day, the rice will soak the moisture and the mobile will become dry from inside
3. After that put the battery back on and try switching, there are more chances now that it will work
4. Never try to instantly switch on the cell phone after taking it out from water you should follow the above steps, switching it on instantly can lead to short circuit in mobile and the cell software can get damaged
5. You can also put the phone in light sunlight (not in very hot direct sunlight) after removing the battery do not put the battery in sunlight though
6. Also make sure you keep the SIM card out of the mobile
By taking these steps you can make a fair attempt to save your mobile from dying.
Regards
Vikram
on Dec 02, 2009 | Cell Phones
Battery keeps dieing on my accord?
take your car to your local auto parts store for charging system diagnosis most will do it for free and you'll have a better idea of what needs to be done.
Sep 14, 2014 | 1994 Honda Accord
Canon powershot sx100is. Error 24 on starting and camera turns off. Can view pictures already taken.
some dry wash lens,display & camera.mother board clean with isopropyl or" petrol.if use ******** wash very good.something heat with mobilephone past.so work it again.harry up in one day or"So4 damage your board.
May 30, 2012 | Canon PowerShot 600 Digital Camera
Kipor 6700t - The battery keeps dying on my genny. I changed it today but now it turns over but doesnt kick in. Any ideas? Em
Ff you do not have a draw an the battery.
It is the battery.
Unless you cycle your generator every few weeks this small battery will drop below 12 volts and start destroying it self.
SOLUTION:
Our best fix was to add a 5 watt solar panel and now the battery stays above 12 volts and has extended its service life.
Hope this tip helps.
R/
David
Mar 11, 2010 | Electrical Supplies
I have a 1997 ciic Hatchback. The lights in the
check small earth conection at thermostat housing where lower water hose meets housing could solve should solve speedo ploblem. good luck.
Nov 11, 2009 | 1997 Honda Civic
I got a Samsung Gravity and it wont turn on.
dear,
if your phone dropped in water then the first step to be done is immigately remove the battery and then let it dried through a table lamp. you should keep it under 100 W test lamp at a distance of 5-6 feet. if it worked fine after dropping in water and again shut off then open the cover and do this method..
goodluck....
Aug 20, 2009 | LG VX5200 Cellular Phone
Powershot SX100is battery life
hey, i had same problem.. after i started using energizer ultimate lithium AA it started lasting weeks
Jun 16, 2009 | Canon PowerShot SX100 IS Digital Camera
Black Screen; Change Battery Message
simple! with my Canon S90 had the same problem until I changed the SD card from LEXAR for a TOSHIBA SD card and the message " Change the Battery Pack"disappeared.
Jun 27, 2008 | Cameras
1995 pontiac transport
I have one idea, but keep in mind that I am miles away, so don't be too critical of me!
I had a similar problem with a Dodge Durango. The fix was the battery. I had very similar symptoms, and when the battery was replaced, PRESTO! The problem was gone. If you are able, have the battery replaced/or at least checked. You can have the battery checked for free at any major parts store like AUTOZONE.
Good luck, and keep us updated!
Jun 09, 2008 | 1995 Pontiac Trans Sport
Cameras Logo
13 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
