Western Digital My Book Essential Edition  500 GB Hard Drive
Problem for Western Digital My Book Essential Edition (WDG1U5000N) 500...
My Book makes clicking noise and does not show up anymore
By July77 on Dec 18, 2007
Help! I have all my files on MY Book and until today it worked great...now it clicks when I plug it in and my computer does not seem to recognize it anymore. What can I do??? Thank you for all the help! Merry Christmas!
Same Problem
May 24, 2009
-   my book doesnt show up when i plug it into my computer its makes the sound that lets me know its connected but it doe not show up in my computer -   scgshit66
Apr 30, 2009
-   WD My Book 500GB. Six clicks, stops spinning, light stays on. Not recognized by Toshiba A6, WP pro. -   Guest
Apr 24, 2009
-   Mine lasted a little over two years. I had noticed it would run continuously sometimes and I tried to remember to make sure to turn it off manually, but then it started turning off every few hours, then finally the clicking began.
I've got it in the freezer now hoping I can get it to work one last time. After that I will tear it apart and try to hook it up with the SATA.
-   Guest
Apr 05, 2009
-   I've got the click. Tried everything ( except the freezer solution ) nothing works. i'm frustrated-   Guest
Mar 21, 2009
-   it clicks to show that its reading it bt does not recognise it anymore....this then makes my pc un responsive-   proton5111
Best Solution
posted on Aug 01, 2008
Very Helpful)
Guest
Rank: Apprentice  Computers & Networking  Expert
Rating: 0%, 0 votes
This might be a good thing to check before you start voiding warranties, opening cases, or panicking, AND if you have recently reorganised your setup.
I found that my drive was making the dreaded clicking noise about once per second when I turned it on, and that it was not recognised by the computer. I later discovered that I had plugged in the WRONG power cable. The MyBook was plugged into the seemingly identical cord for a cable modem that I have. The current and voltage were different so of course, the disk didn't work. Funnily enough, the cable modem worked fine. Switching the cables back solved everything.
So as a first guess, assume your own stupidity is at fault - mine was.
Solution #2
posted on Aug 02, 2008
Helpful)
Guest
Rating: 0%, 0 votes
Hi, I have a potential solution to this problem. I don't know if it will work for everyone, I just know it worked for me.
I had the same problem as everyone here. The MyBook wouldn't be recognised by the computer. Fornutately for me I was merely moving file using it, so I wasn't totally screwed. I figured I'd just move less files at a time.
So, I plugged in my USB stick and low and behold, my system starting recognising the MyBook as well!
My guess is that plugging in a USB device that's not so unstable woke the system up and made it look harder at the USB ports.
So, there you have it. Like I said, I don't know if this will work for anyone else, but I thought I'd put it up here in case it did.
Signed
sgh
Solution #3
posted on Mar 10, 2008
Helpful)
Styb
Rank: Apprentice
Rating: 89%, 5 votes
My issue was in fact a USB power problem. The WD drive works fine on my (1 year XP old) Dell and iMac but will not work on my old Powerbook G4. The only activity I get is a clicking sound and a continious flashing blue light indicator. I will try the dual-head USB cable option to see if that helps.
Was this helpful?
Yes
No
Solution #4
posted on Jan 07, 2008
Helpful)
janeydoey
Rank: Apprentice
Rating: 86%, 11 votes
My Book just did this today, was working before lunch, died after I got back. Click click clik! Found this online:
http://www.ransackery.com/western-digital-mybook-open-case-recover-data.htm
I think mine is a power issue, so I'm going to try this as soon as I get back home and have access to phillips screwdriver and get extra sata cable.
I need an external with a higher crash rating anyway, like a solid steel case or rubber so it'll bounce next time I drop it. You'd think the my book was steel for all its weight.
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #5
posted on Jan 25, 2008
Helpful)
Guest
Rating: 0%, 0 votes
I don't have a fix for the problems with the WD MyBook 500GB drive (my issue is very similar to many listed here), but I do have a solution on how to extract data when you can't access it. I found a program called GetDataBack that I used to pull all the data off my drive. It took roughly 17 hours for 104 GB of music, video and other files, but at least I got it off of there.
WD's support is a joke. I'll just pay the 50 extra bucks and get a better drive next time.
Solution #6
posted on Jan 10, 2008
Helpful)
Lazy703
Rank: Apprentice
Rating: 86%, 57 votes
THIS WORKS....Here try this...unplug everything including the power cable...press and hold the button on the unit for 10 seconds. after that hook the unit back in the power cord first..and it should work...files and everythin are there...I got this from tech support and it worked for me
Was this helpful?
Yes
No
6 people thought this was helpful
Solution #7
posted on Aug 08, 2008
Somewhat Helpful)
akim211
Rank: Apprentice
Rating: 81%, 16 votes
OMGOMGOMG!!! PAY ATTENTION! I have been depressed all day reading these reports on the click of deat. I had the same noises in the same 6-2-2 pattern. As i contemplated suicide i decided to fiddle round with the cables and it miraculously came back to life!!!!
1) Unplug everything
2) plug in the power cord yo your wall outlet and make sure its flush
3) plug in the adapter to your hard drive
4) Press the on button (this is where it gets exciting)
5) i heard one click and the drive started running
6) in nervous anticipation plug in you Usb cord to your hard drive
7) praise whatever god you want that your hard drive has risen from the grave!!!!!
Was this helpful?
Yes
No
5 people thought this was helpful
Solution #8
posted on Dec 26, 2007
Somewhat Helpful)
Guest
Rating: 0%, 0 votes
Same happened to me this morning (Christmas). My Books generally come with a 3-year warranty, so let me know if any of you manage to get ahold of Western Digital support for a replacement. I currently can get onto their website, it appears down for my area.
I've read that if you need the files they refer you to a third-party disc recovery service that starts at $500 and goes higher to retrieve the files. Sounds like a hell of a scam. Sell a $150 500GB drive, have it break in 3-6 months, then charge $500 to get the files off. Turns quite a profit.
http://support.wdc.com/warranty/selection.asp?custtype=end
Solution #9
posted on Dec 20, 2008
Somewhat Helpful)
CTM1
Rank: Apprentice
Rating: 74%, 3 votes
I have a 500 gb My Book Premium Edition WD5000N that wouldn't show up and was continuously clicking every 1-2 seconds. I discovered it as soon as it started to malfunction and tried several ways to get it to show up on the MAC Desktop by trying different cables/computers/USB versus Firewire/turning on and off multiple times/using DiskWarrior and Disk Utility/Applejjack to do repairs for about an hour or so. Nothing worked. The disk wouldn't show up on the Desktop and continued to click.
I then read about others who removed the hard drive from the external unit and mounted the drive internally so I decided to try this.
Mine differed from these enclosures:
http://www.neoseeker.com/forums/7/t819501-how-to-take-apart-your-wd-mybook/
http://www.youtube.com/watch?v=6FlySnyJ0CQ
It is closest to this one:
http://www.sigg3.net/b2perma.php?p=1185&c=1 but no rubber band - only glued on metal cover.
I had to destroy the case to get the hard drive out as mine differed from the ones described above (and they are not built to take apart!!!!). First there are no external screws. Pry off the metal perforated grill that covers the back of the unit. This is just glued on. Instead of a rubber gasket, my unit had vinyl that was all part of one piece so I couldn't peal off the gasket. Taking off the metal perforated grill reveals 3 tabs on the bottom (these were covered up) plus the readily apparent 3 tabs on the top. Press these down and hold them down by wedging something in the perforations. On the long edge close to the connectors, pry outward with a screw driver since there are tabs here that prevent you from sliding the hard drive out. Then try to slide out the hard drive away from the metal skin. This method is based on the disassembled unit. I had to pry the whole plastic unit away from the metal front casing so if the above method doesn't work, try brute force (just don't pry on the hard drive.
One you get the plastic holder away from the metal front piece, take out every screw you can see. Be careful with the flat screw that holds the on/off switch (if your unit has one) since this is easy to strip. Take out the 4 screws holding the SATA circuitry to the hard drive and unplug the wires, the 3 screws holding the front switch, and the 4 screws holding the hard drive to the plastic piece. This allows you to remove the metal holder and the hard drive. Now take off the 4 screws that hold the hard drive in place. Then pry off the silicone washers. This releases the hard drive which is covered with a metal film. Carefully pry/peal this off. Don't damage the controller board.
This revealed a WD5000ks caviar drive se16 which is a SATA drive made April 22, 2006.
Western Digital Caviar SE16 WD5000KS 500GB 7200 RPM 16MB Cache SATA 3.0Gb/s Hard Drive - OEM
No jumpers were installed.
I installed the drive into the internal slot of my PowerMac G5 and it now shows up on the desktop. I rebuilt the drive with Disk Warrior (it had minor errors) and checked it with SMARTReporter which reports that the drive passes the SMART tests.
It's has been up for 5 hours and works fine, no data loss.
So, I think that the problem was with a defective SATA connector/circuit. If you catch the drive early when it begins clicking (don't leave it on long with it clicking as this may mess up the hard drive heads), you can remove the drive and use the SATA circuits in your computer to mount the drive.
Hope this helps. Again, my advice is the minute you hear the clicking sounds, try fixing via usual techniques but if these don't work, take the hard drive out of the enclosure (sooner rather than later) and try it internally. This will void your warranty but might allow you to save your data (and maybe even the hard drive).
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #10
posted on Sep 21, 2008
Somewhat Helpful)
Guest
Rating: 0%, 0 votes
Ok, I got it. its a plug and play driver issue. I had the same problem and just considered it dead. Recently I had to do a complete reinstall of windows on my laptop and when I plugged in the Mybook it reinstalled its plug and play driver and worked. Lasted about 1 week and has died again. If you desperately need your data back you'll need to reinstall windows and it will work.
Solution #11
posted on Aug 13, 2008
Somewhat Helpful)
hopeithelps1
Rank: Apprentice
Rating: 70%, 1 votes
sounded like mine was dead too. spent a day just plugging in the power and turning it on and then back off whenever i heard the second click. watched die hard 2 and after about the fiftieth time i heard only one click. so while it mite not be dead i think you casn get another run at. it done shutdown after being on for a few hours tho. but i managed to copy all the data before that. so just try turning it on and off a bunch of times and it should eventually kick back on long enough for you to maybe extract your data. a solution for those less tech savvy unable to open up there hard drives.
Was this helpful?
Yes
No
Solution #12
posted on Oct 25, 2008
Very Helpful)
zzptichka
Rank: Wiz
Rating: 80%, 45 votes
Clicking is usually caused by bad heads and in this case drive needs heads swapped by a pro.
Check out this page with sounds hard drives make with problems explanation. Hope it helps.
Was this helpful?
Yes
No
Solution #13
posted on Aug 19, 2008
Very Helpful)
eNLogic
Rank: Apprentice
Rating: 100%, 2 votes
Ok, my myBook started making the 3-clicks...3-clicks. The drive is dead. It is now a race against time to save your data. Believe it or not, this worked (once) for me. Put the drive in the freezer and then plug it in while its cold. Ice cold. I had mine in the freezer for like 2 days. Make sure you have another drive to transfer the data to as this trick worked for me once and only once. I tried to put it back in the freezer and it is just clicking now. This is actually an old hard drive data recovery trick. It has nothing to do with the myBook in particular.
I have been a loyal Western Digital customer for years. This drive is about 18 months old; warranty just expired. I have been reading online and it seems many people are experiencing drive failures immediately after the warranty expires. I will never buy Western Digital again. Buy Maxtor - 5 Year Warranty on my new OneTouch!
Was this helpful?
Yes
No
Solution #14
Somewhat Helpful)
sgh_
Rank: Apprentice
Rating: 75%, 2 votes
dfah
Was this helpful?
Yes
No
Solution #15
posted on Dec 03, 2009
Not Rated)
qlott
Rank: Apprentice
Rating: 0%, 0 votes
My Book 320GB makes a clicking noise only with Vist or Windows 7.
Was this helpful?
Yes
No
Solution #16
posted on May 31, 2008
Not Rated)
Guest
Rating: 0%, 0 votes
My my Book 160G was clicking-spinup-spindown-clicking spinup-spindown-turnoff and was not recognized.Thanks to the above post from Janeydoey with this link! (and Thanks Again!)
I was able to recover all data. Mine had an IDE connector instead of the SATA in the article. There was no clicking going on while connected to the computers power supply and IDE. This was a lot cheaper than the $790 quote I got for data recovery!
Popular Solutions for Western Digital My Book
Questions and Unsolved Problems for Western Digital My Book
Do you recommend Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive?
Answer
Answer
It succesfully adds the adware junk and then here is an exit sign. From there, nothing seems to... (More)
39 Other Users Have The Same Problem - Continued
Comment by Guest, posted on Mar 20, 2009
same exact problem. I've been holding on to my drive for a year now hoping to finda solution...
Comment by andrewsleon, posted on Mar 10, 2009
Same thing! Computor won't recognise it and it has clicking noises!
Comment by swoan, posted on Jan 31, 2009
Today for the first time I've encountered the same problem.  It just kept making a weird clicking noise and my computer no longer recognizes it.  I am a photographer and I used this to back up my images.  I need help.
Comment by Guest, posted on Jan 20, 2009
Same problem here, at least it lasted for a year or so... no more WD's for me either...
Comment by Guest, posted on Jan 16, 2009
Same problem as everyone with the 3-3-2-2 clicks. No solution up to now. Still hoping to get my data back.
Comment by Guest, posted on Dec 16, 2008
ive had my 400 gig for nearly 3.5 years now. yesterday for the first time it was not recognized by my laptop. I hear the same clicking when trying to power up. Luckily its not completely dead and with patience it will eventually power all the way up. Although it has not lasted more than six hours, i was able to transfer all my data to a new hardrive. im still looking for a fix though.
Comment by imascarman, posted on Nov 08, 2008
Drive just keeps clicking....I followed the steps to take the drive out of it's enclosure and put it in my other computer as a secondary internal drive and it still clicks and stops spinning. The device manager shows a second disk drive but doesn't know what it is. Doesn't show up in explorer. I really need to get some of that data off. This was my backup but had recently been storing data on it only as I was going to rebuild the computer it was attached to and then dump it all back down to the PC. So much for trusting WD My Book to be my reliable backup...I'll never buy WD anything again!
Comment by magedarkness, posted on Nov 03, 2008
I have the same problem! After about 6 months, the drive started clicking and I couldnt get any data off of it. I left it alone for 5 months, and then tried it again. It started working again! I dont know what happened in that 5 months, but it worked. After about another 6 months, it started clicking again. I did the usb stick idea, and that worked for about 3 days, now, nothing again.
Comment by cmadt, posted on Oct 18, 2008
I just lost my second My Book.Same clicking noise both times.
First one after six months, second only lasted three.
And no, It's not the power supplies.
WD's RMA process is easy. But I'll never trust a WD drive again.
Comment by rkirsch, posted on Sep 19, 2008
My Book is also making clicking noises and my computer will not recognize it.
Comment by Guest, posted on Sep 19, 2008
I have the exactly same problem. Argh!
Comment by aric719, posted on Aug 17, 2008
Comment by Trev7186, posted on Aug 06, 2008
I have the same problem, tried all the fixes here and then dismantled using the Ransackery site plugged it into my PC still have the clicking so i would guess its the reading head not initiallizing. I think we have all learnt something from this 1) back up everything thats Important to DVD or CD 2) Never ever trust HARDWARE! 3) have a box of tissues next to the PC for your tears when said hardware breaks lol. 4) Don't buy WD!
Comment by jimhollis, posted on Aug 02, 2008
When powering on I consistently get this pattern - The drive spins up... I hear six clicks... the drive spins down... the drive spins up... I hear two clicks... the drive spins down... the drive spins up... I hear two clicks... the drive spins down and stays down.
Comment by scritchy, posted on Aug 02, 2008
three clicks and nothing. the power button does nothing. wd stands for whata drag!
Comment by shonky1, posted on May 31, 2008
I have the same problem with mine. Turn it on and you can hear three distinked clicking noises before going into idle. It no longer appears through windows explorer. Good work Western Digital!!
Comment by prozim, posted on May 12, 2008
My My Book makes the same clicking noises. I have a My Book Essential Edition external hard drive (Western Digital, model WD5000C032). My computer is a HP Compaq dx2200 Microtower with Windows XP and Pentium 4 processor. The hard drive always showed up as an E drive. Now, it is not showing up at all. No drivers are needed for install. I went to the Western Digital website, but did not find any updates that needed to be installed. I've restarted the computer and tried plugging the drive into every USB port that I have, but none of this has worked. Fortunately, I had everything backed up on my computer's hard drive as well, so I don't need to recover the data. I'd just like to be able to continue to back up my data on an external hard drive without buying a new one, although I can if I have to. Any ideas?
Kevin
prozim@hotmail.com
Comment by bushell23, posted on May 11, 2008
Same problem here. Mine clicks 6 times then gives up.
Comment by emhol, posted on Apr 23, 2008
I have the same problem. The three clicking sounds and then it goes idle. My Powerbook doesn't detect the harddrive at all. I'm very happy for all the tips on what to do and I will sure try them all until I find a soloution. 3 years of my life is on that stupid thing!
Comment by bradman1479, posted on Feb 08, 2008
I can't no longer access MY Book. When I turn it on, all I can hear is the 3 annoying clicking noise and it goes idle....my computer see it as USB device connected but I can't see the hard drive or access it!!!
Comment by erokocho, posted on Jan 22, 2008
My Book crapped out on me too. I was copying a file over to it the other night and got an error message saying "Error Performing Inpage Operation". I used Active File Recovery to get a lot of the data off of it before it froze up on me a second time. Now I can't access any of the data at all. It now just clicks when I turn it on. Is the thing fried or what? I really don't want to lose my music collection that I had on the HDD. What are my options?
Comment by Dinotsi, posted on Jan 09, 2008
Got up to get something out of the living room while my laptop restarted and came back to listen to some music on my laptop. The drive turned back on and I heard 3 clicks and then the light on the drive started flashing. I restarted it 6 times and it repeated the same clicks and then light flashing. I knew it probably crashed at that point --- or did it?
what do I do?
Comment by Mgraine, posted on Jan 03, 2008
I have the same Problem my 500gig MY Book just clicks and will not show up ...this is the 2nd one to do that the first one I finaly got to show up after pluging and unpluging it for hours got my data off it but the 2nd one will not work ....I am never buying WD HD's again I had it full of data now I cant access it at all.
Comment by amanda17, posted on Jan 02, 2008
THis is the exact same problem I have had, the drive has worked like a charm for a year, now today it doesn't show up on the drive list, and there is that clicking sound. I need the data, of course. And sooner, rather than later, of course.
I'm not even sure where is the best place to go to have the best chance of getting the data?
Comment by aswudgeta, posted on Dec 30, 2007
I'm having the same problem with mine. mine's a 250 GB. It didn't come with installation software, just had to plug in. The problem started yesterday, first it started making a clicking sounded, then it locked up. I shut my computer down, but the drive would not shut off, I had to unplug. tried hooking up to 2 other computers, starts makes clicking sound, and thats it. It won't even shut off with you push the button.
Comment by kjmac6, posted on Dec 29, 2007
I tried plugging it into a different computer and it worked fine. I unplugged it from that computer and put it into my original computer. Still did not work, so I plugged it back into the second computer and it did not work there the second time. Went though 5 computers and it happened each and every time. Worked the first time I installed it on a computer and then didn't work after that. Even tried to reformat the drive and it worked for 2 days. After putting all my files back on, it failed again. Just a bad product! Try a new computer, get your files off and return it to where every you got it. Line forms here!
Comment by darcyzero, posted on Dec 29, 2007
Had the same problem starting today!! I bought the HD back in April!! I lost 500GB worth of data. Thankfully it wasn't anything super important but its still annoying. I noticed the HD was acting weird a few days ago but I didn't think much of it. Then today it was coming up as LocalDisk and I got an error when I tried to access it. I did some research and tried chkdsk, It worked! I was able to get to the HD and back up some of the important files that I had on there. Then as I'm backing it up the HD dies. I start it up again, this time it buzzes a little.. and then CLICK. CLICK. CLICK. I restart it.. it powers on.. usb works.. and then the drive just clicks. I guess WD was serving up a bad line of HDs 6-8mo ago and we all got "lucky".
Comment by Cooler, posted on Dec 26, 2007
Folks,
Update from me is that WD will replace my drive, although it will take 3-4 weeks as it is going back via the retailer.
I've done some research on clicking drives and it is indeed a sign of permanent failure. In my case the problem was intermittent so I managed to get the files out before sending the drive back.
I would like to know how common this problem is, as it introduces a level of insecurity into backing up files which seems to defeat the object.
Comment by Reardon145, posted on Dec 24, 2007
same problem! i really need a solution....and fast!
Comment by Kwintzy, posted on Dec 24, 2007
Same thing happened to me today (Dec 24, 2007). Any ideas why so many are failing at the same time?
Comment by ssscott78, posted on Dec 24, 2007
Yep, same here..and I really need the files from it. I've had My book for less than 7 months. Clicking noise non-stop. I've needed to restore my files and had tons of errors, but was at least able to recover most of them. However, as of today, it won't even show up under My computer. The USB ports are functioning properly and the driver diagnostic tool says it's fine as well. My Book does not show up and therefore, I cannot access any of my backed up files. What should I do? I'm desperate here...
Comment by Guest, posted on Dec 23, 2007
Same exact thing for me starting today. I have the 500GB USB.
Comment by Cooler, posted on Dec 22, 2007
Same here, clicking and doesn't show up in windows. Does anyone know the mechanics of this problem? is it a dead drive?
e.
Comment by massdestruct, posted on Dec 20, 2007
I am having same problem, it sounds like the drive can not start up for some reason.
Describe your Hard Drives problem:
Related Products & Issues:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Hard Drive Experts
Top Computer & Laptop Repairmen
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
Insert Link
What is this?
Select
close
Add to My Products
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
Step 1: Select a category & subcategory
Step 2: Select a product and click on add
I can't find my product
select
close
Success!
Add another product
Close
close
Save This Product
Enter your email address
We will not share your email. Privacy Policy
I agree to the FixYa Terms of Use
Send to friends
Send to: (e.g. Julie@email.com)
(Separate email adresses with commas)
Your name:
Your email address:
Message:
