My printer is not spooning - Office Equipment & Supplies
  • Jamil Ahsan
    Jamil Ahsan May 11, 2010
    Go to start, control panel, Admin tools, and then services. Find a service named "Printer Spooler". Make sure its status is "Started" and it is set to "Automatic. Let me know if it helped. Jamil
How many grams are in 1/2 tablespoons(tbsp.)?
You answered your own question!
Yes, there in inequality in the world. Your good old Aussie measuring spoons used for stirring your tea, as just that, an implement for stirring tea. Measurement wise, they are based on UK spoons, because you all came from the UK in the early days of colonisation.
The Americans, did things their way and used the 'Cup' as a measure, because in the cowboy days, everyone on a wagon train had a mug or a cup. If the whole recipe is in Cups, it doesn't matter if the cup is the size of an elegant coffee cup, or a 1 pint enamel mug, because the ratio was always the same.
The best way is electronic scales and measure in quarter grams.
Jan 18, 2017 | The Kitchen Appliances - Others
Print head not moving
first put your printer off - look under your head of the printer you will see little white plastic move it with your pen or spoon or any other then pull your head to left
Feb 13, 2015 | Epson Stylus Photo 925 InkJet Printer
Sides of hat are wrinkled. How do I straighten and stiffen?
how about heat up a soup spoon on gas range or other heat source and then iron your hat wrinkles with spoon when spoon cools heat it again or go to a hat store the person should be able to fixya
May 18, 2014 | Office Equipment & Supplies
What is a runcible spoon
A runcible spoon is a sharp-edged fork with three broad curved prongs. How that relates to fishing I'm not sure.
Oct 31, 2013 | Advance Tackle Michigan Stinger Scorpion...
Are measuring spoons only made of plastic?
No, even tho the most common material for measuring spoons is indeed plastic, there are also companies that produce them in metal and other materials. However the plastic is the easiest kind to find in stores
Jul 16, 2013 | Home
What is the best material for spoon rests?
Spoon rests are made of different materials like wood, plastic, glass and ceramics. I personally believe the worst to be wood because it absorbs very easily any liquid and never really gets cleaned well. Plastic also absorbs, even tho much less than wood, and is much easier to clean. But, like wood, will probably retain the odors.
The best option I believe is ceramics, because is more commonly found than glass spoon rests, and is strong, easy to wash and doesn't absorb odors.
Jul 16, 2013 | Home
Why is a spoon rest necessary?
Spoon rests are very useful for keeping any food from staining the counter while cooking and at the same time protecting the spoon from touching any contamination that might be on the counter
Jul 16, 2013 | Home
I want to scan a picture and make it A4 size
take a photograph of the spoons, depending on the camera quality, and the ability of the camera to take macro photographs, ( most of the modern cameras do have) Then take the photo into some sort of photo editing program, and enlarge the file/photo up to A4 at 300 dpi and print out
Jan 12, 2013 | Office Equipment & Supplies
186 people viewed this question
k24674
jasbo
jasbo
