Question about Samsung Digimax S630 Digital Camera
Stripped out Mount
Where can I find a new tripod mounting piece for my samsung s630. I noticed there are just 2 screws holding in the one that is stripped out. Thanks for your help
    Scholar:
  • 39 Answers
Just visit the link below for the tripods that you could purchase for your S630 camera:
http://www.myaccessorymall.com/product/product_list.asp?categoryID=34
Hope this helps.
Posted on Jan 12, 2008
What do I do to attach the camera after attaching it to the mount piece?
the quick release plate, that you are calling the "mount piece" will just snap onto the head of the tripod - if you aren't sure, a good way is to take off the QR plate from the camera, and then, with the screw threads face up, see how it fits into the head - many times, you have to engage the spring lever, so when you set the plate inside the head, it will snap locked into place. Then, re-mount it on your camera, and do the same thing, and there ya go.
Jul 01, 2014 | Manfrotto Camera Supports 3405BN JR. BLK...
Hi, I have a meade lxd55 tripod (with 8" discovery newtonian mounted on it). 2 of the 3 leg braces at the bottom that also hold the eye piece tray have broken. I need to replace 2 or all 3. Can I get...
Sometimes you can find these for sale at these web sites--
Sometimes--
http://shop.telescope-warehouse.com/
and here:
http://astronomy-mall.com/astro.parts.outlet/
You might try calling Meade directly:
http://www.meade.com/support/index.html
Mar 14, 2011 | Meade Optics
I need to purchase screw that attaches scope to window mount on a 78-4405
The mount has a 1/4-20 screw that fits most camera equipment. If you have the scope (spotting scope) it should have that hole in the bottom of the mounting ring. If the screw is missing from the window mount then most 1/4-20 tripod screws will work or you may substitute a cap screw and flat washer, to work with an Allen wrench for tightening.
Feb 07, 2011 | Bushnell 784405 Tripod
I broke a piece off of my tripod mount, can I buy
Call us at 800 735-4373 if you are in the USA. From your description of the problem the answer is no. We would have to know which tripod and exactly what broke.
Apr 26, 2010 | Giottos (VT806) Tripod
Nikon 70-200mm Tripod Mounting Question
There should be a mount that attaches around the barrel of the lens with a flat part that would allow you to screw that to your quick release plate. The flat part usually have several screw holes so you can mount the quick release plate for or aft for better balance. These mounts are removable so it may have been taken off.
Nov 22, 2009 | Nikon 70-200mm f/2.8D VR G-AFS ED-IF Lens
SD600, the camera time resets everytime i turn it on. i read the manual and found out that there is rechargeable lithium battery built into the camera to save such setting. does any one know what type...
There's a little battery in the camera under where the tripod mount is. Make sure your camera is out of warranty before attempting any repairs. Opening the case will void your warranty. Do this at your own risk.
1) Remove all six screws from the outside of the case.  2) You'll need to loosen the LCD panel, there are two little tabs holding the panel, and one screw up by the speaker (photo/movie/view) switch.  3) Remove the screw by the speaker, this will give you access under the LCD. Do not unhook the LCD cables.  4) Now under the LCD panel you should see a screw that connects the metal backplate with the tripod mount, remove that screw.  5) On the bottom, on the main motherboard, there's another screw holding the tripod mount in.  6) After removing the tripod mount, you should see a battery under the LCD cable.  7) On the main motherboard, gently (GENTLY) remove the large LCD cable and pull it through to the other side.  8) You should now see the battery pretty clearly.  9) Replace the battery. MS614X 10) Reverse the steps.
Mar 02, 2009 | Canon PowerShot SD600 Digital Camera
Gears will not hold telescope
This is a common problem in the DS series. The altitude slewing mechanism has a design flaw that will cause the jack screw to back off of the axis gear, and get the screw caught on the internal body of the mount. It also tends to crush the jack screw against the motor spindle.
Meade does not sell replacement parts. You'll have to send the mount to them to have it repaired.
Jan 29, 2009 | Meade DS114-EC Telescope
Missing Tripod piece (Quick release)
What you can do is find a local welder or metal shop in your area. Take the tripod with you, and ask them to fabricate a aluminum or steel replacement "shoe" for your tripod. Also have them drill a hole in the center so you can later insert the proper threaded screw that will mount to your camera. You may want to take your camera and get the proper threaded bolt first before you get the shoe made, so they can make the hole the correct size. You can go to any hardware or home improvement store and ask for assistance to find the right thread for you camera equipment. The bolt should not be any longer than1 inch, so it will mount tight on your plate.
** Note you want a flush mount type bolt that when tightened on the plate is smooth on the bottom** This is so when you mount the shoe in the head, it will be properly seated.
Aug 02, 2008 | Gemini Sound Products Jeva 60 Tripod
701RC2 going on 745B sticks
Hey SkipHall,
As in most Manfrotto tripods this tripod should have 3 set screws underneath the head mounting surface. Unscrew these set screws and you should be able to unscrew the current head off the tripod by holding the center column and turning the head counter clockwise. Installation of the new head should be the reverse. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Jun 16, 2008 | Manfrotto 745MF3 Tripod
Slik U 200 Tripod
17 th street Photo
Oct 27, 2007 | Slik U-212DX Tripod
Samsung Digimax S630 Digital Camera Logo
130 people viewed this question
Top Samsung Cameras Experts
Computer Links
Jerry Z
Are you a Samsung Camera Expert? Answer questions, earn points and help others
