Question about Polaroid iZone 300 Digital Camera
The battery loses its charge right away - Polaroid iZone 300 Digital Camera
My saturn sc1 lights and radio would flicker when pressing the brakes, sometimes it would shut off when pressing the brakes in reverse, now it will not turn completely over or hold a charge in the bat
corrosion on you battery terminal will create high resistance.inspect the battery connectors and wire. if you find white/blue crystals on you terminal disconnect and clean. the battery cable must be gold/light brown.If the wire are black/blue that mean is burn from bad(lose) connection to the terminal and need replacement.Inspect all ground connection betvin battery and body for corrosion or lose
Mar 23, 2014 | 1998 Saturn SC
My iPod is charging but when I take it out it loses charge right away and if this helps I have the 4 th generation
Dear imaranee,
Your iPod's battery is faulty. Take it to the nearest apple store and get it replaced. It won't cost you a penny if you still have a valid warranty (or if yo had previously purchased an apple care plan)
Oct 19, 2012 | Cell Phones
Battery loses charge when going up hill. Also hear clicking noise, but don't see anthing hitting the wheels. Is there a local authorized repair dealer near Williamsburg, VA, that could do a...
Hi, Something maybe touching the battery terminal and arcing is occuring. Check terminals again.
You may have to strap down the battery better. Good luck
Aug 12, 2011 | Pride Go-Go Elite Traveller Plus HD...
2005 rendezvous battery light came on do i need to replace it right away?
The battery light coming on means you have to check your charging system very soon, right away is good. It doesn't necessarily mean you need to replace your battery. Get both the battery and the alternator tested because the battery could be low if the alternator is not charging properly. Hope this helps.
Oct 21, 2009 | 2005 Buick Rendezvous
Battery drains quickly. Loses charge when plugged
Sounds like you need a battery. The key here is that the battery is losing charge while it is supposed to be charging. Works like a car battery, even if the alternator is working 100%, if the battery is pooched, the car won't start.
Sep 25, 2009 | Motorola Mobility Moto Q
My palm Treo wx will not sync with my computor. I have troulbe with it shutting off my plantronics T150 bluetooth.It continually needs to be rebooted. I have had this phone for 18 months. I have had...
the problems your experiencing are problems that every cell phone has...be patient and make sure your battery is charged well. after 18 months, I would just replace the battery. after time the batteries just lose full strength power.
your phone is like a mini computer and takes a good battery to run.
Replace the battery with a new OEM battery, charge it real good and see if your problems go away.
Jun 07, 2009 | Palm Treo 700wx Smartphone
2007 Corolla battery not keeping charge
There is an electrical problem. Get someone to scan the vehicle.
You might have to replace the alternator and the battery.
Sorry
rate this please
May 29, 2009 | 2007 Toyota Camry
Cameras Logo
62 people viewed this question
Top Polaroid Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
