Question about Whirlpool GEW9250 Electric Dryer
How can i make sure that the motor is bad on my le9480xwn0 whirlp
How can i make sure that the motor is bad on my le9480xwn0 dryer? the element is heating up, the drums turns by hand easily. i removed the front panel and drum so i can see the motor. i just want to make sure thats the problem before i get a new one. any suggestions?
  • C S Sep 28, 2009
    wow that was a fast response!! but, having removed the front panel and the drum to expose the motor(as stated in post), i think that i would have noticed the belt broken belt. anymore suggestions?
  • Whirlpool Master
  • 3,361 Answers
Sounds like a broken belt to me.
Posted on Sep 28, 2009
Testimonial: "thanks"
  • steve
    steve Sep 28, 2009
    If the heating element comes on the motor is turning to allow the centrifugal switch in the motor to send power to the heating element. If the heating element gets power and the motor is not running,the motor is defective.
Maytag dryer motor does not come on . replaced motor still does not come on. the electric element does come on.
Dennis498
This is very strange. Are you sure the heating element comes on?On most models I know of , motor has to be running for heater element to come on. Come to think of it your model has a centrifugal switch (attached to motor )it's probably bad .The heater probably thinks the motor is running.
Give that a try
Aug 05, 2011 | Maytag Dryers
The dry will not start the display or dig. Controls wont engage anything the start button keeps flashing was just working great
Bad Heating Element
Most clothing dryers heat up and dry clothes with a heating element inside the appliance's body. Maytag dryers are no different and sometimes these heating elements break down or burn out, making the dryer cease to get hot. Make sure the dryer is unplugged and the breakers that run the dryer are switched off before inspecting so you don't electrocute yourself. The heating element is in the bottom panel of the dryer and is often a silver part which heats up when the dryer is on. Sometimes the heating element will be cracked or burned out, which means it is broken. Other times it won't look damaged but may not be working. Replace the heating element if this occurs, to see if this is the main problem.
Broken Motor
Maytag dryers have motors which turn the dryer drum, tossing the clothes so that air and heat can help dry them out completely. When the dryer drum is not turning it means there is something wrong with the motor or that the motor is not getting power. Unplug the dryer and take it apart to inspect the motor. Once you have found the motor, plug the dryer back in and use a meter to see if the motor is getting power. If it is, and isn't working, then there is something wrong with the motor and how it is operating. If the motor isn't getting power, then there is something wrong with the circuits or fuses which disperse power to the motor itself.
Bad Switch
When Maytag dryers won't tumble or heat the clothes which have been put inside of them, this means there could be a number of different things wrong. However, sometimes there's a simple solution to this problem: The switch on the door of the dryer itself may be faulty or not making the electric connection it should to allow the dryer to run. This is a cheap fix and worth troubleshooting before tearing your Maytag dryer apart. Remove the switch and inspect the two leads to make sure they haven't broken or are still transferring electricity. If they aren't you will have to replace the switch
Mar 11, 2011 | Maytag Dryers
I have a may tag performa gas dryer. When I start it, it spins and heats but it spins very slow. I opened the top and checked the belt and it was tight and does not appear to be slipping. Is the motor...
  • There are a number of different problems which can occur with models of Maytag dryers resulting in them not heating and drying clothes properly. A variety of parts could have broken or been worn out over the course of the time you have been using your dryer or something could just malfunction, as appliances tend to do from time to time. Check warranty information before trying to repair the Maytag dryer yourself.
  • Bad Heating Element
  • Most clothing dryers heat up and dry clothes with a heating element inside the appliance's body. Maytag dryers are no different and sometimes these heating elements break down or burn out, making the dryer cease to get hot. Make sure the dryer is unplugged and the breakers that run the dryer are switched off before inspecting so you don't electrocute yourself. The heating element is in the bottom panel of the dryer and is often a silver part which heats up when the dryer is on. Sometimes the heating element will be cracked or burned out, which means it is broken. Other times it won't look damaged but may not be working. Replace the heating element if this occurs, to see if this is the main problem.
  • Broken Motor
  • Maytag dryers have motors which turn the dryer drum, tossing the clothes so that air and heat can help dry them out completely. When the dryer drum is not turning it means there is something wrong with the motor or that the motor is not getting power. Unplug the dryer and take it apart to inspect the motor. Once you have found the motor, plug the dryer back in and use a meter to see if the motor is getting power. If it is, and isn't working, then there is something wrong with the motor and how it is operating. If the motor isn't getting power, then there is something wrong with the circuits or fuses which disperse power to the motor itself.
  • Bad Switch
  • When Maytag dryers won't tumble or heat the clothes which have been put inside of them, this means there could be a number of different things wrong. However, sometimes there's a simple solution to this problem: The switch on the door of the dryer itself may be faulty or not making the electric connection it should to allow the dryer to run. This is a cheap fix and worth troubleshooting before tearing your Maytag dryer apart. Remove the switch and inspect the two leads to make sure they haven't broken or are still transferring electricity. If they aren't you will have to replace the switch.
  • please stay how helpful it
    Dec 21, 2010 | Dryers
    Dryer won't get hot it isn't the heating element
    check the thermostats located on the heater box,make sure you remove at least one of the wires when you read anything out.also if the t-stat is bad clean out the dryer,if the vent line is a long run from the back of the dryer to the outside hood i use a leaf blower to blow out the line,also clean the duct that the lint filter slides into and vac out the inside of dryer where the motor is,if you have a shop vac blow off the motor,it might look clean but alot of lint gets stuck inside the motor.let me know what you find,if the t-stats are good check to make sure your getting 110 volts to the heating element,could have a bad timer but most likely it will be the top t-stat on the heater box,also check the thermal fuse on the blower wheel housing
    Jun 20, 2010 | Kenmore 62802 Electric Dryer
    Heating element is getting too hot and shutting down dryer
    Disassemble the dryer again and check the blower wheel on the motor shaft. It may be slipping.
    Also,remove the rear exhaust vent and run a load. The blockage could be in the outside exhaust.
    May 25, 2010 | Maytag PYE2300AY Electric Dryer
    Heating element going bad. Even with setting on high and small loads the clothes take forever to dry. Can I replace the heating element myself?
    yes but make sure to unplug before you start but make sure lint is not the cause ck dryer hose cabinet motor blower wheel and discharge tube is lint free the element doesnt sound like the problem they just go inop may be it is limit switch short cycling but also make sure element housing is clear of lint
    Jan 26, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
    Wont heat up
    Generally either a bad thermostatic fuse or an open in the coil. I would suggest checking Here:http://www.repairclinic.com/ for issues related specifically to your make and model as well as repair/diagnosis advice and parts.
    Jan 22, 2010 | Dryers
    The dryer will not get hot.
    hello check all wire connections are tight then check heat sensors .all the best
    shaun
    Aug 04, 2009 | Dryers
    Indesit washer dryer, washer is fine, but dryer does not heat up
    If you don't hear the fan running then the fan motor has gone bad. If the fan motor is bad then most likely your element has burned out. If you hear the fan motor than probably your element has gone bad..
    Jul 29, 2009 | Splendide 2100 Vented Washer-Dryer
    Whirlpool GEW9250 Electric Dryer Logo
    75 people viewed this question
    Top Whirlpool Dryers Experts
    Dan Webster
    Dan Webster
    Tim Whalen
    Sal DeAngelo
    Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
