Question about Compaq Presario X6000 Notebook
Laptop wont stay on longer than approx 3 seconds. How do I check the switch?
  • Rahul Prashant Singh May 11, 2010
    Remove the Battery and try to run the laptop on the AC power. If the laptop still turns off automatically then restart the Computer and access the BIOS to check if the same issue occurs when the Computer is in BIOS setup screen. IF the issue persists in the BIOS also then disconnect the AC Adaptor and remove the Battery pack then press and hold the "POWER" button for 30 seconds. Now, connect the AC adaptor to the Computer with the Battery out then try to turn it ON. If the problem still exists then the issue is with the power supply unit. Good luck!!!!!!!!!!!!!!!!!!!!
  • 40 Answers
If the switch at least starts the laptop.. then it is not the switch
check that you can boot the pc with the battery pulled out of the laptop and the power supply plugged in...
if this works then you need a new battery
if this does not work.... then the motherboard or the power adapter plug maybe the issue.. is the plug on the side of the laptop solid... or sloppy fitting..
if solid then the motherboard cpu and memory are the suspected components next..
is there beep noises during boot for the three seconds that occur???
Posted on Sep 28, 2009
Laptop stays in standby and wont switch on
Remove main battery and press power, no change! sub out one stick of ram try again, repeat with the second one, Check to make sure the power adapter putting out the proper voltage, after this I recommend a professional to assess.
Apr 03, 2012 | Toshiba Computers & Internet
Gmp075-3 furnace wont stay lit
Sounds like an airflow issue. Is the return air clean? System is not tripping the limit switch with the door off because it's getting all the air it can handle, with door on its not getting enough air???
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Aug 15, 2017 | Goodman Heating & Cooling
How do I reset the change oil light on my 2001 silverado?
DID YOU TURN ON IGNITION SWITCH ON AND SLOWLY DEPRESS AND RELEASE THE ACCELERATOR PEDAL 3 TIMES WITHIN 5 SECONDS.IT WILL TAKE LONGER TO RESET DETERMINE HOW LONG YOU LET THE OIL LIGHT STAY ON.WHEN YOU TURN ON SWITCH 5 SECONDS DEPRESS AND AND RELEASE ACCELERATOR 3 TIMES.IF DONT RESET.TURN OFF SWITCH.THEN TURN BACK ON.YOU MAY HAVE TO DO IT SEVERAL TIMES.LET SWITCH REST SOME TRY AGAIN.IT WILL TAKE A WHILE.WHEN EVER CHANGE OIL SOON LIGHT COME ON RESET IT THEN AND CHANGE OIL.DRIVE IT ON A WEEK OR TWO TAKES LONGER TO RESET.
May 30, 2010 | 2000 Chevrolet Silverado
My ipod wont stay charged
This may not be the answer you are looking for but your I pod might not be fully charged, meaning that you are not plugging it in the computer/docking system long enough.( it takes much longer than 15 minutes to charge the battery. So you might want to plug it in/dock it over night) Or you may be playing a game that uses a lot of MB/GB so it kills the battery. And make sure that you press the play/pause button down for at least five seconds before switching the little switch at the top of your I pod. If you don't press the play/pause button for five seconds and just switch the switch at the top a little lock will appear on the left corner meaning you need to hold the play/pause button down for five seconds then the i pod screen goes black at that time flick the switch at the top off. -hope it helps owner of i pod nano and I pod touch.
Dec 30, 2009 | Apple Mini IPod
Teac AG v6200 wont stay on
Check your speaker wires, if they are crossed somewhere then the system protects it's self.
Jun 22, 2009 | Teac Audio Players & Recorders
PS3 wont boot the operating system, so wont stay switched on!
It doesn't happen to everyone, but just about.
The problem is most likely related to the GPU on the motherboard.
But let's find out for sure.
Try booting the PS3 with the hard drive removed.
Let me know what happens.
Jun 19, 2009 | Sony Playstation 3 (PS3) Console
My canon powershot a470 wont stay on i put new batteries in it and it still wont stay on for longer then a second
check your battery if it's an alkaline. you should use battery that doesn't contain mercury and shooting at night can cause short life on battery...
Mar 30, 2009 | Canon PowerShot A470 Digital Camera
My furnace wont come out of lock out mode
Pressure swithc stuck closed? try undoing on of the wire going to the pressure switch and see if it stays on longer. Make sure you tested all limit switches there are usually at least 3 and up to 5
Jan 10, 2009 | Cross Furnace Draft Inducer Blower 115...
LCD Screen problem
You have a failed inverter circuit. This is a very common fault with BenQ and other LCD monitors. I have seen more FP737 and FP731's and all their cousins in the last 2 years then I care to count.
You will be best to take it to a TV technician and have them do the repair. There are ways to fix it yourself, but the chances of success are not great without a decent amount of electronic knowledge.
Call several places and get approx quotes based on the inverter fault. A lot of TV techs will not work on LCD monitors and is another good reason to call around first.
One final thing, check the manufacture date on the back of the monitor, these normally come with a 3 year warranty and it will be either expired now, or very close to it. If it is still under warranty, then contact BenQ near you to facilitate the repairs.
BenQ support webpage.
Apr 15, 2008 | BenQ FP731 17" LCD Monitor
Compaq Presario X6000 Notebook Logo
76 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
