Question about HP Officejet Pro 8500 Wireless All-In-One InkJet Printer
Error Message: Pump Motor Stalled. Please advise
    Scholar:
  • 67 Answers
Try partial reset and semi full reset of the printer, this is error message is a hardware error, if the issue is still not resolved contact HP, they would replace the printer if it is under warranty.
Posted on Sep 28, 2009
I have an error message pump motor stalled on my Photosmart Printer 8200. Can you help?
On the left hand side (Facing the printer) behind side cover sits a micro pump for the ink. Pull cover and check that belt is OK from gear to micro pump. You should be able to just turn back and forth- not too much, the large pulley on the pump. There will be some friction here..... I think you can turn on machine OK with this cover off and see if pulley is turning
Jun 12, 2011 | HP Photosmart D7360 All-In-One InkJet...
I have a samsung washing machine, a error message came up on the screen. 3e. we were advised to contact our after sales. we did, we were told by a service eng; the mother board was dud can you please...
Switch off the power/reconnect and try again, try unplugging power cord for two minutes, if problem persist follow instructions at the end of user manual to call service
Jul 24, 2008 | Samsung Washing Machines
HP C7280 printer: "Pump motor stalled" error
This means there's a failure in your printer's pump motor.
If you are still under warranty, contact HP's Customer Service here : http://welcome.hp.com/country/us/en/wwcontact_us.html
If not, you can try your local computer store for a check-up but they'll probably suggest a new printer.
Hope this helped.
Please rate :)
Mar 04, 2011 | HP Photosmart C7280 Printer
Just Purchased A Hp Office Jet Pro 8500A. The printer says Pump Motor Stalled. What to do ?
You mentioned this is brand new printer purchased and gives "Pump motor Stalled" Error. Since this is new unit, my suggestion would be to contact HP Tech support regarding this issue as your printer is In-warranty and if needed, the printer will be replaced without any cost.
OR,
If you have purchased the printer from a store like bestbuy, Costso, Walmart etc. you can return the printer to them and get another one exchanged ( Check their return policy )
HP Contact # - 1800-474-6836
Before you contact HP or return the printer to store, you can try few things to check if it works as "Pump Motor Stalled" generally is Hardware Issue.
Open the Printer front access door.
Remove the Cartridges and Printheads ( Printhead is that holds the cartridges, loosen the latch to remove it )
Clean the contacts ( Electrical or Golden contacts ) using lint free cloth. ( Cloth damped with few drops of water, squeezed properly )
Put the Printhead and Cartridges back and Turn off the printer and turn on.
If should not display the error. If it does, it is your choice whether to take the printer to store and get exchanged or contact HP.
Regards,
Ron
* Please rate this solution with Thumbs up and Testimony to help us improve providing support
Jan 03, 2011 | HP Photosmart C6180 All-In-One InkJet...
Dishwasher showwing LE error message
Hi Tanja
LE is motor error.
Empty water from inside the machine and try tripping the circuit breaker for a couple of minutes.
If that does no clear the error , then one of the following faults may have ocurred:
Wiring connection broken either bad connector on pump side or on timer control side, or faulty wiring harness.
The hose connected to impeller, or the impeller itself is blocked.
Motor or pump locked.
Faulty timer board.
Aug 15, 2009 | LG Dishwashers
Pump motor stalled
My advice would be that if your printer is in warranty then call up HP Total care as u
will get a replacement if the issue is not fixed over the phone. But if the machine is Out
of warranty, then you can try the following:
Make sure the printer is connected directly to the wall socket(No Porwe Surge or anything).
1) Power Drain: Unplug the power cord from the back of the printer, then press & ho;d the
power key for 30 seconds, then release the key & plug in the power cable back.
Check if the problem is resolved.
If Not
2) Partial reset: Unplug the power cord from the back of the printer again. Press and hold
the # and 3 keys together and while holding them plug the power cord back in.
If Not
3) Semifull reset: Unplug the power cord from the back of the printer again. Press and hold
the # and 6 keys together and while holding them plug the power cord back in.
hope fully the problem will be fixed by this. Please let me know
Aug 04, 2009 | HP Photosmart C6180 All-In-One InkJet...
F01 error on playback or recording - Panasonic NV-DX100
Panasonic JVC Description
F01 No Take-up reel rotation
F02 E03 No Supply reel rotation
F03 E02 Mechanism has not unloaded to the eject position
F04 E01 Mechanism has not fully loaded to the stop position
F05 E04 Rotation of video head has stalled or to fast
E06 Tape drive motor is not rotating or stalled
F31 Data transmission error
F51 Focus motor is not functioning, No focus
F52 Zoom motor is not functioning, No Zoom
U10 Dew sensor has detected condensation or failed
U11 Video heads have been detected as dirty or failed
Matti Knuutila mattik1999@yahoo.com
Jul 11, 2009 | Panasonic Video Cameras
Message says carriage is stalled
Please Click Here and follow the instructions on the document to resolve this issue.
May 26, 2009 | HP DeskJet F380 All-In-One Printer
Camera error message
This suggests a stalled lens motor.
Check Kodak for repair costs
A new camera may be as cheap.
Dec 26, 2007 | Kodak EasyShare C330 Digital Camera
Will not run
I had the same problem with my machine, there is nothing you personally can do to fix it. You'll have to find a service tech who can work on it to solve the problem.
Dec 23, 2007 | White Sewing White 4400 Computerized...
HP Officejet Pro 8500 Wireless  All-In-One InkJet Printer Logo
1,945 people viewed this question
Seeker5211
Seeker5211
