Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
Lot of noise in last spin and lick water when spining
  • 61 Answers
Make sure tub top seal is snapped all the way around, if loose in spin cycle will through water over top
Posted on Sep 29, 2009
Why my fridigiere washer machine leaves a lot water after the last spine
check the following:
filter
drain level
abstracts in the water pump
if the pump doesn't receive volts, check Main board
Aug 25, 2017 | Washing Machines
Bosch 500 next ers washer has a bad grinding noise when spining it's getting very loud
Clothes load may be out of balance, try to rebalance load, may take multiple tries. My bet, it doesn't make this noise if just water in the tub and spin out. However, if it makes this noise with just water in the tub, you may need serviceman to look at it. How old is the machine? Service may cost more than a lightly used replacement.
Mar 04, 2015 | Bosch Washing Machines
Kenmore 80 series spin cycle isn't spining water out
could be defective part or lid switch problem
Dec 10, 2013 | Kenmore Washing Machines
Washing but not spining out clothes
Take the power plug off the wall. Be prepared for a lot of water before attempting the following. It doesn't spin because the unit is not draining water. It will not spin with water in it - must drain first. Check drain hose for kink,check exit pipe for blockage, then check pump. Could be your "coin trap assembly" is blocked, therefore not allowing all the water to pump out. Remove the front access panel, and remove the clamp that connects this trap assembly to the pump and clean it out.
If helped pl say so, thanks.
Apr 02, 2013 | Frigidaire GLTF2940F Front Load Washer
Washer makes straining noise when draining water from tub while spinning?
my admiral washer machine model AAV7000AWW makes a noise only when draining/spining water, is no water spill at all. Thanks
May 21, 2010 | Washing Machines
Spining makes noise and machine vibrates a lot
its a simple solution just remove the brown colour clamp at the bottom of the machine with a screw driver
Jun 03, 2009 | Whirlpool Washing Machines
Excess water in clothes after spin cycle
Unblock the outflow pipe from the machine that goes into the sump under the sink. (have a pot ready for water overflow) This will help drain the water. If the spin cycle is making a screetching sort of noise then it is possible that the carbon brushes will need changing. This affects the spinning if the brushes are worn.
Nov 05, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Pav2300aww spinning very slow,and not draining
In all these Cases it sounds like a faulty lip seal. These special seals have Sealed bearings inside. Water gets through the seal and into the bearing which causes it to thump (like a helicopter) or squeal very loudly. As far as draining, the machine has to reach a curtain speed before the pump can turn fast enough to work.
Nov 02, 2007 | Maytag Performa PAV2200
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
127 people viewed this question
Dan Webster
Dan Webster
Sal De
