Hi, just replaced the capacitor thinking that would solve the problem but it appears it did not. The motor outside would kick on the unit inside would kick on but the blower motor inside works sometimes and wont other times. Basically, the unit will work just fine all day then we notice the house is getting warm, check the inside unit and everything is running fine but the blower motor is not circulating the air. I have a goodman a30-10 unit. I read where some people said the relay could be bad but I have no idea where to locate it or if that is indeed the problem.
  • Chip Nall
    Chip Nall May 11, 2010
    You say that the inside unit is running. The inside unit should consist of a condensor coil and a blower. You should open the unit to see if the fan motor is running. Also make sure that the blower wheel is tight and not slipping. I have also seen the blower wheel come apart, but you should be hearing noises. Use a meter at thermostat and relay. Check for broken wires and fan relay or board if motor is not running. There is a fuse usually 3-5 amp on the board.
  • 3,361 Answers
Turn off the power to the air handler(indoor unit). Remove the access panel. From the motor,trace the wires back to the fan relay. One wire will probably trace back to the incoming power terminal. The other is the fan relay. It could be intermittent thermostat signal to the relay or a bad relay.
To verify if the fan motor is good,you can remove the one wire from the relay and re-attach it to the other side of the incoming power terminal. If it runs OK there,replace the relay. If it does not run,replace the blower motor.
Posted on Sep 28, 2009
My central air a/c unit motor will not kick in what should I check ?
outside unit motor or capacitor inside unit relay, motor or capacitor.
Jul 01, 2014 | Carrier Heating & Cooling
F6 error code on Frigidaire split unit ac, model FSC12CM6J/FSE12CM6J. Solution says to check fuse? Where is this located?
It seems like the indoor fan is not running. Quite a few split systems have a fuse on the indoor board. It will require stripping off the outer cover of the indoor unit and removal of the electronic box cover. The indoor board is in there. The fuse may be replaceable or it may be a type that is soldered on which makes it virtually non replaceable. ( A new indoor board will be required) Make sure all power is turned off or disconnected before you do anything. Another possibility is the fan motor start capacitor has failed. Try this first before stripping the unit. When the unit is turned on and the outdoor unit has started, give the indoor fan barrel a flick with your finger to start it spinning, if it keeps spinning and the error doesn't appear, it would indicate that the fan motor start capacitor has failed. The capacitors on indoor units are normally small black square boxes with 2 terminals on it. These capacitors are mounted inside or close to where the indoor electronic box is. Again, make sure all power is disconnected or turned off at the meter box before you do any disassembly.
Apr 09, 2014 | Frigidaire Heating & Cooling
Fan condenser unit wont run
This is usually a bad capacitor or bad fan motor. The capacitor is located inside the electrical panel on the outside unit. You can check these by using a meter that measures Mfds (Microfarads), most of the time you can visually see the capacitor swollen or blown. The fan motor can be checked by a meter that measures ohms, really high ohms are usually bad. If you can't spin the fan blade easily, then it's locked up. What usually happens, the capacitor or motor windings go bad, doesn't spin the fan blade, overheats the compressor so it kicks out on thermal protection till it cools back down, and sometimes the motor will overheat and go into thermal protection also. Just make sure you are getting the 220v to the outside unit too, but shut all power off before doing any trouble-shooting. Hope this helps, feel free to ask any questions!
Jun 30, 2012 | Heating & Cooling
We replaced the compacitor, when you turn the control on inside the outside unit clicks and starts to hum, you can hear the new comp running. The fan will not kick on. All of the wires are connected and...
You have to replace the capacitor whenever you replace a compressor. You may have a bad fan motor as well usually when capacitors go bad the motor isnt far behind. This unit will have a dual capacitor for the fan and the compressor and yes one side can go bad and the other side be good. Replace the capacitor and let me know
Jul 21, 2011 | Ruud UBHC Air Conditioner
Ruud ubhc-17j11sfd the outside unit wont come on for AC. I checked the breakers in the main breaker panel for the house. The fan inside works.
Hi!!
Did you check if the outside fan is working?? On the summer time the failure of condenser fan motors increases due to hi temps.
Have somebody turn unit on as usual while outside you check if condenser fan is turning and if the compressor kicks in. If the fan motor do not work, the compressor will shut of to prevent damage..
If either one of them tries to start but can't take off, replace starting capacitor, some units have separate capacitors and some have combo capacitors, they work the same.
If after replacing the capacitor the fan motor still don't want to start up, replace motor. If Compressor do not want to start, call a HVAC Technician to perform further testing.
Good Day!! Don't forget to rate this post!!
Aug 13, 2010 | Ruud UBHC Air Conditioner
Outside fan doesn't work. Inside it sounds like it works - there is a fan sound - but no cool air What part is broke?
If your compressor kicks on outside but the fan on top doesnt you need to ck the capacitor to the fan and the wiring to each. There is a schematic inside the elect panel on the outside unit it will give you an idea where the capacitor is it will be a silver or grey metal device with three wires coming out of it or you will have one small and one larger one with two wires coming out of each. the fan runs off a 5uf capacitor and the compressor a 35 uf capacitor. The most obviouse thing will be burnt or melted wires inside the elect panel when a capacitor goes bad it usually takes wiring with it. If wiring looks good buy a new motor and replace the capacitor at the same time. take the elect motor with you so it can be matched up.
Aug 08, 2010 | Ruud Matching Split Air Conditioner
Outside unit fan not turning no cold air inside.
Ok here we go. It is possible that the capacitor for that fan unit is out or the motor for that unit is out. Without the proper tools i.e. an electrical meter, there isn't really a way to test the unit. The remote should not have anything to do with the unit activating if the is a manual thermostat. I suggest checking to see if either the motor has gone bad or the capacitor has bit the dust. If you have the motor changed make sure to replace the capacitor
Good Luck on your repairs hope I helped you some\
Dave
Jan 08, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
My Goodman a/c unit will not turn on ..
You have a short circuit in the outside system. Either a bad compressor,bad fan motor or possibly a bad capacitor. Visually examine the capacitor. If it is bulged out anywhere,replace it. Check for burned wires on the capacitor and all other connections.
Remove the compressors wires from the circuit and restart the unit. If the fan runs the problem is in the compressor. If the fan does not run,the problem is with the fan motor.
Jul 20, 2009 | Goodman CKL42AR42 Air Conditioner
Outside fan does not kick on just buzzes
The buzzing noise sounds like the contactor is energizing and if it is then you need to check to see if you have power 230 volts to the outdoor unit, if not, check the fuses or breaker, if you do have power then you may have a broken or burnt wire inside the outdoor unit.
Apr 28, 2009 | Heating & Cooling
A/C quit running
This question is really to broad to answer. There are several things that could cause it to stop running. I think I would turn everything off, let it cool down for several hours and try it again. When you kick it back on, take note of what is running and what's not running. Inside fan, outside fan, compressor. If the outside unit will not run at all it could be as simple as a grasshopper caught in the contacts. If you hear the compressor running outside but no outside fan, The fan motor probably needs replaced. Please make sure that all power to the unit is TURNED OFF before removing cover plates on outside unit and before trying to remove insects from contact points. Check all wiring inside outside unit while it is open. Also check capacitors for swelling or leaking. If you don't know how to turn all the power off or open the outside unit, you need to call a professional AC technician. Hope this helps. kstfas
Aug 26, 2007 | Ruud UAKA037 Air Conditioner
Open Questions:
vulcan bonaire comfort control External natural gas electronic ignition 2004. ISSUE: Fan blowing only cool air continuously. Forced to kill power to stop it. model is one of the following. MB514E,20E or 30E. Going by mech drawing parts list. i can confirm what type of sensors i have cleaned with very fine sandpaper. flame sensor PN 5441603SP and IGNITER ELECTRODE PN 5441602SP The fault code i see is described as the following. There are x4 LED's. Sequence Left to Right. LEGEND: 1 Flame Sensor 2 Pressure switch 3 OverTemp 4 Diag. R Red G Green S Solid Colour B Blinking LED Behaviour. In order 2RS & 4GS Until i hear ignition. 2RS & 3RB Duration: split second 2RB,3RS & 4GB Duration: split second 3RS & 4GB Duration: Until it has completed blinking x4 times. 3RS Duration 4 seconds Repeat last two mentioned behaviour. in my own opinion, as a safety feature, the unit thinks that it has overheated or is about to. so kills the gas and force feeding cool air to heating components to save it from frying. Does this mean i have fault 04 if so does this mean i may have a faulty igniter or flame sensor or maybe a faulty as described in the mech drawing SWITCH OVER TEMPERATURE 120 degrees celsius. Am i correct here? Is this the over temperature cut out switch? if no one can really pinpoint which part requires replacement, can you at least, in sequence advise which parts to purchase? so then ill just try my luck. i wonder how to properly test if flame sensor, igniter, over temp etc is faulty with a multimeter. do i just perform a continuity test. I wonder what other parts can i test related to this fault im getting.
Jul 22, 2018 | Vulcan Heating & Cooling
Heating & Cooling Logo
256 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
