Question about GE WBSR3140DW Top Load Washer
Water is leaking from underneath machine. Washer is less than 2 years old.
  • 61 Answers
Make sure the tub seal is snapped all the way around the top of the tub if it is good replace pump
Posted on Sep 29, 2009
Fridgidaire fex831fs1 washer/dryer stack unit: how is washer timer function knob removed from timer shaft ?
i have a frigidare washer dryer combo model fex831fs approximately 6 mo old . turned on a load and water gushing out from underneath, checked hot and cold hoses not leaking, water coming from underneath
Mar 03, 2010 | Frigidaire FEX831CS Top Load Stacked...
My Maytag washer model #:sav515deww is leaking underneath during the spin cycle. I took off the 2 front panels. I saw the water leaking from a large metal part that spins around. Its behind the motor and...
My Maytag washer model #:sav515deww is leaking underneath during the spin cycle. I took off the 2 front panels. I have been told taht it is a bearing and a seal that are out. Replacement parts cost approx $90.00. Unit is 5 years old. Is it hard to fix? Thanks
Dec 10, 2009 | Maytag SAV515DE Top Load Washer
I also have a front loader that is less than 4 years old and is leaking. Checked filter - nothing blocking.
things that cause leaks / does it leak when you arn't using it . ( ck the fill hoses ) run a cycle with the front panel off and look with light for leakage . the hoses underneath /the front rubber boot / pump hoses ( connections ) and note where water first show. . and get back with me. you have to be a good detective with some cases.. mm
Dec 05, 2009 | Kenmore 43042 Front Load Washer
Bunn coffee maker leaking from underneath the bottom
Please get the model and the date code from the bottom of the machine and contact customer serivce. Depending on the date code, there might be a seal kit available or the machine can be replaced at no cost if 3 years old or less. If it is over 3 years old and the seal kit isn't available, the machine will be replaced at a reduced price.
Apr 29, 2009 | Bunn 10 Cup Home Coffee Brewer
Washer leaking when filling up tub
Unlikely to be pump, sounds more like hose leaking, or drum seal.
Depending upon severity of leak, place a sheet of newspaper under front of m/c, pushing it as far back as you can. switch m/c on for a few secs, then switch off, remove paper and you should be able to judge where leak is.
Tilt m/c back and have a look underneath.
At 12 years old, if it looks major, I think I would replace m/c.
Plz rate my solution.
Thanks.
Dec 31, 2008 | Maytag Dependable Care LAT9206
Washer leaks from underneath
It's still under warranty. Call frigidaire and find out who the closest servicer is. Or check this out: http://www.frigidaire.com/support/service_locator.asp
Oct 06, 2008 | Frigidaire Affinity ATF7000E Front Load...
Fisher and Paykel Washer leaking water
hi there,
the leak underneath could be from the pump or the drain hose. some washers have a tub to pump boot that sometimes springs a leak.
for a 4-month-old washer, i would certainly hope you pay nothing. F&P appliances come with at least a 2 year warranty. check your user & care guide for warranty information.
Oct 03, 2008 | Washing Machines
Ammana washer less than 5 years old making loud noise and leaking water from bottom of washer
it sounds like the tub seal is going bad and leaking on the bearings,not good,you can remove the top with a putty knife into the front seam one clip on each side(make sure no screws on bottom front,you can now check everthing out to see what you find,let me know -mike
Sep 26, 2008 | Whirlpool Washing Machines
Whirlpool Cabrio Leaks Water
Good luck. Mine did the same and they sent their technicians out to fix the problem. A&E comes out and replaces the tub ring. They told me the washer is now made with the tub ring in place. When he opened the washer up I noticed I now have rust inside my washer. I have spent a month trying to get Whirlpool to replace my washer but they will only replace parts. A&E came out to replace the tub ring and now my door creaks and my washer does not go back together correctly. Hopefully you can justreturn the washer to where you got it. Read other reviews on line. It sounds like this washer is a lemon. Sorry!
Aug 28, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
GE WBSR3140DW Top Load Washer Logo
79 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
