Question about Husqvarna 23 Hp 48" Deck Yard Tractor
I need a mikuni fuel pump for the fh 531 v kawa engine. It works off pulsed vacuum from the engine. Any one know where to get parts for this engine at a good price...its on a Husky yth 1848 xp mower ????
  • 148 Answers
Use the Briggs & Stratton Fuel pump instead. The Briggs part number is 808656. It's more easily available, and the same or lower in price than the Kawasaki part number 49040-7001. Roughly $30.00.
Mikuni makes them both and they are identical.
Hope this helps.
Posted on Sep 29, 2009
  • 169 Answers
Use the honda fuel pump number 16700-z0j-003 it is the same as the briggs and is about 10 dollars cheaper we stock them at 22.50 at our shop
Posted on Nov 21, 2009
  • 389 Answers
Briggs & Stratton part number 808656 is $34.50 from Sears Parts Direct
Posted on Oct 30, 2009
What is the symptoms of a fuel pump going out on a husqkavarna riding lawn mower
With fuel tank low engine will be hard to start and run. With full fuel tank will operate near normal. Before anything else check the tiny hole in the fuel cap. It loves to plug resulting in a vacuum in the tank eventually staling the engine no gas.
Listen for air sound when opening fuel cap!
Check/replace fuel filter.
Check pump.
Pump runs on vacuum pulses from engine.
Hope this helps?
Jun 29, 2017 | Garden
No gas coming to carb fuel filter good engine runs while sraying gas in carb
Onan engine? If so, check your fuel pump. It will be located on the engine cowling. You'll see 2 fuel lines, one on top and one on bottom. These are the fuel in/out lines. The line you WON'T see is the vacuum pulse line that hooks to the rear of the pump assembly behind the cowling. This line operates the pump via a vacuum pulse created by the engine.
You can remove the pump mounting screws and the pump will pull away from the cowling a short distance exposing the vacuum pulse line. Make sure it's attached and not dry rotted. If the engine has set up for any extended period, there's a good chance the pump gaskets are "glued" to the pump chambers (internally) by bad gas and not allowing the vacuum to pump the fuel. Onan has (when I was working on them) kits for these fuel pumps and I've installed them successfully, but it might prove to be somewhat tedious if you're not well versed in kits of this sort or not extremely mechanically inclined. But if memory serves, a new pump was priced within reason. Good luck.
Feb 16, 2015 | Bobcat Miller 225 Welder Generator 907209...
TROUBLESHOOTING FUEL PROBLEMS
carbs clean and checked the fuel pump diaphrams not gone hard etc ?? tank and fuel clean and fuel getting to carbs ?? pulse pipes on intake manifold to pump clear and if you crank engine you feel a pulse of air ? plugs sparking ? i would fit a fuel primer bulb inline of feed to carbs and prime fuel and see if helps and as engine running see if priming keeps it running then i would check pump !!
Aug 25, 2014 | WSM 2002-2005 Kawasaki Stx-r 1200 Cc Jet...
Fuel pump carbs bike
Hi, Anonymous for this situation I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry. If necessary, transport your bike to the dealer or shop and have a professional technician take it for a test drive, if it is in running condition, and give you a written estimate of repairs and answer any specific questions you may have about your problem. For more information about your issue and free downloads that you will need please visit the websites below. Good luck and have a nice day.
Mikuni Pulse Fuel Pump
RIVER 600 1995
http://www.oemmotorparts.com/oem2.asp?M=Cagiva
http://www.cagiva.nl/media/owner_manuals/?tx_motomondo_pi4%5Bmodel%5D=&tx_motomondo_pi4%5Byear%5D=-1&tx_motomondo_pi4%5Bmanual%5D=
Cagiva Mito beginer Guide Useful links
Aug 14, 2013 | 1998 Cagiva River 500
Where is the vacuum hose attached on a J.D. GX-345
This type of pump takes a pulse from the engine as the piston rises and falls, this is fed to a diaphram in the pump which then pulsates and pumps the fuel, if there is a loose or cracked pipe it will not work, if the diaphram is split or has hardened you will need to replace the pump as it is not sevicable.
Jul 25, 2013 | Garden
Does the gas tank need to be high on the motor or can it **** from a lower source?
Your water pump is gravity feed type, however you can add a vacuum/pressure pulse type pump. Look here : http://www.motorcycle-superstore.com/4/22/423/22375/ITEM/Mikuni-Pulse-Fuel-Pump.aspx
This is just an example, there are many styles and capacities of pulse pump. Look on ebay. You will need to be creative and find an way to tap into the crankcase system. Some engines that use pulse pump will get vacuum / pressure from the valve cover area. The pump works with the natural pressure / vacuum created in the crankcase by piston movement. Good luck
Oct 07, 2010 | Briggs and Stratton 073001 2" Portable Gas...
Where is the fuel filter on the kawasaki ZX-6R, I need to check it and clean or replace it
look for the canister attached to the fuel pum, bottom side of the tank.
http://www.motorcycle-superstore.com/productimages/OG/0000-Mikuni-Pulse-Fuel-Pump.jpg
Apr 12, 2010 | 2006 kawasaki ZX-6R
Carburetor identification!
try a motorcycle salvage yard-they know bikes or see your local dealer and talk to a tech kawa motor corp has an 800
Nov 22, 2009 | 1990 kawasaki ZZR 600
No pulse at ejectors
Are you getting spark at the plugs? if not your not getting a pulse from the computer and you will need to know if it has a crank and cam sensor, 1990 and 1991 have two different systems, so we would need to know engine size and transmission type to help you more.
Jun 13, 2009 | 1990 Chevrolet C1500
Husqvarna 23 Hp 48" Deck Yard Tractor Logo
502 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
