Question about Nokia 6220 classic Smartphone
Phone will not charge at all have charged battery in another phoneso not battery or charger phone is a nokia 6220 classic
  • 80 Answers
Well, if you are saying that the phone is not charging the battery you put in it except you put the battery in another phone then will it charge,
1, Maybe you could check if the charger itself is bad.
2, Charger socket on the phone is faulty.
3, See if there is something like dust on the inside of the charging pot, then you forcefully blow breeze into it.
4, Finally, if non of these works, it means you need to go to a repairer to change the charging pot.
Posted on Feb 04, 2010
Not charging
Dear:
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Jan 15, 2013 | Nokia 6220 classic Smartphone
How to solve battery charge draining problem for nokia 2700 classic
First thing to check is the battery,if you can try and test another one,you can conclude weather the phone or the battery is the problem,also try to check the charger you are using,might the current is not sufficient giving the battery a charge.
If this 2 methods does not work and still give you a headache, bring the phone to a mobile service shop to diagnose the phone problem,might need to change some components such us charging IC,capacitors or resistors.
Sep 15, 2011 | Nokia Classic 2700 Cell Phone
My nokia 6500classic is not charging
As you said in the question your mobile is not charging.
*Your charging socket as problem.
*You need to change that socket.
*You can visit to your nearest service center for repair.
*They will take few minutes for this.
You can also charge your mobile by using battery charger.There you should remove battery from the phone and then you should charge the battery.
Thanks for your question.
Jun 20, 2011 | Nokia 6500 Classic Cellular Phone
My nokia 6220 classic was ok when i was going to sleep but at Morning its not switching on and not taking charge. When i connect my phone with charger it is becoming little hot and showing no charging...
there must be some problem in battery charging.change the battery and charge it.this will mostly helpful to you.if same problem exist means.then check the charging pin in your charger and in mobile too.if so try to change the charging pin of your mobile.
Dec 27, 2010 | Cell Phones
After charging 6220 classic screen now just backlight and no start up at all
It may be that the phone fell on a hard surface, I have witnessed this before and its a little common with some nokia phones or maybe the current was a little higher that it should be. So maybe you could just keep the phone off for a while like some 20 mins to cool then put back on. If it doesn't, hit it on your pam softly or a little harder. I hope this puts smiles on your face.
Jan 10, 2010 | Nokia 6220 classic Smartphone
My nokia 6220 wont start. When holding down the "on" button it just vibrate a little and the screen lights up a little bit, then it goes back to completely black again
The battery cell may be completely dead and you need to replace the battery. Because its going completely black again means its actually completely of. So try and change the battery, but make sure you charge it till its completely full before usage. Hope that puts a smile on your face.
Oct 13, 2009 | Nokia 6220 classic Smartphone
Cannot power up a nokia 3110 classic. full charged battery
nokia 3110 classic.on the time of update software USB Data cable have been disconnected. and that time mobile was automatically off And after its not starts.
Please solve my problem.
Oct 03, 2009 | Nokia 3110 Cellular Phone
Charging
Then there is a problem in the charger socket. Try a different charger from a friend to eliminate the charger. Does your charger work elsewhere?
Aug 14, 2009 | Nokia 6120 classic Cellular Phone
Hi .my nokia 6220 switches itself off after the battery has been fully charged .once its switched on again it works okay
It may be due to power surge happening when you remove your charger from phone.
1.Try changing your power adapter
2. Switch off the power adapter first before removing the charger connection from your phone.
3. Remove the battery and clean the copper terminals with a cloth
4. If none of these idea works, then give a try my restoring your mobile to factory settings.
Aug 09, 2009 | Nokia 6220 Cellular Phone
Will not retain charge for more than 6 hours. Has new battery and new charger
The charging port on the INSIDE of your phone is probably loose. It shouldn't cost more than 150 to fix, otherwise, hope you have insurance because it's not covered under manufacturer warrenty.
May 06, 2009 | Nokia 6120 classic Cellular Phone
Nokia 6220 classic Smartphone Logo
198 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
