Question about Dell 924 All-in-One InkJet Printer
Tabs on the color cartridge carrier have broken so it will not stay closed. Looking for replacement parts for the carrier.
2 Suggested Answers
SOURCE: Dell Photo All-in-One Printer 944 cartridge carrier malfunction
944 cartridge missing. Faulty cartridge. try a couple of the old cartridges that were low on ink and the printer should work
Posted on Oct 12, 2009
How do i install mt inks
Please follow the steps below on how to install/replace ink cartridges on your model:
  1. Make sure the All-In-One is on.
  2. Lift the scanner unit until the scanner support keeps it open. The print cartridge carrier moves and stops at the loading position unless the All-In-One is busy.
  3. Grasp the tabs on the cartridge lids, and then lift the lids.
  4. Remove the old cartridges. Store them in an air-tight container or dispose of them.
  5. If you are installing new cartridges, remove the stickers and transparent tape from the bottom of the cartridges.
  6. Insert the new cartridges. Make sure the black print cartridge is secure in the right carrier and the color cartridge is secure in the left carrier, and then snap the lids closed.
  7. Lift the scanner unit and push the scanner support back while lowering the scanner unit until it is completely closed.
Sometimes the ink cartridge carrier won't automatically move to its loading position even when the printer is on and the cover is open. Follow the steps below:
1. Unplug the printer from the power source.
2. With the cover open, hold the solid white strip that connects from the carrier assembly to the ink cartridge carrier and gently slide the cartridge carrier to the center of the printer.
3. Remove the used cartridges.
4. Load the new cartridges. Close the cover.
5. Plug the printer back to the power source.
Aug 30, 2011 | Lexmark X1270 All-In-One InkJet Printer
I have the Dell AIO 926 and i have an Error Message. Error 1203 Consult User's Guide I cannot print, what do i do?
error 1203's error name is print head short which indicates a short circuit in the print head has occurred. solution to this problem is to disconnect and then reconnect the printer power cable. Reinstall the ink cartridges.For more information, see Replacing Ink Cartridges.
  • Turn on your printer.
  • Lift the printer unit, and then position the scanner support between the tabs to hold it open.
  • The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
  • Press down on the ink cartridge lever to raise each ink cartridge lid.
    Remove the old ink cartridges.
  • Store the cartridges in an air-tight container, such as the storage unit you received with your photo cartridge, or dispose of them properly.
  • If you are installing new ink cartridges, remove the sticker and transparent tape from the back and bottom of each ink cartridge.
    NOTE: The following illustration shows a black cartridge and a color cartridge (used for normal printing). For photo printing, use a photo cartridge and a color cartridge.
    Insert the new ink cartridges. Make sure the black or photo ink cartridge is secure in the left ink cartridge carrier, and the color ink cartridge is secure in the right ink cartridge carrier.
    Snap each lid closed.
    Hold the printer unit up, push the scanner support back to unlock it, and then lower the printer unit until it is completely closed.
  • Jun 05, 2011 | Office Equipment & Supplies
    Lexmark 7600 printer cover is not seating properly after installing printer cartridge
    The two hinges are attached to the back of the printer by two screws. I removed the two screws and lifted the top off, freeing the two hinges (the one on the right was broken so part of it stayed in the printer). There is a restraining line on the right side that keeps the top from coming completely free of the printer, but it can be worked around while still attached. I removed the broken pieces and the internal spring from the right side hing. The spring is what was keeping the top from seating correctly. I assume you could order a new hing, but I reassembled the printer without the spring and the top seated properly. The printer works, but I will now need to be very careful when replacing the ink cartridges because of the missing hing on the right side.
    May 10, 2011 | Lexmark International Lexmark 7600 Series
    How do I install the printer cartrige? I do not have the booklet...
    1. Turn on your printer.
    2. Open the front cover.
    1. Press the tabs on the cartridge lids, then lift the lids.
    1. Remove the old ink cartridges.
    1. Store the cartridges in an air-tight container or dispose of them properly.
    2. If you are installing new ink cartridges, remove the sticker and transparent tape from the back and bottom of each ink cartridge.
    NOTE: You can use your printer with one cartridge (color or black) at a time. To extend the life of your color cartridge and improve printing speed, install both a color cartridge and a black cartridge at the same time.
    1. Insert the new ink cartridges. Make sure the color ink cartridge is secure in the left ink cartridge carrier and the black ink cartridge is secure in the right ink cartridge carrier.
    1. Snap each lid closed.
    1. Close the front cover. The front cover must be closed to start a print job.
    1. Open the Dell Printer Solution Center by clicking Start® Programs or All Programs® Dell Printers® Dell Photo Printer 720® Dell Printer Solution Center.
    2. Click the Maintenance tab.
    3. Click Install a new print cartridge.
    4. Click Next.
    5. Select the type of cartridge you installed.
    NOTE: Specify whether the cartridge is a new cartridge or an old cartridge (one that has been used before). If an old cartridge is incorrectly identified as New Cartridge in the Dell Printer Solution Center, ink levels may be incorrect.
    1. Click Next.
    Dec 17, 2010 | Dell Inkjet 720 Printer
    How to replace ink cartridge
    1 Make sure the All-In-One is on. 2 Lift the scanner unit until the scanner support keeps it open. The print cartridge carrier moves and stops at the loading position unless the All-In-One is busy. 3 Grasp the tabs on the cartridge lids, and then lift the lids. 4 Remove the old cartridges. Store them in an air-tight container or dispose of them. 5 If you are installing new cartridges, remove the stickers and transparent tape from the bottom of the cartridges. 6 Insert the new cartridges. Make sure the black print cartridge is secure in the right carrier and the color cartridge is secure in the left carrier, and then snap the lids closed. 7 Lift the scanner unit and push the scanner support back while lowering the scanner unit until it is completely closed.
    Sometimes the ink cartridge carrier won't automatically move to its loading position even when the printer is on and the cover is open. Just unplug the printer from the power source. With the cover open, hold the solid white strip and gently slide the cartridge carrier to the center of the printer. Remove the used cartridges. Load the new cartridges. Close the cover. Plug the printer back to power source.
    Dec 02, 2010 | Lexmark X1270 All-In-One InkJet Printer
    Lexmark X1150 - how do I change ink cartridge
    Make sure the printer is on. Lift the scanner unit to access the cartridge area. The cartridge carrier will automatically move to the center at the loading position. Squeeze the tabs on the cartridge lids, and then lift the lids. Remove the used cartridges. (refer to sample image below. printer shown may not look like your printer, however, the steps are the same.)
    Insert new cartridges. Color cartridge should be in the left carrier and the black in the right carrier. Snap the lid closed. Lift the scanner unit and push the scanner support back while lowering the scanner unit until it is completely closed.
    Sometimes the ink cartridge carrier won't position automatically to the middle even when the printer is on and the cover is open. Just unplug the printer from the power source. With the cover open, hold the solid white strip and gently slide the carrier to the middle of the printer. Load the cartridges. Close the cover. Plug the printer back to power source.
    Thanks.
    Nov 18, 2010 | Lexmark C533DN InkJet Printer
    Where do tou install ink
    From the Manual:
    1 Make sure the printer is on.
    2 Lift the printer (scanner unit) until the scanner support keeps it open. The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
    3 Squeeze the tabs on the cartridge lids, and then lift the lids.
    5 If you are installing new cartridges, remove the stickers and tape from the bottom of the cartridges.
    NOTICE: Do not touch the gold contact area on the cartridges.
    6 Insert the new cartridges. Make sure the color ink cartridge is secure in the left carrier
    and the black cartridge is secure in the right carrier, and then snap the lids closed.
    7 Lift the printer (scanner unit) and push the scanner support back while lowering the printer (scanner unit) until it is closed.
    Sep 18, 2010 | Dell A920 InkJet Printer
    How to open printer to change cartridge?
    In order to replace the cartriage, please follow the steps below:
    1 Keep the printer on.
    busy.
    the cartridges.
    Sep 15, 2010 | Dell A920 InkJet Printer
    Where do I put the replacement cartridges?? I can't see where it goes on this printer???
    here is your answer this was found here in your manual if you need it heres a link with picture instructions. start on page 15
    MANUAL:
    Open the printer, and then press down on the print cartridge carrier levers.
    Open the color cartridge foil, and then remove the cartridge from the pack.
    Remove the tape from the color print cartridge, insert the cartridge in the right carrier, and then close the color
    cartridge lid.
    If a black print cartridge is included in the box contents, open the black cartridge foil, and then remove the
    Note: You may need to purchase a black print cartridge separately.
    14 Remove the tape from the black print cartridge, insert the cartridge in the left cartridge carrier, and then close
    the cartridge carrier lid.
    Close the printer, and then load plain paper
    Mar 26, 2010 | Lexmark X4650 InkJet Printer
    Replace ink cartridge
    The print cartridge carrier moves and stops at the loading position.
    5 Remove the stickers and transparent tape from the bottom of the cartridges.
    6 Insert the new cartridge. Make sure the color print cartridge is
    secure in the left carrier and then snap the lid closed.
    If you are installing a black print cartridge, make sure that it is
    secure in the right carrier, and then snap the lid closed.
    Mar 02, 2008 | Lexmark X1150 All-In-One InkJet Printer
    Dell 924 All-in-One InkJet Printer Logo
    26 people viewed this question
    Top Dell Office Equipment & Supplies Experts
    jasbo
    jasbo
    Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
