While watching TV, the picture started to shrink in size until it disappreared, leaving a black screen and a beeping noise. power button does not work. Unplugged TV for several hours and when I plugged it back in, no picture and just a beeping noise.
  • 5 more comments
  • jazzercop Sep 29, 2009
    This is the information I found on the back of the TV... the TV is a GE Model# 46gw945, Chassis# PTK195AA, Serial# 813444001, March 1998. Yes... The picture pulled in like a box!
    not sure if you got my repley? If you did, please disregard this message!
    This is what I found on the back of my TV, it's a GE Model# 46GW945, Serial# 813444001, Chassis# PTK195AAA, March 1998
    YOU ROCK!!!! Thank you so much!! money is tight right now and replacing the TV is just not an option!! Is it hard to replace the parts? can I do it myself or do you recommed I find someone who knows what they are doing?
    Thank you so much for your help! Could this problem be related to the Hori output tasistor and the 5 pin startup transfomer?
  • jazzercop Oct 01, 2009
    yes they do!
    Thank you again!! I will open up the TV and see if there is a leak!
  • jazzercop Oct 02, 2009
    The solution was very helpful and totally accurate!! Thank you for all your amazing help!!
  • 5,138 Answers
In order for me to help you ,I need your brand name and model number it will be on back of TV and what Yr.? Also did tv begin to pull in on sides and top/ bottom like a square box?
Posted on Sep 29, 2009
  • 1 more comment
  • ladywinn
    ladywinn Sep 29, 2009
    Dead with Beeping sound , Shorted hori out put transistor Q14401 and replace Transfomer T14401 , Small 5 pin startup transfomer this should fix TV! Also these set are well known for Bad FBT flyback Transfomers #239111 Call Mats for Parts 1-800-628-1118 They list #239111-R for only 13.95 if you plan on keeping this TV For Furture use order one now at that price they retail at 89.00 original FBT listed for 39.95 You can go to their website at www.matelectronics.com Tell them to send you a catolog in the mail they have alot of different parts and supplys.If you need anymore help just let me know I will be more then Glad to assist you and Thank You for trying FixYa.
  • ladywinn
    If you can solder you can Do it! If not do you have a friend who knows How? First Replace hori out put and resolder 5pins on startup transfomer see if maybe thats all you need If TV does not work after replacing hori ooutput then you will need the staup transfomer. I know real well about how tight money is right now and its hard to get by. I belive God gave everyone a gift and its up to you to use it to help others if you are able! I am very Bless to be able to help others who really do appreiate the help. My granny always said that I was just to kind Hearted . Let know if you should need anymore help. Thank You for trying FixYa.
  • ladywinn
    ladywinn Sep 30, 2009
    Just to let you know I have over 28 Pages on Anything to everything that does go wrong with these sets , I want you to pull out The whole Light Box OUT, it just slides out after unbolting screws, Look to make sur you DO NOT have any coolant fliud leaking on chassis its mostly the Blue Tube that does this.
    President:
  • 1,653 Answers
Otherwise known as progressive frame collapse. This is usually caused by either the frame amplifier going progressively bad, generally due to age and overheating, or the frame power supply going bad and eventually being so bad that no picture frame can be generated. Alternatively this could be a problem with the main internal power supply as many drive voltages are derived from one line and then stepped down to derive others so if 1 goes bad then several others can go bad which can result in progressive system collapse and the frame collapse picture fade etc.
Best call in a service engineer. This should be a relatively straightforward and relatively low cost repair depending on the model that you have and its age / condition etc.
  • Karl Wright
    Karl Wright Sep 29, 2009
    Whilst the parts are not that expensive I would recommend that you find a friendly TV engineer to do the work as they can be very dangerous items to work on with voltages reaching several thousnad Volts - and that hurst or can kill.
  • Karl Wright
    Its possible? Do they look burned at all?
How do i make picture fit screen? top and bottom of picture is missing
Some receivers have the ability to do this for you, for instance, all ViP and Hopper receivers from DISH can stretch or shrink the screen to fit. Most HDTvs also have this feature, independent of the type of input, using your TV remote find the button that says something along the lines of screen size, picture fit, stretch, aspect, etc. While watching a program that looks unlike the way you want it to, tap the button until the picture changes to the style you most prefer.
Mar 02, 2015 | Evesham Televison & Video
Toshiba CF32H40 32"TV shrinking picture with solid black on bottom. What causes this and can it be fixed?
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Aug 30, 2014 | Toshiba CF32H40 32" TV
Picture is only in middle of screen, top and bottom of screen is blacked out
If you are watching widescreen format movie or tv programming on a non-widescreen tv, that is how it will appear. The widescreen is a wider picture so to show it on a less wide screen, it has to shrink down to fit. and leave blank space top and botton.
If not, sorry.
Sep 12, 2009 | Toshiba 36A40 36" TV
PLTV-32- Picture on screen is larger than TV screen.
if you have HD cable try shrinking the picture there. LCD's are not subject to 'bloom' like
analog tvs. try the aspect button on the remote.
wrong picture size on a digital tv is a result of the input signal.
Apr 05, 2009 | Protron PLTV-32 Television
Hi - After using a projector recently, all websites that I pull up on my HP laptop (in either firefox or IE) are very big and I can't see the left or right edges. I've checked properties on my desktop and...
try doing this. Start firefox. hold down the Ctrl button. Press "-" (minus) twice and watch the screen. If it shrinks do it again dont let off the Ctrl button. Keep hitting '-' (twice) until it shrinks to a size you like.
Jan 28, 2009 | Dell Dimension 2400 PC Desktop
Viewing mode will only go from zoom to wide!!!! please help
Hi!
Found some relevant info on how to adjust your video settings... You might want to give it a try!
Thanks! =)
4.12 PC Input Picture Adjustment
The Picture Adjust menu operates in the same
way for the PC Input as for the DTV / TV input in
section 4.2 for Backlight, Contrast, Brightness and
Color Temperature.
4.12.1 Auto Adjust
When the MENU button is pressed, the On Screen
Display (OSD) appears on the PICTURE ADJUST
page. Press the button to highlight the Auto
Adjust selection.
Press the button for the LCD HDTV to adjust to
the PC signal timing automatically.
4.12.2 H-SIZE
Press the button to highlight the H-Size selection.
Press the button to start adjusting the horizontal size of the picture. Use the or button to adjust
the horizontal size.
4.12.3 Horizontal Shift
Press the button to highlight the Horizontal Shift selection.
Press the button to start adjusting the horizontal position of the picture. Use the or button to
adjust the horizontal position.
4.12.4 Vertical Shift
Press the button to highlight the Vertical Shift selection.
Press the button to start adjusting the vertical position of the picture. Use the or button to adjust
the vertical position.
4.12.5 Fine Tune
Press the button to highlight the Fine Tune selection.
Press the button to start tuning the to the PC signal. Use the or button to adjust the tuning
4.14.1 Understanding Viewing Features
Your LCD HDTV features four viewing modes and Picture-In-Picture (PIP)/Picture-by-Picture (POP) mode.
You can switch viewing modes using the remote control.
4.14.2 Viewing Modes
Normal Mode
The original 4:3 aspect ratio (1.33:1 source) is preserved, so black bars are
added to the left and right of the display image. Standard TV broadcasts are
displayed with a 4:3 Aspect Ratio. Movies in 4:3 Aspect Ratio may be referred
to as pan-and-scan or full frame. These movies were originally filmed in 16:9
(widescreen), and then modified to fit a traditional TV screen (4:3).
Wide Mode
When watching a standard broadcast or full-frame movie in this mode,
the display image is stretched proportionately to fill the TV screen.
When watching a widescreen (1.78:1 source) program or movie, the
display image fills the TV screen. If you are watching a widescreen
(1.85:1 or 2.35:1 source) program or movie, there will still be black
bars at the top and bottom.
Zoom Mode
When watching a widescreen (1.78:1, 1.85:1, or 2.35:1 source)
program or movie, the display image is zoomed proportionally to fill the
width of the screen. The top and bottom are cut off to remove most of
the source material’s black bars. This mode is good for programs or
movies with sub-titles.
Panoramic Mode
When watching a standard broadcast or full frame movie in this mode,
the 4:3 Aspect Ratio (1.33:1 source) display image is stretched
horizontally on the left and right sides to fill the TV screen. The center
of the image is not stretched.
Note: Viewing modes are saved based on input. For example, you lasted watched a DVD in widescreen
mode and then watched TV in standard mode. When you switch back to DVD input, the viewing mode
will return to widescreen.
Jan 04, 2009 | Televison & Video
GE 31
check electrolitc capacitors in horizontal circuit
May 09, 2008 | GE 31GT659 31" TV
Picture size is shrinking within screen
hi there, you have vertical section prob., repalce imeditely the electrolytic capacitor at the vertical section. do some test and check up. ty
Feb 18, 2008 | Philips 27MT3305 27" TV
Shrinking screen.
hi there, you do have a vertical section problem and at the power supply section problem. do some test, check for some cold solder at the power supply section, test some electrolytic capacitor at the vertical section. ty
Jan 01, 2008 | Televison & Video
Televison & Video Logo
50 people viewed this question
Top Televison & Video Experts
Electro Med Services...
