Question about GE Spacemaker JVM1640SJ Microwave Oven
My ge spacemaker 1800 xl, keeps beeping and beeping. Plus I'm also getting a F3 error message that keeps coming up. And last but not least, when I press "any" button on the pad nothing happens. PLEASE HELP!!!!
4 Suggested Answers
SOURCE: microwave malfunction
I was also getting F3 error code on GE spacemaker xl 1800. After reading prior post about possible faulty keypad, I unplugging and touching each of the keys on the control panel. After touching most of the individual keys, the problem solved itself. Back to having a working micro. Thanks for the help!
Posted on Jul 10, 2007
  • 619 Answers
SOURCE: have a ge spacemaker xl1800 - f3 error
The magnetron almost shortening , the diode sound beeping / replace magnetron.
Posted on Jan 03, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: F3 error GE Spacemaker XL 1800: Model JVM1851CD.
F3 on a GE / Hotpoint microwave means you have a shorted membrane keypad (aka membrane switch).
If and when an oven is coming on or doing anything by itself, this is very dangerous and can result in a fire.
So until it is repaired, please leave it unplugged or leave the door open when it's not in use, and of course one should never leave a microwave unattended while cooking.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
If you would like to have us do this repair for you, we do that for $39.95 plus part costs nationwide.
Either way, we can let you know what your options and costs would be and send you other helpful info.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Feel free to contact me
directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
Posted on May 06, 2010
GE Profile Spacemaker xl 1800 JVM1860SD. Touchpad has stopped working.When power is turned on -get error message F3
F3 means you have a shorted membrane keypad.
The keypad is not available as a separate part, so you would have to order a control panel frame assembly, which comes with a new keypad on it.
Whether your model number is JVM1860SD001 or JVM1860SD002, the part number is WB07X10474 and a link to various suppliers is here.
They're not making these anymore, so order while supplies last.
This is a simple DIY job.
Then you unplug the keypad (as per the photo below) and carefully move your circuit board into the new frame.
Some connectors on the relays have a lock:
Dec 18, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Ge psacemaker microwave oven no working it started with a sensor error and the message change to F3 and beeping. I unplug and plug its still same error.Model JVM1750. What does F3 message stands for?
F3
Key panel (touch pad) shorted This code will occur if a shorted key panel is detected
continuously over 60 seconds. Replace key panel (also called touch
pad).
Dec 19, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
F3 error ge Spacemaker xl 1800: Model JVM1851CD. What does F3 mean?
prototech@usa.net
May 05, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
The unit is beeping and has a code showing F3
Is it difficult to change a touch pad on my ge profile eterna spacemaker microwave. F3 Error, Bought it new in 2006. Touchpad Part No# WB07X10959 Twinsinger asked.
Feb 03, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
My GE Spacemaker XL 1800 was working fine and
check fuse inside unit microwave has a fuse around 15 to 25 amps get at local hard ware store u should discharge capacitor before installing fuse not nessary in microwave
Jul 25, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
F3 Error Message
the code means this.
F3 Shorted touch pad panel
Good Luck
Dec 29, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Spacemaker beeping loud and f3 message driving us crazy
The error code F3 indicates an oven sensor problem. The oven sensor is most likely the failed part. The oven sensor probe must have the correct resistance readings at specific temperatures. When the electronic range control (ERC) cannot identify the correct resistance of the oven sensor or the resistance is way out of specs F3 will display.
I recommend calling a service technician to diagnose and repair your oven.
Dec 18, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Spacemake xl 1800
just off hand if you have completely removed the power to the microwave and you hear a beeping it is likely coming from another device in your home.... took me ten minutes the other day to figure out the odd noise i was hearing was the low battery alarm on my wife's cell phone.
Sep 22, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Have a ge spacemaker xl1800 - f3 error
I had the same problem. I removed the grill and opened the control panel as I read an answer from "GENE" on APP (Appliance Pros) that this indicated a short in the circuit board (TouchPad). I was going to replace the faulty circuit board but when I opened the control panel there it was......One wire harness had just came unplugged!! I plugged it in, reassembled and the microwave works again!
Mike
Tampa, FL
Jan 01, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave malfunction
On a GE microwave F3 means you have a failed keypad.
We replace these for customers nationwide with our guaranteed $39.95 service.
If you might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved. It's here.
Please feel free to contact me directly if you need more help.
We're happy to help and we appreciate your thoughtful rating of our answer.
prototech@usa.net
May 29, 2006 | GE JVM1861SF Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
143 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
