Question about Nikon COOLPIX L3 Digital Camera
Flash for Coolpix L6 Digital
When taking pictures in low light, the flash doesn't come on; therefore pictures are out of focus. A RED hand flashes on the screen. When I try to push the flash button, nothing happens. What can I do? Otherwise my pictures are good.
  • sue10436 Jan 05, 2008
    My camera doesn't flash either and a red hand flashes on the screen.
  • 797 Answers
You can try to reset all of the internal settings. This has worked for me with a digital camera.
It would be good here to know what kind of camera we are working with.
Make sure you do not have any of the settings in the camera set to turn off the flash...for instance setting it at mountains or most any outside setting may not allow the flash to work. Some cameras will allow you to override the setting internally.
If the flash does not work at all, then repairs will be needed.
Posted on Jun 21, 2008
My camera won't take pictures with the flash on and when i try the red light just blinks. only takes pictures with no flash.
When your flash light (I mean the part that gives the flash) or the capacitor that stores the power for the flash are defect. you won't see a flash. When a red light comes on, when actually the flash should fire, the most likely the capacitor is defect. The electronics sensed it could not reach the voltage needed to fire the flash.
It also could mean your battery can't deliver enough to charge the capacitor, but is that was the case the battery indicator should tell you.
Jan 20, 2014 | Nikon COOLPIX S230 Digital Camera
My flash stopped working on my nikon coolpix L110..
The Nikon Coolpix is a compact digital camera that is well-suited for amateur to semi-professional photographers. Occasionally, some issues with the built-in flash can occur. If the hardware is damaged, the camera must be taken in for repairs. More often, problems occur because of obstructions or issues with the camera's settings and are easily repairable. Follow the troubleshooting guide to fix the built-in flash.
Instructions:
1.Ensure the Nikon Coolpix digital camera battery is fully charged.
2.Wait several seconds before pressing the shutter-release button if the "Flash Ready" indicator light is flashing red. Press the "Flash Mode" button once or twice to change the flash settings from "Off" to "On" or "Auto" if the "Flash Ready" indicator light is off.
3.Ensure there are no obstructions, like your finger or the camera strap, that are preventing the flash from firing if an error message appears on the display screen and the flash is not firing when the flash mode is set to automatic.
4.Press the flash back into the camera after every photo to ensure the flash always fires in "Auto" mode instead of just in low illumination settings. Press the flash back into the camera to turn off the flash in "Manual" mode; otherwise the flash will continually fire.
5.Change the auto focus setting from "Infinity" to "Auto," "Macro Closeup" or "Self-Timer" by pressing the "Focus Mode" button once, twice or three times to automatically turn the flash back on.
6.Use only Nikon external flash accessories to avoid damage to the built-in flash and camera circuits.
I hope you find it very helpful. Thanks.
Aug 25, 2011 | Nikon COOLPIX L4 Digital Camera
My Nikon Coolpix s230 flash won't work. It just blinks red in the lower right hand corner. I've tried all the settings and they all won't flash.
If there is a problem with the flash itself or the mainboard connection to the flash it will not charge. If the flash won't charge then it won't go off when you take a picture. The only way to fix the problem is to replace the flash with a good used one and see if that fixes it. If not, then you need to replace the mainboard. Good used parts can usually be found online for cheap; that auction website doesn't pay me to type their name, so I don't, sorry. Hope this helps!
Thomas Drayton
Owner, www.darntoothysam.com
Affordable Digital Camera Repair
Jul 24, 2011 | Nikon COOLPIX S230 Digital Camera
Sx30is flash off position. I would like to take a picture in low light without a flash. The camera emits a green light as a warning that the flash is off. I would like to not have either the flash or...
The reason the camera has the green light is not to warn that the flash is off. The green light is used to help the camera auto-focus in low light situations. If you disable auto-focus and use manual focus the green light should not flash when taking the picture. Let me know if that helps!
Jul 10, 2011 | Canon PowerShot SX30 IS Digital Camera
NIKON Coolplix S210 can't take photo in flash mode
If the flash is on and you can't take photos, it could be that the flash circuit has gone bad. Make sure the camera is focused first though, before you try to take the pictures. Many times if the camera can't focus on something, it wont take a picture.
Mar 30, 2010 | Nikon Coolpix S210 Digital Camera
"hand" icon flashing
It's likely your photos are blurry from camera motion, caused by taking a hand-held photo with a slow shutter speed, rather than out of focus.
The hand icon flashes when you don't have enough light to take a crisp (not blurry) photo without either using a tripod (or a flash). The reason for a flashing hand is you can't "hand-hold" the camera at the current settings - you need to use a tripod. If you are "zoomed in" (on a telephoto setting for your lens) you can sometimes get a crisp hand-held photo if you "zoom out" to a wider angle setting on the lens. (You need a steadier hand to hand-hold a telephoto lens setting than a wide-angle lens setting.)
You may have changed a setting that sets the ISO (the normal setting would be "auto") and if so, if you change the ISO to a high number, or to auto, this will help you take better photos in low light. Check your camera's user's manual to see how to check/change the ISO.
When you have more light the icon will stop flashing. If you need to take hand-held photos in low light then you need to use flash, or get a better camera that has better low light capabilities.
Dec 14, 2008 | Nikon Coolpix 5200 Digital Camera
Nikon Coolpix digital camera L18
The red light is probably the focusing beam. I'd guess that your flash is turned off somewhere in your settings. Go through the menu and if you find that it is not turned on there might be a hardware problem. Also, if the flash is set to automatic, it will not work when it thinks there is enough light to take a good pic.
Nov 07, 2008 | Nikon Cameras
When i take a picture with flash, the screen goes black and a red light flashes
after i take a picture on my nikon coolpix the screen goes black for about 30 seconds before you can take another picture.
Feb 10, 2008 | Nikon Coolpix S1 Digital Camera
Turning off after taking a picture with a flash
Sorry but that is just because the flash is recharging.. It turns the screen off so it can charge the flash faster.. No worries it works fine :)
Jan 24, 2008 | Nikon Coolpix 4600 Digital Camera
Nikon COOLPIX L3 Digital Camera Logo
186 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
