Question about Hotpoint BWM12 Front Load Washer
Programme dial again
When i turn on my washing machine to start it the programme dial just keeps clicking around constantly. the door is locked and no matter the programme i set it too it starts clicking round and doesnt stop until i switch it off
  • Anonymous Mar 18, 2008
    I sometimes have the same problem with my bwm 12 integrated washer, also it now will not pump out the water. A friend has told me that there may be something stuck in the `trap' which is obstructing the water from draining out. I have tried to unscrew the black round `plug' at the front on the bottom left hand side but this will not come out completely. I've heard it should unscrew and pull out which will enable me to remove whatever is stuck there, should this come out, I dont want to pull it too hard incase i break something.
  • Anonymous Mar 12, 2014
    40min mixed wash and 15 min quick programme seem to get mixed up when you turn dial. Then programmes may stop and clock goes back to start time like you never started machine. Bosch Exxcel 7 1400 Express.
Yes thats your problem,the reason it wont unscrew is because of things caught inside ie coins gunk you will have to take out machine turn on side,there are two sometime four screws at front of machine where black dail is remove these,when machine is on its side you can acess pump from underneath,there is a black rubber hose which goes from drum to pump which is held on with a circlip remove this at pump end you will need a vicegrip,remove all gunk coins ect, refit all back to machine ,,problem solved......the reason dail was turning was because it was looking for progam to release water which it couldnt because of blockage,after tou unblock you will find that black srew on cover on front can be removed(always better to check for blockages every few weeks hopes this helps
Posted on May 23, 2008
Why does the door lock keep locking & unlocking when the cycle is done?
Sounds like the programmer needs to be replaced. If this does turn out to be the fault, it does not sound like anything else, it might be cost effective to buy a new machine. New obes are not much more than the cost of a repair nowadays
Good Luck with it, hopefully it is not too costly to rememdy
Jun 11, 2015 | Washing Machines
Ariston Washer not running Programme
It sounds as if the brushes in the motor have worn,when the motor stops it wont go through the program,try turning the ddial around to spin to check the motor
Mar 07, 2014 | Washing Machines
Bosch 500 series washer E:27 error code?
turn dial to off. hold down both delayed start and spin select buttons and turn dial to the left one click, to the cold position. keep holding button until you here a click. let go of buttons and turn dial to off. Every thing should go back to normal. Just fixed mine and all is good.
Nov 21, 2010 | Bosch WFVC5400UC Washer
Indesit WA6x washing m - dial clicking around...
This sort of problem is usually associated with a faulty control board
If there is a reset point on the timer, then reset it, and try again, if it still does the same thing, then it it is going to be the control board.
Mar 22, 2010 | Washing Machines
this sounds like a door lock issue if the machine does not detect the door has closed properly you will get the same symptoms, try slamming the door shut (not too hard) if machine starts but then does the same thing next time you use it will need new lock it will have gone out of calibration.
Oct 14, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Beko wma1510s washing machine dial problem
my beko wma 1510s will not spin and is heating up
Apr 11, 2009 | Washing Machines
Washing machine malfunction
The latch might be an issue . Move the dial on pump mode . Try activate the door lock with a screw driver move it to the right and should activate the machine. If that works then the latch is the issue and can easily be repaired by removing the door.
Aug 09, 2008 | Bosch Classixx WFL 2462 Front Load Washer
Washing machine wont do anything
rotating timer knob indicates that there is a fault, obviously, so its a case of going through a checklist, based on info given, check in this order, outlet pump, for open circuit, then heater element for open circuit, then maybe the water valves, you have given little information for me to go on as an engineer, please understand, the more you say the more detail we can give ..... ok cheers with looking for the fault, best of luck and work safe
Dec 21, 2007 | Indesit W 123 Front Load Washer
Zanussi washer drier 1480W door lock
Zanussi's always keep clicking before starting.I don't know what E60 is about,but I take it the machine is working?
Dec 10, 2007 | Zanussi FJS1225W Front Load Washer
Hotpoint BWM12 Front Load Washer Logo
339 people viewed this question
Top Hotpoint Washing Machines Experts
Todd Arndt
Todd Arndt
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
