Question about Acer Aspire One PC Notebook
Battery is causing laptop to shut down on start up. Laptop boots normally when battery is removed
  • 40 Answers
Replace the battery if the battery seats correctly in the laptop
try charging the battery with it off for two hours...
if the charging light does not go off after one hour the battery pack needs to be replace...
goto and order the battery correct for your laptop
Posted on Sep 28, 2009
My Lenovo laptop is frozen and the mouse, keyboard and power off button isn't workind! What should I do ?
Either wait for it to start responding again (I'd give it a few minutes) or just pull out the battery to force it to shut down.
After that just insert the battery again and try booting up your laptop normally. It's quite possible your laptop will give a few error messages because you didn't power it down normally.
Hope this helped!
Mar 04, 2015 | Lenovo Computers & Internet
Why doesn't my laptop start?.
remove the battery for about a 5 minute then insert it again, then press the on button
Jun 03, 2014 | Computers & Internet
Dell laptop boot problem
Try a "Cold-Start",Remove all media, DVD, CD, USB..etc., Remove AC plug, Remove Battery, Hold down on/off button for 10 seconds, Replace battery, Plug into AC outlet,Push on/off button and Start normally. IF THAT FAILS, reboot while tapping F-8 or what ever will get you to an options list or Boot Menu, my laptop is F-10 for Boot Menu, for example.
Nov 07, 2012 | Dell Computers & Internet
Compaq nx6125 is not charging even though the adapter is working fine and the battery is fine too
Firstly, try the following steps to check the problem:
Turn off laptop.
Unplug AC power adapter.
Remove battery.
Replace AC power adapter.
Turn on laptop, allow OS to boot.
Once logged in to the machine, perform a normal shut down.
Replace battery.
Turn on laptop, allow OS to boot. The battery should once again be charging as normal.
Oct 25, 2012 | Computers & Internet
Toshiba A135-S4527 starts to power up then shuts down.
When the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a small brush and can of compressed airto do this.
Mar 08, 2012 | Toshiba Satellite A135-S4527 Notebook
I have an Acer Aspire 5670 (5672WLMi) with a boot problem, the laptop boots, and the battery led blinks and the computer shuts down. I remove the battery and the laptop boots up. The battery is new and...
Thank you for your query, this is not a too uncommon in acers it would seem you may have a cold solder joint on the motherboard causing a short and ultimatley shutting the laptop down
You will need to book the laptop into a reputable PC shop for repair
I hope this has been useful
Mar 15, 2010 | Acer Aspire 5670 Notebook
My new HP notebook won't turn on. I've had it for one month. There is a light on the side where it is plugged in, but it won't turn on
Unplug the AC adaptor. Remove the battery. Hold down the start button for 1 minute. Replace the battery and plug in the AC adapter. The computer should reboot.
Jan 07, 2010 | HP Pavilion dv6000z Notebook
Laptop just shutting down every 5 mins or so -- Just going power down and booting up until one waits -- Same issue in safe mode, on battrey, on power with abttrey disconnected, and even in bios mode....
Sounds like the CPU is overheating. Try cleaning with canned air. On the bottem of the laptop you can see a fan with laptop off and battery removed use a whole can of air to clean it. wait 5 min. replace battery and try normal start up. listen for the fan to come on if it doesn't the fan is bad and needs to be replaced
Hope this helps
Please leave feed back
Nov 29, 2009 | HP Pavilion DV6910US Laptop
My laptop acer 5220 when I start the system by power Button automatically after about thirty seconds off the system - shams79
the processor shuts itself down because the fans on the processors are not getting on and the processor gets over heated. if you can jump into bios setup please see processor temperature
if all is normal please reset your bios to default mode and save settings by preessing f!10.
next step try to remove one ram if there are two.
third step .. remove any attached device to your system or remove any cd from the cdrom tray. remove any media card if its already there
Sep 19, 2009 | Acer Computers & Internet
The laptop doesn't boot up always.
I would try the following:
1. Remove the battery completely. If the computer boots properly several times in a row, then the battery may be causing the power supply to do strange things.
2. If you have experience removing laptop components, try removing the hard drive. Because you say the screen goes black (I assume the system powers off) sometimes after the HP logo, I doubt its Windows or a software issue.
3. If HP has a diagnostic CD you can boot to, try that.
4. It may be the power supply acting up. If it charges the battery, and if you can boot to Windows with the battery, try getting a new power supply.
5. Otherwise, it may be the motherboard of the laptop.
Nov 28, 2008 | Computers & Internet
Acer Aspire One  PC Notebook Logo
70 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
