Question about Samsung Computers & Internet
How can i change my bios device priority settings
Hi ,
I have a samsung r510 laptop. I wantto change my bios settings but some properties are locked. How can I unlock these locked properies,settings ? how can i change my bios device priority settings ?
Please answer me ...
    Genius:
  • 1,027 Answers
Many Bioses have 'locked' sections because there is no supported hardware on the motherboard. One way to 'unlock' is to clear the CMOS memory, by removing the coin cell battery (if that type) and keep it off for about 5 minutes. If a soldered in battery, there usuall is a jumper to clear the CMOS. Once done, the BIOS is at default state, and the time, etc needs to be entered.
Posted on Sep 29, 2009
How do I unlock the Bios on an Acer ES-1 111M Laptop
To boot from a CD, DVD or USB device, make sure that the device has boot sequence priority over the hard drive.
BIOS Boot
BIOS (Basic Input Output Subsystem) is a programmable chip that controls how information is passed to various devices in the computer system. A typical method to access the BIOS settings screen is to press ESC, F1, F2, F8 or F10 during the boot sequence.
BIOS settings allow you to run a boot sequence from a floppy drive, a hard drive, a CD-ROM drive or an external device. You may configure the order that your computer searches these physical devices for the boot sequence.
The first device in the order list has the first boot priority. For example, to boot from a CD-ROM drive instead of a hard drive, place the CD-ROM drive ahead of the hard drive in priority.
Before you set boot priority for a USB device, plug the device into a USB port.
To specify the boot sequence:
  1. Start the computer and press ESC, F1, F2, F8 or F10 during the initial startup screen. Depending on the BIOS manufacturer, a menu may appear.
  2. Choose to enter BIOS setup. The BIOS setup utility page appears.
  3. Use the arrow keys to select the BOOT tab. System devices appear in order of priority.
  4. To give a CD or DVD drive boot sequence priority over the hard drive, move it to the first position in the list.
  5. To give a USB device boot sequence priority over the hard drive, do the following:
    • Move the hard drive device to the top of the boot sequence list.
    • Expand the hard drive device to display all hard drives.
    • Move the USB device to the top of the list of hard drives.
  6. Save and exit the BIOS setup utility.
  7. The computer will restart with the changed settings.
Boot Priority Options
Some computer manufacturers allow you to select the device that contains the boot sequence from a special device selection menu. The example below uses a Dell system board.
To set boot priority using a device selection menu:
  1. When the computer starts to boot up, after the manufacturer's ID screen, press F12 several times. The device selection menu appears.
  2. Use the up and down arrows to select CD-ROM or
May 04, 2015 | Acer Aspire Computers & Internet
My computer wont boot correctly
won't boot at all?
it's probably the BIOS settings
go to the BIOS settings by pressing F8 or DEL
go to advanced settings
look for "boot device priority" or something like that
set the first priority device as your harddisk
save & exit,restart,happy computing
the "boot device priority" maybe not placed on advanced setting,each BIOS has different interfaces,just look for something like that,it's easy
Aug 22, 2012 | Gateway NV53A24u Laptop
Acer aspire one ZG5 booking bios
have you change the settings of boot device from your bios?..in order for you to boot from CD or DVD once you install a windows, first go to your bios settings and change the boot device priority. The 1st boot should be the CD/DVD. Hope it helps thanks.
Nov 22, 2011 | Computers & Internet
PXE-E61: media test failure/PXE-M0F: Exiting PXE ROM/Operating system not found. This message is coming up on my screen. The only thing I can access is F2
Hi, welcome to FixYa.
Apparently, the error of your system is missing operating system, this could caused by many things, from broken hard disk to missing boot record such as MBR.
First, try to fix your BIOS start up setting. Depend on your BIOS setting, go to your BIOS by pressing F1 or F2 (apparently this is your key) or END during boot time. Then go to Boot Setting (this name is vary in any BIOS manufacture, so try to locate the similar name). Change the boot priority with first priority is your hard drive,
If you still don't able to boot, this can be caused by missing boot record such as MBR. This is little bit trickier. The fastest way (I assume you use Windows), is to insert your Windows installation CD/DVD then boot from there (by changing boot priority again from BIOS, or some new BIOS support pressing F12 to choose boot device). After you boot from there, repair your Windows.
I hope this information will be helpful. Thank you for using FixYa!
Mar 07, 2011 | Acer Aspire 3680 Laptop
How do i put new keyboard in my samsung r510
This is not a "do-it-yourself" job. Take the Samsung to a qualified technician, to get the job done correctly, without damaging your device.
Mar 06, 2011 | Samsung R510 AS08 R510 FA01 R510 FA02 R510...
How can i change first boot device cd rom to dvd rom
To change your boot device you must change the setting in you BIOS.
To do this restart your computer and press delete repeatedly.
When you are in the BIOS search for Boot Priority within the different tabs.
To set you DVD Drive as the boot device make sure it replaces the CD Drive.
Set the DVD Drive as the first priority and your Hard drive as the second boot priority.
Save the settings and exit.
This will enable you to boot from your DVD Drive if a bootable disc is present in the drive.
Let me know if this solution was helpful!
Regards
Nov 30, 2010 | Gigabyte GA-8ST800 Motherboard
How to boot from windows CD / boot property changes
Hi there.
Restart the laptop and hit F2 as it starts, that will take you into the bios, in the bios look for the boot order and set the CD/DVD as first boot device, hit F10 and exit the bios, the computer will restart and allow you to boot from CD.
Please post back with the results and thanks for using FixYa!!
May 23, 2009 | Toshiba Satellite A10-S100 Notebook
BIOS SETTINGS
Go to BIOS setting by pressing F2 or Del while booting..and change boot priority as first boot device as hard disk then save and exit...
Feb 19, 2009 | Intel D845GLLY Motherboard
Computers & Internet Logo
312 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
phoenix chi
phoenix chi
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
