Question about Maytag Atlantis MDG6400AW Gas Dryer
How do I open the top. I see hinges but no catches?
  • Maytag Master
  • 2,605 Answers
First; unplug the dryer from the wall. Now that the unit gas no power to it, you need to remove the front panel to open the top. 1) open the door, you will see a total of 8 screws. Remove them starting on the hinge side (once those are out you can take off the entire door) then the other side. With the screws all out, the front panel is ready to come off. 2) the front panel sits on a couple of holders at the bottom, lean the panel towards you and lift, it will release. 3) you will now see a hook type holder on both sides securing the top down, remove those and the top should flip up on the hinges you already identified. Hope that helps good luck
Posted on Sep 28, 2009
How do i open the panel under the dryer door
Some panels are hinged at the bottom and removal consists of pulling the panel out at the top to release the catches and rotating downward to pull up and away from hinges.
Aug 26, 2016 | Kenmore Dryers
Door won't open catches on small panel next to it when opening took panel off which is right behind front passenger wheel and the metal underneath it looked as though it was sucked in. How do you fix...
LOOK AT THE DOOR CLOSED, SEE WHAT PART OF THE GAP IS MORE THE TOP OR BOTTOM, REALINE THE DOOR BY OPENING THE DOOR WITH A HYDROLIC JACK, JACK UP THE SIDE WHERE LATCH IS JUST ENOUGH TO HOLD IT THERE, THEN LOSEN THE THE BOLTS ON HINGE (IF TOP IS MORE GAP LOSSEN TOP HINGE OR IF BOTTOM IS GRATER THEN THE BOTTOM HINGE) LOSEN ONLY ENOUGH YOU CAN TAPE EDE OF DOOR WITH PALUM OF HAND AND IT WILL MOVE, YOU ONLY MOVE IT 1/16 OF AN INCH THEN TIGHTN IT UP AND CHECK ALIGNMENT. REPEAT TILL IT IS CORRECT
Aug 02, 2011 | Pontiac Bonneville Cars & Trucks
Driver door has dropped about 1/2". I see a torx
Before attempting to adjust the door, you need to check the wear on the hinge pins. Open the door fully and look at the middle of the hinge. See the pin there? Lift up on the latch side of the door as you watch the hinge pin. If you see the hinge moving around the pin or see the pin shifting back and forth then the metal grommet the pin goes through is worn and needs replacing. Motormite makes a replacement pin set that comes with new grommets ( or bushings to some). It's not so hard to change, but it can be a little tricky. Jack up the door to relieve the pressure on the pin.Start with the top pin. Watch the pin as you jack and keep going until the pin is in the middle of the movement range. Tap the old pin out and then inspect the grommet to see if it's worn past the outer edge of the metal. If it is worn past the edge then you'll need to replace that hinge. Otherwise, you can use that old pin to tap out the old grommet, and replace with the new one, then the new pin. slowly release the pressure on the jack and watch the new pin for excessive movement, then do the bottom pin and grommet.. Test door swing and alignment. If the door still hits low on the catch post, loosen those torq bolts after lifting the door slightly and now lift the door the distance it was low plus 1/8 inch. retighten torq bolts and release jack, then retest the door alignment to the catch post. Don't let the door strike the catch post hard - just let it slowly come into contact as you watch for alignment. Repeat procedure until door lines up centered on taht catch post.
Good luck!!
Nov 07, 2010 | 2001 Dodge Durango
How can you get saddle bag open, that latch is screwed up?
The solution to this problem, unfortunately, will involve the destruction of two hinge pins; since the hinge is sold only as an assembly, the entire hinge will have to be replaced. I'm sorry about that, but I thought you ought to know that before you start the repair.
Look at each end of the hinge (on the outside of the bag); you will notice a hole and (it may take a flashlight to see it) the end of a hinge pin within. Those hinge pins will have to be driven toward the center of the hinge until the hinge halves separate; that's much less than an inch, but is SEEMS more like 30 feet. Use a nail set that fits loosely in the hole, or a hardened nail about the same size with the tip ground flat.
Once the hinge halves separate, you'll find that you can lift that side of the saddlebag cover only a very short distance; the nylon fabric hinge cover on the inside keeps the cover from opening more than a VERY few inches. The hinge cover is secured by 3mm hex bolts; use a 3mm allen wrench to remove the bolts and the saddlebag top should swing open far enough for you to get your hand inside.
Take a flashlight and examine high on the opposite side of the saddlebag, inside the bag just underneath the cover; there are two catches covered by a broad plastic shield. Use your 3mm allen to remove the plastic shield, then use a small socket to remove the bolts holding the catches to the bottom part of the saddlebag. You can now lift the top of the saddlebag off and reveal the bottom of the catch.
The cover of the catch is secured by 1/4-turn fasteners, you'll see the phillips-head slots. Turn the screwheads until all fasteners are obviously loose; the cover can then be removed. There is a bent catch actuator arm beneath; push the top (free end, well, actually MIDDLE) of the arm toward the outside of the saddlebag cover, and the catches you removed from the saddlebag can be freed and remounted on the saddlebag.
You'll see the bottom of the release button through the catch actuator assembly; push it out, back to its' normal position. You're likely to find one of two things wrong: the actuator arm (4XY-2841A-00-00) is bent or broken, the lock assembly (4XY-W2843-00-00) has a bent or broken actuator tab or lever. A bolt may also be missing from either the actuator arm or lock assemblies; that would typically cause misalignment or binding.
Replace the hinge, reassemble the saddlebag top with the appropriate repair parts, mount and take a nice, long ride to relieve the frustration.
Mar 18, 2010 | 2008 Yamaha Royal Star Venture
Can not get saddle bag open the lach is messed up and won't open
You'll see the bottom of the release button through the catch actuator assembly; push it out, back to its' normal position. You're likely to find one of two things wrong: the actuator arm (4XY-2841A-00-00) is bent or broken, or the lock assembly (4XY-W2843-00-00) has a bent or broken actuator tab or lever. A bolt may also be missing from either the actuator arm or lock assemblies; that would typically cause misalignment or binding.
Mar 17, 2010 | 2006 Yamaha Royal Star Venture
How do you open the soap dispenser
We have this Gojo soap dispenser and can't figure out how to open it to refill it. there are no directions on the refill package and no obvious release buttons to press. Help?
Dec 10, 2009 | GoJo GO-JO INDUSTRIES NXT Lotion Soap...
Brother MFC-8840d ADF feed problem
Hi, the left hinge is spring loaded to keep the lid open. This applies a lot of pressure on the pivot point of the hinge (steel pin/plastic hinge) that elongates the plastic holes and raises the lid from the scanner. As the paper leaves the scan window, a ramp next to the scan window sends the paper up to the tray, just past that ramp under the lid is a lip that guides the paper to the tray. With the hinge stretched, the lip is too high and catches the end of the paper at the rear only, and jams the paper. If you press on the cover (with the new hinge) and it does not catch then you have installed a bad hinge. Also ensure that the top part of the hinge is on the guide pins under the cover.
Jul 29, 2009 | Brother MFC-8840D All-In-One Laser Printer
The lid on my top loading admiral mega 22 plus washing machion is
These are plastic and will need to be replaced with new.
Once you have sourced new hinges then the machine top needs to be opened,
Electrically Isolate the machine, then at the joint between the machine front panel and top insert a flat blade 4" from each side to release the lid catches, tilt back the top to access the screws on the hinges and replace with new.
Mar 03, 2009 | Admiral AW22 Top Load Washer
Top oven door glass has smashed
Usually, u open the door as far as possible and at the lower end of the hinges you shoud find what look like 2 small catches, pull these up and latch them on to a hook or something similar on the main part of the hinges, this compresses the springs, and then lft up the door and pull towards u, this should release the door, and then change the glass, then offer the hinges into the slots, and pull the door back down, then release the catches.
Plz rate my solution.
Thanks.
Jan 01, 2009 | Fagor Ovens
New Cornu Fe Stove - Oven door pops open
I had the exact same issue with my Cornue Fe (only on the right hand side oven). The other symptom I noticed was that the door itself didn't close as smoothly as the left hand side oven.
Take a look at the alignment of the "post" sticking out from the oven relative to the spring loaded catch on the door. These need to be *very* well aligned vertically in order to keep the door closed as it heat cycles. You'll notice that the post has a depression at the end of it (furthest away from the door). The door catch has an upper and lower spring loaded roller that is supposed to "catch" on both sides of the depression. If you are misaligned vertically, then only one side of the catch will be applying sufficient force to the depression.
In my case, the post and the catch were misaligned by about 4-6mm. In fact, I noticed that repeated opening & closing of the door was actually causing some wear on the upper roller of the catch. To fix, I needed to raise the door, which was accomplished by adjusting the hinges.
I removed the door from the oven, which can be done by removing the screws on the hinges. The hinges consist of a bottom & top knob that slot into the door (similar to the way refrigerator hinges work). The hinges themselves are made of ~1/4" metal (could be stainless, but it's relatively soft stainless). I put the lower hinge in a vise (appropriate covering to prevent scratching) and *gently* bent it up to adjust the door upwards. Putting it back together required some help (the door is heavy), but after a bit of work it was all back. Thankfully the alignment was right the first time. This whole process took about 20 minutes.
In my case, I suspect that either the wife or kids had put too much weight on the door at some point and bent it out of alignment. The problematic door had about 4-6mm of "play" between the top and bottom hinges prior to my adjustment--the working door had zero "play". You might want to check to see if you have any such play before you do this work (you can either look at the hinge itself or simply lift up on the door at the hinge point to see if it moves). If you don't have this same play, but you do have misalignment, then you'll need to adjust both top and bottom hinges.
The other possiblity is that you might have a weak spring in the catch mechanism. You can check that by gently pushing a flat head screwdriver in between the two rollers and feeling for how much force is required to separate them.
Of course, you can also just call the La Cornue service folks and have them check it out.
Mar 21, 2008 | Kitchen Ranges
Maytag Atlantis MDG6400AW Gas Dryer Logo
247 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
