I need the following printing cartages as they are not available in sierra leone 1. Canon CLI-221 Black Compatible Inkjet Cartridge W/ Chip 2. canon PGI-220 PIGMENT BLACK COMPATIBLE INKJET CARTIDGE W/CHIP 3Canon CLI-221 YELLOW Compatible Inkjet Cartridge W/ Chip 4. Canon CLI-221 MAGENTA Compatible Inkjet Cartridge W/ Chip 5. Canon CLI-221 CYAN Compatible Inkjet Cartridge W/ Chip
Reset ink level on canon mg2120 after ink refill
The following procedures may be used to reset the Canon printer ink level monitoring following the installation of a refilled Canon 30, 31, 40, 41, 50, 51, 210, 211, 240, or 241 integrated ink cartridges. In most cases, the error/alert will need to be cleared to enable printing. Ink waste container reset procedures are also provided below.
NOTE: for multi-cartridge installation, the procedure(s) may need to be repeated twice.
For PGI-5, PGI-9PBK, CLI-8, PGI-220 CLI-221 PGI-225 CLI-226 PGI-250 CLI-251 Cartridges: These are new Canon cartridges which have an embedded chip on each cartridge. If you just refill the ink, the printer will still reads the cartridge as empty. You have two choices:
Purchase a "refillable cartridge" from www.asapinkjets.com
BCH or other sellers. These refillable cartridges have an auto-reset chip (non OEM) and will reset automatically.
Use a chip resetter (e.g., search Canon + model number + resetter on eBay). Follow the instruction below to refill your original cartridge, and use the resetter to reset the chip.
Inkjet Cartridges and Toner Refills
Aug 29, 2012 | Canon PIXMA MG2120 Inkjet Photo All-In-One
I own a Canon PIXMA MX860 printer. I have several extra CLI-221 Black ink carriages, but my PGI-220 Black shows it needs to be replaced. Is there a way I can use up some of my extra CLI-221 Black...
Hello, if your printer tells you need to replace the cartridges just press stop/cancel buton for at least 5 second and then you can use the printer only on black. I dont recomend you do that becouse your printhead might burnout.
Jan 05, 2012 | Canon Office Equipment & Supplies
Canon pixma ip4300 black ink refill. BK and PB
The correct order of install a ink tank (From Left to Right):-
1. CLI-8 Black
2. PGI-5 Black (pigment)
3. CLI-8 Yellow
4. CLI-8 Magenta
5. CLI-8 Cyan
Else you can visit this link and type "correct order of ink tank" in enter your question space.
Good luck...don't forget to rate the solution.
Feb 22, 2010 | Canon PIXMA iP4300 InkJet Photo Printer
Magenta check ink comes on but it is full
Is the cartridge a new original Canon or is it refilled? If it is refilled it is likely whoever has refilled it has done a poor job. The Canon CLI-8 cartridges have kill chips on them that need to be replaced. Many refillers like to try to confuse people and tell them to either ignore it or put the old chip on their new filled compatible cartridge. The truth is that the chip must be replaced or reset for the printer to recognized it.
Feb 06, 2010 | Canon PIXMA MP530 All-In-One InkJet...
QUESTION FOR DON_FARR
whenever you print greyscale what actually happen is that the printer mixes the red, blue and yellow to give the output in gray scale. See if you mix red, blue and yellow ink in the right proportion it gives you very close to black. just try to print your greyscale with your black ink finished you will still get the same print quality as when the black has ink in it. Or find a way seal the nuzzle of the black in and print your greyscale. check what results.
Dec 12, 2009 | Canon PIXMA MP610 InkJet Printer
Printing B&W on a Pixma MP800 with empty color cartridges
no you cant print with emapty colour catridges you have to install the other full catridges.
Nov 23, 2009 | Canon Pixma MP800 All-In-One InkJet...
What is the cartridge number of HP 4335 all in One Printer
the part number is hp 21 black injet print cartridge part# c9351aa, hp 22 tri-color inkjet print cartridge part# c9352aa cartridge for everyday printing and the high volume printing cartridges hp 27 black inkjet print cartridge part# c8727aahp 22xl tri color inkjet printer cartridge part# c9352ca; these cartridges is for hp officejet 4355 all-in-one inkjet printer
Nov 21, 2009 | HP Officejet 4355 All-In-One InkJet...
Canon pixma ip4600 black ink problem
The PGI-220 is the larger ink tank and is filled with standard black ink. The PGI-221 black cartridge is the photo black. There is no way to force the printer to use the photo black cartridge (skinny one) to print documents. The photo black cartridge is only used if you print a photo. I own a Cartridge World ink refilling shop and I can't refill these cartridges yet. There is no way to reset the ink level chip without a resetter and any replacement chips you find on the internet are technically violating patent law.
Jan 28, 2009 | Canon PIXMA iP4600 Color InkJet Photo...
Other compatable cartridges
Cartridge Description
Zone 1
small black inkjet print cartridge
HP 94
small tri-color inkjet print cartridge
HP 95
large tri-color inkjet print cartridge
HP 97
photo inkjet print cartridge
HP 99
Jan 15, 2008 | HP PSC 2355 All-In-One InkJet Printer
78 people viewed this question
jasbo
jasbo
