Question about Samsung HT-Q100 System
Squeeling Fan in main unit
The fan is squeeling in the main unit upon turn on. How do i get the case open to be able to change it?
  • 440 Answers
Sides scres slip it off get new fan in blow dust out
Posted on Feb 10, 2008
Fan is making squeeling noise when running.
After reading dozens of similar problems on here about the Vornado fans squealing (and rattling) it seems they are in need of some 3-in-1 oil for the bearings and any moving parts in and around the motor area.
Also good to keep the fan clean by wiping down and removing front grill and the fan blade...A high pressure duster or spray air canister for the motor body etc. should get out any dust inside the unit.
good luck!
Oct 19, 2010 | Vornado 785 Stand (Pedestal) Fan
I have a 2001 Sonata. I have a squeeling pulley.
It sounds like you have a worn or streched belt making the sqeeling noise. Whenever you turn on a
device in the car that draws a fair amount of voltage
ie. a/c or headlights it will cause increased drag on
the alternator and if you have a loose/worn or glazed
belt, it can slip around the pully making the squeel.
To adjust the alt-a/c belt loosen the mounting bolts
on the tensioner, then use the adjuster bolt behind
the tensioner pully to loosen and tighten the belt.
Be sure to check the belt for cracks bald spots etc.
While the belt is loose spin the pullys to make sure
they all spin freely. Also I would replace the belt just
to be sure. Hope this helps
Jul 04, 2010 | 2001 Hyundai Sonata
Making squeeling noises and center devider is hot
Your condenser fan underneath the unit is probably making the noise and is not turning fast enough. When that fan don't work when the compressor runs you get the heat in the center divider and possible loose cooling efficiency.
Jan 19, 2010 | Whirlpool ED5FHEXMQ Side by Side...
Is my car ok to drive with a broken fan or AC belt?
Open the hood and start the car with the a/c off. Do all the components running on the drive belt seem to be working ok?
Turn on the a/c and check to see if the symptoms repeat themselves...
If with the a/c off everything is ok, then you're probably fine to drive until you can get the a/c unit serviced.
If the symptoms are happening with the ac off, then it could be an idler pulley or a water pump or alternator, or powersteering.
Best bet is to open the hood and do a bit of inspection/investigation with motor running.
Jul 01, 2009 | Honda Civic Cars & Trucks
Squeeling fan motor
Try this web site they are located in the city I live in and ship anywhere in the world. Be sure to get the size of fan motor 1/3 hp ect. You can get all the info off the data plate on the side of the motor. And also get a new capacitor they are only 5 bucks. The motor will run you 125. Ball parkish
Mar 11, 2009 | DeLonghi PAC85 Portable Air Conditioner
So, i start my 95 nissan pathfinder up, and one of the belts starts squeeling, (fan belt?) and after the squeeling I can hear a slightly metalic "buzzing" comming from (what I think is an engine pulley)
Get a Can of Fan Belt Dressing at your Auto Parts Store and spray this on your Belt. It will Make the Belt Quiet ehough that we can Narrow down the Other Problem. Let me Know! Please Rate my Response, I need all the Help That I can Get! Thanks!
Jan 27, 2009 | 1995 Nissan Pathfinder
Squeeling noise coming from AC, compressor is on, fan not turning
The squealing noise is coming from the compressor. This noise is common when the unit reaches extreamly high pressures. The pressure is most likely high because the fan is not running. Since you can spin the motor it could be that the motor has damaged windings. Leave the unit off until the repairs are made to ensure no further damage to the compressor. You will need a multi meter and some experience reading wiring diagrams to properly diagnose the system. You can perform an amp draw on the motor to see if it is in spec. You can measure the volts to the motor and see if they are in spec. Finally the contactor can be measured with the proper meter to see if it is working properly.
My suggestion is to have the Motor and capacitor both replaced. Also inspect the wiring in the condenser electrical compartment for any signs of damage or burning.
Jun 17, 2008 | Carrier 38CKC042 Air Conditioner
Squeeled, then hot on exterior
normally squeeling sounds from the freezer is evapurators fan motors... need to pull back panel off freezer and check out fan motor
Sep 03, 2007 | Whirlpool 26.6 cu. ft. Side-by-Side...
Squeeling noise
It could be just a dry belt and pulley. You could try the old squeeking car fan belt trick and rub soap on the belt. You can even buy sticks of anti-squeek from automobile outlets.
May 10, 2007 | Maytag Performa PAV2200
Samsung HT-Q100 System Logo
70 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
