Question about Sunbeam Mr. Coffee& Programable Coffeemaker (FTX 25-1)
No power to my ftx41.. cord and outlet are fine? is there a fuse inside?
My apollo microwave/ convection oven touch pad is not lit
First things first friend. Make sure there's power on the outlet it's plugged in to. Try another outlet or extension cord from another outlet. If still no light, replace the fuse inside the panel. Possible a power spike popped the fuse.
Jun 30, 2014 | Vehicle Parts & Accessories
My TV won't turn on. It was fine this afternoon and when I tried to put in on tonight, nothing.
The key here is does the red power light come on? If not follow power cord inside to the fuse that is directly in line with the cord.
If other let me know.
Apr 23, 2012 | Hitachi 51F510 51" Rear Projection...
Red light is on in the back of my t300 tower speakers
That is the standby mode but if its not kicking out of standby mode it could be a fuse issue
The T300 uses a 2.5A fuse.
To replace the fuse:
1. Unplug the AC cord from the AC power source,
then remove the AC power cord from the speaker's
power connector.
2. Remove the fuse cap with a small, flat blade screwdriver
(see diagram 2).
3. Remove the fuse from the fuse cap
(see diagram 3).
4. Replace the fuse inside fuse cap with another metric
5X20mm size fuse
5. Replace the fuse inside the cap, replace the fuse
and cap in the power connector (see diagram 5).
6. Connect the AC power cord to the speaker and
raise it upright.
7. Connect the power cord to an AC power outlet
Jun 01, 2011 | Cambridge Soundworks ton Theater T300 Home...
Television has no power. outlet has power and cord from outlet to television has power. is there a fuse?
All telivisions has fuses inside. Some of them has one, and some has two. If your tv doesn't power on, and power chord and outlet is ok, surely the fuse inside may blown out. There may be some reason for the blowing of fuse. Fuses are used inside tvs are for protection purposes. f any overvoltage or over current taken by the system, the fuse will blow out. you must fist find out the resom for the bowing of fuse. New fuse must be put in only after that check. Otherwise you will spoil the whole circut board inside the tv irrepairable. Concat a service personnal, and let him do that. Ok.
Remember, different tvs have different power ratings. Must select proper fuse according to the ratings.
Oct 13, 2010 | RCA 32F531T 32" TV
The microwave does not react what so ever. Checked the fuse and its fine, what could be the problem? please help
Is there power at the outlet? You say you checked the fuse ... is that the one inside the machine? Is the outlet protected by a GFI (reset for a GFI is on the GFI)? A GFI looks like a ordinary outlet but is very sensitive to electrical irregularities. Your circuit breaker may be on or your power panel fuse may be fine and the fuse inside your oven may be fine. If the GFI is popped, you have no power.
Try some other electrical device in the outlet. Does it work? Try an extension cord from a known hot outlet?
Beyond these tips, you may need professional help with this.
Thanks for your interest in FixYa.com
Jan 22, 2010 | LG LMV1630ST Microwave Oven
No power to tv - but ac cord and wall outlet are fine though
hello the glass fuse inside the tv might blew make sure the tv unpluged take the back in the power supply you should see a glass fuse if the fuse is black then it's blew if you put another 1 in and it blows again then you have a dead short somewhere
shaun
Nov 06, 2009 | Philips 60PW9363 60" Rear Projection...
I have a trutech undercounter mount DVD/TV combo. It was working fine, and all of a sudden it turned off and will not come back on. We checked the outlet and it is fine.
Unplug the power cord from wall outlet and take the unit apart follow the power cord inside the unit it goes to the fuse. Check the fuse most of the time the fuse is bad.
Jul 22, 2009 | TruTech LMD-5702RT Portable DVD Player
Ac just stop working. we check the outlet and it is fine. help me please, diane
If you have power to your outlet. The problem is inside the unit. Does the fan run? If it does not sounds like a blown fuse or control problem in the unit. Does the power cord have a reset button on it if so push it. It is ground fault surge protector.
Jul 14, 2009 | Maytag Heating & Cooling
NO POWER
Inside the microwave is a fuse. If you can, try plugging the microwave into a different outlet (use an extension cord). If it does not power on, you have likely blow the fuse. If you are technical, you may look into replacing the fuse yourself (you will have to remove some parts of the microwave exterior to get to the fuse). Otherwise, if no longer in warranty, you will need to have a shop or handyman replace fuse.
Mar 29, 2008 | Microwave Ovens
Motor won't turn on
Hi , Try to check with multi tester the power cord ,test the two tips of male outlet switch on tested read the continuity /if not reading ,pulout if push type /if permanent open cover below test the test the cord inside to the male plug if does not response cord is problem,check also fuse test both end of fuse not reading fuse buste then replace thats all goodluck.
Nov 12, 2007 | KitchenAid KSB5 Professional Stainless...
Sunbeam Mr. Coffee& Programable Coffeemaker (FTX 25-1) Logo
41 people viewed this question
Top Sunbeam Coffee Makers & Espresso Machines Experts
ray gallant
Gil Shultz
rhodesworks
Are you a Sunbeam Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
