Question about Euro-Pro NV31 Infinity Vacuum
NO SUCTION/RED LIGHT ON INFINITY MODEL BAGLESS VACUUM
I have same exact problem this month with the INFINITY vacuum cleaner, red light keeps blinking and no suction.
What do I do?
I've cleaned it out several times.
reddevil6
  • 1673 Answers
SOURCE: remove suction motor on rainbow vacuum
Take off the water tank, remove the screw, should be four, that will separate the 2 pieces, remove the rubber seal, remove the screws, 8 If I remember, disconnect the wires to the motor, it should pull out. Replace motor, hook up the wires, screw it back together, glue the water seal back on.
Posted on Jan 05, 2008
SOURCE: bad suction on bissell powerforce bagless vacuum
I took the bottom apart and it needed a new belt and that was the problem so it's fixed.
Posted on Jan 17, 2009
  • 134 Answers
SOURCE: Infinity Shark Vacuum
YOU HAVE BROKEN THE BELT, ORDER ONE FROM HERE
http://www.sharkvac.com/partsearch.aspx?CatID=cxmdqvOilfw%3d
Posted on Feb 14, 2009
juststinks
  • 98 Answers
SOURCE: Hoover Bagless WindTunnel vacuum cleaner.
very easy. you have clog. take the brush off look where the hole is thats where the clog is. it might be in there you might have to take the housing off of the motor
Posted on May 08, 2009
  • 8404 Answers
SOURCE: No suction - Infinity Shark Vacuum NV31C
You might try sucking the sose out with another vacum from the wrong way. You might be able to remove the hose and push a broom handle or stiff wire through. If you have compressed air available, you could try that, outside.
Im sure you have a clog and if you remove it, you will be back in business.
Thanks for your interest in FizYa.com
Posted on Dec 11, 2009
Attachment of vacuum base to handle
yes friction and the air suction presure keep the head and the handle together.
Jul 25, 2008 | Hoover S2220 Flair Bagless Upright Vacuum
When I turn on my dyson animal vacuum the red light flashes on and off and there is no suction
I think you have a blocked pipe somewhere. I use a large marble to drop through the pipes to see where the problem is.
Mar 11, 2014 | Dyson DC14 Animal Bagless Upright Cyclonic...
Red power light blinks even with completely clean canister and filter
Check for a filter where the air blows out of the machine. Could be clogged.
Jul 26, 2013 | Hoover S3755 WindTunnel Bagless Canister...
Vacuum roller won't turn and there's no suctions. Red light Doesn't blink
go to http://www.dyson.com/
get the support and download the model, troubleshooting, video for your trouble.
God bless you
Sep 16, 2012 | Dyson DC28 Animal Bagless Upright Vacuum
What is the blinking red light on the top of the vacuum
red light blinks when filter needs to b change hope this help thanks for reading
Jan 06, 2012 | Euro-Pro NV31 Infinity Vacuum
Hoover tc5238 bagless cylinder vacuum cleaner - no suction
You have a clogged hose. Sometimes a Q-tip or something like that gets sucked up and then stuff jams up against it. You can use a long stiff wire with a hook bent in the end to reach the jam and work it loose. Just be very careful not to poke the wire through the hose! Work slowly and get the clog out a bit at a time.
The clogged hose would also account for the red light.
Apr 08, 2009 | Vacuums
Red light for HIPPA filter won't go off
Red light is sign of reduced suction due to a blokage of some sort. If you are sure the filter is thoroughly cleaned, check the hose, wand, and the nozzle connector for obstructions of any kind.
Oct 25, 2008 | Hoover S3755 WindTunnel Bagless Canister...
Euro-Pro NV31 Infinity Vacuum Logo
357 people viewed this question
Top Euro-Pro Vacuums Experts
Dennis Key
Dennis Key
Are you an Euro-Pro Vacuum Expert? Answer questions, earn points and help others
