Question about Goldstar MV-1501 Microwave Oven
Goldstar Microwave The micowave stopped heating and making a funny little noise, however everything else is working just fine. The turntable, lights, clock, timer, fan, etc. is working. Any thoughts?
  • 833 Answers
Could be the relay, an internal fuse. With the power off, open up the key panel and search for a fuse. Also, there are thermo sensors black, diameter of a dime and 3/8 inch thick with two wires. Check the fuse and replace if necessary. The thermo can be jumped out to test. Remove the wires, use a paper clip between them and tape it up. Briefly turn the unit on. Replace if it works now. The thermo is generally clamped to the wall of the oven behind the key panel. Never run without the thermo sensor.
Posted on Dec 19, 2007
LG MS-1943ALT Micowave not working, light, fan and turntable all work, no heat
From the decription that you have provided, the magnetron is highly suspect and is the most expensive part to replace, cheaper to replace the microwave oven in the long run.
Sep 06, 2011 | LG Microwave Ovens
The turntable runs when the door is shut and the oven is not turned on. When the door is open the turntalbe stops and the light comes on. the heating part of the oven is fine.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
Dec 09, 2010 | Goldstar MV-1501 Microwave Oven
MICROWAVE NOT HEATING
Most likely you have a magnetron problem. Easy to replace (DYI) but make sure the high voltage capacitor is fully discharged first against the case.
Dec 11, 2009 | Kenmore 62622 Microwave Oven
Can't heat food
So we can help you, please post a NEW question, and please include your brand name and the full model number from the tag in or on the unit, as well as the answers to these questions:
When you try to microwave are the inside light, internal cooling fan and turntable all working?
Is there any unusual noise or is it louder or quieter than normal?
A loud buzz, hum, or groan is usually a shorted high voltage rectifier diode, but a sound like gurgling into an empty coffee mug is one symptom of a failed magnetron, and yet the mag can be bad without that sound.
We have a sound clip of what a microwave should sound like when the cooling fan and high voltage section are working.
Oct 11, 2009 | Goldstar Microwave Ovens
Have GE JVM2050 over the range microwave, which stopped heating food and water since this morning. All other functions including light, key pad, clock, turntable work normal. The magnetron sound also
if everything works except the heating, it is most likely the mag tube is on its way out.........that is the most common reason for it not too cook.......since the microwave is a GE and it is 3.5 years old, i would say you are better off buying a new microwave, the mag tube starts at around $70.00 and up + the labor it costs too have a service person put it in........around another $60.00
May 02, 2009 | GE JVM2050 Microwave Oven
My goldstar mv1501B won't heat anything. What' wrong?
everything works except the heating system what shell i do?
Mar 25, 2009 | Goldstar MV-1501 Microwave Oven
Everything works except the cooking part/no heating/turntable not turning, help!
you may have gotten a power surge and that can cause some funny things to happen, 1st is there power to the oven, 2nd if so there may be an internal fuse protector built in to the oven, check with the manual for anything of that sort listed. if not you may have to take it in and have it repaired by a pro. there is a lot of voltage in these ovens and unless you know what you are doing a person could get hurt
Jan 03, 2009 | Whirlpool GH4155XP Microwave Oven
Goldstart Microwave Model #MV1526 1000w Everything works, but does not heat up. Goldstar MAL 783W Same problem as for another Goldstar I saw here. light comes on, turntable turns, and to answer the...
With the symptoms you have, I would most strongly suspect a shorted high voltage rectifier diode or a bad magnetron, or a loose and possibly corroded connection on the magnetron's terminal.
The diode is a fairly cheap fix, and the mag will cost more.
The service manual can be downloaded here.
Here are some links you or someone you know can use for test help, but read their safety warnings first:
http://www.gallawa.com/microtech/diode.html
(if it's not shorted or burned, it's probably okay)
http://www.gallawa.com/microtech/mag_test.html
http://www.gallawa.com/microtech/xformer.html
To order Goldstar / L.G. parts, visit Vance Baldwin Electronics. You'll probably have to call them.
Dec 27, 2008 | Goldstar MA-782M Microwave Oven
SPORADIC HEATING
check highvoltage crcuit ,and check fan, and turntable motor,
Oct 18, 2007 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Goldstar MV-1501 Microwave Oven Logo
229 people viewed this question
Top Goldstar Microwave Ovens Experts
William Miller
William Miller
Mike
Gerry Harvey
Gerry Harvey
Are you a Goldstar Microwave Oven Expert? Answer questions, earn points and help others
