Question about Cameras
Cannon powershot sd300 displays in lower left hand corner E18. How do I fix this problem
  • 75 Answers
SOURCE: E18
E18 indicates a lens or "optical unit" problem. In other words your zoom lens won't function correctly. Canon will be more than willing to look after you.
Posted on Mar 30, 2007
t00nz
  • 4738 Answers
SOURCE: canon powershot sd300 e18 error
The following blog outlines some repair options for a lens error. They won't work for all cases, but they're worth a try if the camera's no longer under warranty:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on May 17, 2008
  • 15 Answers
SOURCE: camera frozen, emits a buzz and "E18" in the lower left hand corner
Assuming you have tried the repair people on this site first, and need to follow it up further, I have found a site which gives some insight and proposes a fix if you would like to view it, it's at www.e18error.com They explain the problem like so:
Canon E18 error happens when the lens gets stuck while trying to extend. The camera will beep a few times and the LCD will display a little E18 in the lower-left corner. The lens gets stuck in the extended position, and refuses to move either to focus the lens or to retract when powered off.
Apparently, people who posted about this incident on forums say they had to send the camera for repair and that Canon has horrible customer support and response time.
They also say how you may be able to fix it yourself - which is nice - well worth a visit! Hope this helps
Posted on Sep 02, 2008
Kiln Man
  • 5 Answers
SOURCE: camera shuts off after E18 error code
You have most likely dropped the camera or banged it against something while the lens was out. This situation causes the brass pinion gear to shear teeth off the plastic ring gear on the Inner Lens Housing. It may also cause the guide pins to jump their track. If this is the case the repair bill usually exceeds the value of the camera and you are probably better off selling it for parts on eBay and getting a new higher resolution camera.
Posted on Jan 01, 2010
  • 1382 Answers
SOURCE: Cannon Powershot S21S is stuck on on/ A message
"E18" indicates an error that involves the lens unit or lens cover in your camera .This error appears where the lens is prevented from properly extending or retracting .The error may also be displayed if the lens camera has been subjected to an external shock, or if a foreign substance (i.e. liquid, sand, dirt) enters the camera.Hold the camera so that your fingers do not touch the lens unit when you are shooting. Make sure the camera is off before the camera is placed back in the case. Exercise caution to ensure that the camera does not accidentally power on while the camera is stored inside the case.If you cannot clear the error code by turning the camera off and then on again, or if the error code is displayed frequently, a camera malfunction may have occurred and might require service from canon.Or else try pressing the power button on and held it down while extending the zoom lens. The lens will extend out and the camera will be freed from the error.
Thank you !!
Posted on Jun 30, 2010
Tip
Working with E18 and cannon cameras
he E18 seems to be a significant flaw in an otherwise great camera.
It is a flaw well know by users of Canon Powershot and Ixus cameras and is currently not acknowledged by Canon as a flaw in camera design.
HOW IT ALL WORKS:
The problem usually happens because dirt or sand get into the lens mechanism. But it seems that more and more people are showing, who took great care of their camera, and still started receiving E18 errors.
It seems that the problems have been happening with the following types of Canon cameras:
- Powershot A40
- Powershot A60
- Powershot A70
- Powershot A75
- Powershot A80
- Powershot A85
- Powershot A95
- Powershot A400
- Powershot A410
- Powershot A430
- Powershot A510
- Powershot A520
- Powershot A530
- Powershot A540
- Powershot A610
- Powershot A620
- Powershot S1 IS
- Powershot S2 IS
- Powershot S10
- Powershot S30
- Powershot S40
- Powershot S45
- Powershot S50
- Powershot S60
- Powershot S70
- Powershot S80
- Powershot S400
- Powershot S410
- Powershot S500
- S100 / Digital Ixus
- S110 / Digital Ixus V
- S200 / Digital Ixus V2
- S230 / Digital Ixus V3
- S330 / Digital Ixus 330
- S400 / Digital Ixus 400
- S410 / Digital Ixus 430
- S450 / Digital Ixus 55
- S500 / Digital Ixus 500
- S550 / Digital Ixus 750
- SD20 / Digital Ixus i5
- SD30 / Digital Ixus i Zoom
- SD100 / Digital Ixus ii
- SD110 / Digital Ixus iis
- SD200 / Digital Ixus 30
- SD300 / Digital Ixus 40
- SD400 / Digital Ixus 50
- SD450 / Digital Ixus 55
- SD500 / Digital Ixus 700
- SD550 / Digital Ixus 750
- SD600 / Digital Ixus 60
- SD630 / Digital Ixus 65
- SD700 / Digital Ixus 800
- SD800 / Digital Ixus 850
- SD900 / Digital Ixus 900
Instructions
If your camera is still under warranty, the best thing you can do is to take it to the nearest official Canon repair shop and Canon should fix it for free.
If your camera is out of warranty, or if Canon refuses to repair it for free (happens sometimes if for example they suspect the camera has not been treated properly) you can try some of the methods listed here to repair it yourself. These simple methods have helped a lot of people fix their cameras.
Before trying any of the suggestions, make sure your Canon has fresh batteries and it is in recording mode.
1) Remove the batteries from the camera, wait for a couple of minutes, then put them back in and turn the camera on.
2) Try compressed air. With a fine tip blow off gun and dry compressed air (20 lbs) set the tip between the lens turret and the camera body and turn on the air while moving the tip around the lens. It should remove all dust and sand. Turn the camera on and it should function fine.
3) Another method is to tap the padded USB cover part on a hard surface, for example, a desk. It sounds so simple, but very often in works.
4) Try forcing the camera lens:
Turn off the camera. Place it on the back with the lens facing up and take a look at the spacing between the lens and the lens housing. If you notice that the gap is not even all the way around the lens, the problem should be easy to fix. This type of a problem usually occurs if the camera was dropped while the lens was extended.
Simply - VERY GENTLY - press down the lens on the side where the gap is the biggest. You should hear a "click" as it pops back into place. Try powering the camera back on.
If the lens doesn't extend at all or it extends, and then retracts again, do the following. Turn the camera off. Take the camera in one hand and with the other gently take one part of the lens and gently move it round in a circular movement. Do so with both sections of the lens. You will hear a "click" as it pops back in place. Power the camera on.
Another version of this fix would be to pull and twist on the largest ring of the lens while turning the camera on. Listen for a "click". If at first the focus seems to be off, turn the camera on and off and take lots of pictures, close ups and distance. Focus should slowly start improving.
5) If that doesn't work, there is an online guide for dismantling Canon cameras and fixing the E18 error. (NOTE: Try this only if your camera is no longer under warranty!) It is a great guide with pictures and it can be found here.
There are 2 other guides, one Bulgarian and one Estonian with the take apart procedure for Canon cameras. They are not in english but have a lot of pictures which help with the process.
- Bulgarian guide
- Estonian guide
on Jan 03, 2010 | Cameras
What does E18 mean?
Canon E18 error happens when the lens gets stuck while trying to extend. The camera will beep a few times and the LCD will display a little E18 in the lower-left corner. The lens gets stuck in the extended position, and refuses to move either to focus the lens or to retract when powered off. This is caused by dirt in between the telescoping portions of the lens. You can clean this with compressed air, generally. Blow air all around the turret sections of the lens. you can also GENTLY push the lens inward ( have the lens extended and take the battery out... then push inward...)
Jul 10, 2009 | Canon PowerShot S50 Digital Camera
When I turn on my PowerShot A70, it comes on and immediately shuts itself off and the Error E18 appears on the screen.
Canon Powershot's error E18 has to do with the lens:
If it appears on a black LCD with E18 written on the corner, it is mostly due to the lens getting stuck while trying to extend. The camera will beep a few times and the LCD will display a little E18 in the lower-left corner. The lens gets stuck in the extended position, and refuses to move either to focus the lens or to retract when powered off.
I am giving below a link which will help you with E18 problem.
http://www.e18error.com/repair.html
Hope this helps, let me know if you have a proble.
Please do rate and thanks for using FixYa and Best fo luck to get you camera out of E18!
Mar 04, 2009 | Canon PowerShot A70 Digital Camera
Camera won't function - "E18" (Canon PowerShot S230)
Try lightly tapping lens on a hard surface. This sometimes reseats the lens. If this does not work take to bits and reassemble.
Dec 13, 2008 | Canon PowerShot A75 Digital Camera
E18 on Canon Powershot A95
take a look at e18error.com website for more info
Jul 30, 2008 | Canon PowerShot A95 Digital Camera
Camera frozen, emits a buzz and "E18" in the lower left hand corner
Nov 28, 2007 | Canon PowerShot S410 / IXUS 430 Digital...
Unusable
This is a hardware problem common with many Canon cameras. Unfortunately, there is no easy way to fix this. Canon can fix it for you, but they charge more to fix it than it would probably cost to replace the camera. There are entire sites dedicated to those who've had this error, but there is no way to fix it short of sending it in to Canon. One such site is here: http://e18.bitnet.cx/comments.php
Aug 28, 2007 | Canon PowerShot S410 / IXUS 430 Digital...
Camera was dropped, lens will not retract, when on/off button is pressed the initial screen and sound appear but then the camera makes a kind of warning sound and E18 appears in the lower left hand co
Perhaps the lens got bumped (if the camera was one when it was dropped) and is out of place. Mine did the same and I sent it in (it was within warranty) and Canon fixed it.
Mar 18, 2007 | Canon PowerShot SD100 / IXUS II Digital...
Problem with my camera
Your lens is jammed, and needs to be repaired or replaced.
Sep 04, 2006 | Canon PowerShot SD300 / IXUS 40 Digital...
Cameras Logo
20 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
