Question about RCA HD52W59 HDTV Projection Television
RCA D52w15 will not turn on, flashes three times.
My RCA D52w15, flasehes three times then cuts off. No picture or sound. Help!!!
    Genius:
  • 1,112 Answers
Replace you flyback transformer and Horizontal Output Transistor
Posted on Oct 05, 2009
Where is the lamp on an rca d52w15 tv?
That model doesnt have a lamp. They have three CRTs ( Picture Tubes) instaed. You can get the parts for your model at www.tvrepairworld.com. If you have sound but no picture youre needing a deflection board, same item if the set is dead or if the power led flashes three timnes slowly. They all indicate a bad deflection board.
Aug 08, 2011 | RCA D52W19 52" Rear Projection Television
D52w15 comes on then shuts off
Hi, thank you for visit fix ya.
This is a common problem on this kind tv.
Replace capacitors on power supply.
22000 uf 16V and 220uf 16 V; upgrade to 35V.
For parts, go to:
http://www.encompassparts.com/
Any question I will be here.
Thank you
Jul 28, 2009 | RCA D52W15 TV
My tv not turn on
you will need to replace the flyback number 259296 and CP150 you can get the parts at the following link with free installation instructions.
http://servicemanuals.vstore.ca/
Mar 13, 2009 | RCA D52W19 52" Rear Projection Television
Please help
I suspect if you have green lines .you have a bad crt. there are three tubes red green and blue i suspect blue tube. tubes cost is around 300.00 to fix.
thanks doctor video
note sometimes you could adjust screen voltage located near the front grill black box . becareful high voltage ony a pro should do.
Jun 14, 2008 | RCA D52W15 TV
Rca hd tv d52w15
that model is famous for having bad flybacks. fortunately they arent exspensive and there easy to replace. you can get a new replacement at the following link for less than 50 bucks and they give free instructions on how to install it properly.
Jun 07, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Have a RCA D52W15 w/ ITC222 board. TV will turn on and stay on for about 20mins and then it will shut off. I have been trying to play an Xbox hooked up through component cables. I even tried not connecting...
Take a good look at the power/deflection board. The one on the left as you are looking the back. You will find 2 ribbon cables that connect the power/deflection board to the small signal board (the one on the right). Look at the connector that the ribbon cables plug into. If they are black in color that is good. If they are white, that is bad. These connectors do cause intermittant power problems ( or a dead set). They need to be replaced. If they are black, take it to a repair shop.
Jun 06, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca 52 inch hdtv model D52W15
Blue CRT has shorts that causing the set to go into protective shutdown.
May 01, 2008 | RCA D52W15 TV
Rca d52w15
Most likely a bad flyback. It's a cheap part, but service people are even having a harder time getting ahold of one since they are failing often.
Apr 01, 2008 | RCA D52W15 TV
RCA D52W15 52 in. Rear Projection HDTV-Ready Television
The component connections are usually video only and the audio goes to separate connectors set aside for that input. Check your manual to make sure you have all the connections made.
Dec 02, 2007 | RCA D52W19 52" Rear Projection Television
Rca d52w15
Possible short and safety is keeping the set from burning up. A service man should be able to find the short hopefully in a small amount of time.
Nov 05, 2007 | RCA D52W15 TV
RCA HD52W59 HDTV Projection Television Logo
407 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
