Question about InFocus Proxima DP5900 Multimedia Projector
Bad convergence. do i need remote to converge unit? i can bring up menu and make those adj's by set top buttons. but i have three misaligned pic's
  • 2,237 Answers
There is no convergence for these. the lcd panels are fixed. if they are out of alignment, you'll need to replace the entire optical engine. first reset the settings to factory default. see if that helps.
Posted on Nov 10, 2009
Misaligned convergence on sony kp-65ws510
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Aug 08, 2010 | Sony KP-65WS510 65" Rear Projection...
Tip
Convergence Failure Test
CONVERGENCE PROBLEMS
This is a very common failure on these sets and a fairly simple DIY fix.
  • Screen looks 3D
  • TV shuts off after powering on - TV may also make a chirping noise.
Here are some pics of convergence problems.
Note: If you TV has as focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
47a7bc4.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from TvRepairKits.com
Their kits include a step by step instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
on Apr 18, 2010 | Televison & Video
My big screen panasonic tv has a double fuzzy picture what am I supposse to doto fix it
Adjust the convergence or reset it to factory default. Use only the remote when adjusting convergence. The front controls have no effect.
  1. Press action button to enter MENU.
  2. Navigate to SETUP.
  3. Scroll down to CONVERGE.
  4. Press VOL > to select.
  5. Press CH buttons to navigate up or down.
  6. Choose CONVERGENCE ADJ or RESET TO DEFAULT.
  7. Press VOL > to select.
  8. If CONVERGENCE ADJ is selected the align Green to Center screen will be displayed.
  9. Use the navigation buttons on the remote control to align the horizontal and vertical green lines on screen, with the cabinet reference marks on top center and left
    center of cabinet.
  10. Press ACTION button to display red center correction screen.
  11. Use the navigation buttons on the remote control to align the red cross with the white cross pattern at the center of the screen. To prevent picture tube damage do not leave test pattern on for an extended period of time.
  12. Press “0” on the remote control keypad to display the BLUE center correction screen, repeat procedure for adjusting blue. If needed press “0” again to return to RED correction screen. An adjusted cross pattern appears white with a minimum of color protrusion.
NINE POINT CONVERGENCE CORRECTION
Remote Control must be in TV mode.
  1. Press ACTION button to display red correction screen.
  2. Press the 1 through 9 keypad buttons on the remote control to select the desired convergence position.
  3. Use the navigation buttons to align the RED cross with the white cross pattern.
  4. Press “0” on the remote control keypad to display the BLUE correction screen, then repeat procedure.
  5. To exit press ACTION button repeatedly, then press CH up.
Nov 07, 2009 | Panasonic PT-47WX53 47" Rear Projection...
3-d pic and colors dont line up?
  • Screen looks 3D
Sep 30, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Blurry pic double pic
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
  • Screen looks 3D
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
Jul 10, 2009 | Hitachi 46F510 46" Projection HDTV
Convergence problem...
even if you had the original remote you
could not adj the pic for the failing convergance
chips. have a shop swap the chips . its
takes me about an hour + .price should be
no more then 175.00 part/labor. ps you
will may need to order the original remote.
to set up the convergance , wait have the
shop do that for you.
Jun 29, 2009 | Philips Magnavox 9P6034C 60" Rear...
Adjust color, need service manual
On controlls the foucus...the other the brightness. I would not mess with them. 99% of the time the problems is one of the two listed below...
You have one of two problems. Sometimes both.
Problem #1) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #1
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Problem #2)
Your TV may have a convergence failure. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
Using your original remote go-to the tv settings then goto the convergence section.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
0667c5f.pngSolution # 2
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Jun 05, 2009 | Philips 9P5544C 55" Rear Projection...
55 INCH TOSHIBA, CONVERGENCE WON'T STAY SET, WON'T ALIGN
Projection TV2_bing.gif sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung2_bing.gif, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith2_bing.gif, and others. You can get a convergenece repair kit from the link below.
Note: If you TV has as flash2_bing.gif focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
93a1209.pngCONVERGENCE SOLUTION
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
Jan 08, 2009 | Gateway PLSM50TV 50 in. Plasma Television
Convergence adjustment @ 52MH84
press mute on the remote then while pressing mute press menu on the set.then you navigate with the instructions below.
3. KEY FUNCTION IN THE SERVICE MODE
The following key entry during display of adjustment menu provides special functions.
Screen adjustment mode ON/OFF: TV (ANT)/VIDEO button (on TV)
Selection of the adjustment items : Channel s/t (on TV or Remote)
Change of the data value : Volume s/t (on TV or Remote)
Adjustment menu mode ON/OFF : MENU button (on TV)
Initialization of the memory (QA02) : RECALL+Channel button on TV (s)
Initialization of the self diagnostic data: RECALL+Channel button on TV (t)
“RCUT” selection : 1 button
“GCUT” selection : 2 button
“BCUT” selection : 3 button
“SCNT” selection : 4 button
“SCOL” selection : 5 button
“TNTC” selection : 6 button
Convergence adj : 7 button
Self diagnostic display : 9 button
Jan 21, 2008 | Televison & Video
RCA 52" Rear Projection P52930BL
You can adj. from the front panel of the set using the channel and vol. buttons,if the set you have has a ptk 195 chassis,check and make sure you have adj. projection tv in screens of the menu,in not the convergence power supply has failed,replace the reg on the board,part number is 215530
Oct 04, 2007 | RCA P52930BL 52" Rear Projection...
InFocus Proxima DP5900 Multimedia Projector Logo
622 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
