Home | Network Adapters | Cant connect to dns ser...
Network Adapters
Problem for Network Adapters
Generic problem for all Network Adapters
Cant connect to dns server
By chixenlegs on Dec 18, 2007
i just got a belkin adater and it connects to my network and has a ip address but it wont connect to the dns server and when it searches for a signal it says limeted or no connectivity while it says my network has good strength
i have tried ipconfig/flushdns and ipconfig/registerdns and still fails. Tried uninstalling and reinstalling first.
Same Problem
Nov 24, 2008
-   cant connect to the wireless G broadband router-   Guest
Solution #1
posted on Dec 18, 2007
Not Rated)
pasha19
Rank: Guru
Rating: 86%, 759 votes
When attemptin to attach to a wireless router
Either the SSID's match between your router and wireless adapter or your router is unencrypted and is attached to by the default configuration that uses the SSID it finds of an unencrypted network.
Now the two machines can talk to each other
If you request a dynamic IP address from the router it's DHCP can pass to your wireless adapter a various pieces of information including an IP Address, subnet mask, default gateway (the routers address in this case), adn DNS addresses (optional)
If you have static addressing in the wireless adapter you must provide to the wireless adapter a IP Address (NOT in the DHCP range of the router and not matching any other device attacned to the network, the same subnet mask as the router, the gateway address of the router and DNS addresses.
The first three of these allow you to communicate with the roouter and establish connectivity with it.
If the router's lan address is 192.168.0.1 and subnet mask is 255.255.255.0 then all addresses of devices connected to the router lan must begin 192.168.0.?. IF the DHCP server in the router can assign 192.168.0.100 - 192.168.0.149 as dynamic addresses. We can assign 192.168.0.2 - 192.168.0.99 as static IP addresses each to one and only one device. There are more potential static addresses above 192.168.0.149 but we will ignore them for this discussion.
The communication band (A, B, G, N) sable by for the router and wireless adapter must have at least one in common
Both the router and wireless adapter must have encryption set the same (WEP or WPA with the same passphrases and options)
If Mac Filtering is enabled on the router the MAC address of the wireless adapter must be loaded into the routers table of permitted MAC addresses.
If there is an error in the IP Address, Subnet Mask, Default Gateway?, encryption, or Mac Filtering, mismatched bands the wireless connection will fail as indicated with limited or no connectivity.
Even if all that works you still are not assured access to the internet.
The DNS addresses and default gateway are needed to be correct along with all the ISP's interface requirements for the wan or modem side of the router to be able to access the internet as and achieve the expected results such as accessing google.
If you would like to work through this step by step we can get you connected however I cannot see what you are doing and anything you do or change that I don't know about until we are done is likely to confuse the process. Please reply to this message if you wish for me to continue to assist.
Was this helpful?
Yes
No
Popular Solutions for Network Adapters
Questions and Unsolved Problems for Network Adapters
Answer
just loaded Ubuntu 9.10 on my Acer 3610 laptop. Need a driver for my Broadcom 802.11g PCI bus... (More)
Answer
can't get my wireless to work
Answer
need to open safe do not know number, looking for insurance papers and cannot open brinks home... (More)
Answer
i need a set up or where can i get the set up for wli2-pci-g54s by buffalo inc but its the air... (More)
Answer
I want to know about the problems of centralization and decentralization at Intel.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Network Adapters:
Top Network Adapter Experts
Rank: Guru Guru
Solutions: 1349
Experience: I have owned a computer networking sales and service company.
Ask Me
Find more Network Adapter Experts
Top Computer & Laptop Repair
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
