Question about Sony KP48V85GRAY 48" Rear Projection Television
KP-48V85 Sony with Technician diagnosed Convergence problem
I was just told by the Sony factory servicemen my TV has convergence problems to the tune of $350.
Can I buy a kit and do it myself cheaper? There is a yellow, blue, and red halo around every picture..
    Novelist:
    Champion:
  • 232 Answers
Kt33, of course you can do it yourself cheaper, IF you know how to solder & un-solder parts and IF you have a voltmeter and know how to use it. Convergence IC`s and probably a few support resistors will have to be removed and replaced. IF you can do the above I can look-up the IC`s for you but your on your own with the resistors until you tell me which ones you need if any, let me know, BMW Rider
Posted on Dec 18, 2007
My KP-62HS10 sony tv got picture smear and cook on right sight. i think some electronic part burn out ?
Tv have colors lines R,G,B mis alignment,have colors shadows pictures or 3D pictures look like?The tv have a problems known as a convergence problems,it dead.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost u $300-350 for parts and labors.
Oct 19, 2010 | Sony KP-61HS10 61" Rear Projection...
Sony KP 51 HW 40 - in left half of screen picture has double images, right half of screen picture is normal.
This problems very common on DLP Tvs.This problems known as a convergence problems,it dead.Colors lines R,G,B mis alignment,have colors shadows or 3D pictures.The tv convergence board is dead.Require to be replaced on the tv convergence board 2 STK convergence ICS and some or all it resistors to solved the tv convergence board problems,to solved tv convergence picture problems.The shop,will cost about $300-350 for parts and labors.
Sep 18, 2010 | Sony KP-51HW40 51" Rear Projection...
Sony KP-51WS510 picture swirls in the corners and is doubled
The tv have a problems known as a convergence problems,it dead.The tv have any colors lines R,G.B mis alignment,picture have colors shadows or 3D pictures.The tv convergence board the 2 STK convergence ICS and some or it resistors are dead.These parts on the tv convergence board,must be replaced to solved the tv convergence problems.The shop,will cost u $300-350 for parts and labors.
Sep 15, 2010 | Sony KP-51WS510 51" Rear Projection...
I have a red shadow in 3d on sony KP-46WT510 TV.
Ur convergence is dead.Problems:Are 3D colors,colors misaligns,and colors out of focus.Know how to solders?Must change 2 convergence ICS,and some or all the resistors.Tries Websites Tv repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300 for parts and labors.
Feb 17, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
Kp-46wt500
the pico fuse are the two little yellow resistor looking things under the heat fins of the convergence chips
Jan 03, 2009 | Sony KP-46WT500 46" Rear Projection...
How to change convergence ICs in Sony KP-57WS510 TV?
Replace Both STKs convergence ICs big black ics with number on them STK392-560.Parts 1-800-223-3205
Dec 20, 2008 | Sony KP-51WS510 51" Rear Projection...
Sony kp-41t65
The convergence IC's on your set have failed. There are several web pages that detail how you can replace these IC's by yourself. Do a websearch for convergence problems and you will find your instructions. This webpage gives instructions on replacing the IC's on a Mitsubishi but it is similar to the Sony:
http://www.techlore.com/article/22530/DIY-Repair-Replacing-Convergence-IC-s-on-a-Mitsubshi-TV-Set/
Nov 11, 2008 | Sony KP-41T65 41" Rear Projection...
Sony CONVERGENCE
are you experienced technician ? if you are not you are gone to mess up your tv you need to replace 2 IC's stk392-040 check power supply if still ok and get in to service mode to make the convergence aligment and is not that easy contac andrews electronics in CA they have squematic for
Mar 17, 2008 | Sony KP-53HS30 53" Rear Projection...
Blinking 4 times - Sony KP 51HW40
Hello scramble5,
This might be a convergence amplifier problem or a problem in the convergence coils. I would suggest that you have a qualified TV technician check this TV out. This problem is usually due to the convergence amplifiers malfunctioning, to replace then the two modules and their biasing resistors must be replaced.
I hope this helps
Thank you,
Shuttle83
Jan 27, 2008 | Sony KP-51HW40 51" Rear Projection...
Sony KP-48S65 48 in. Rear Projection: fine tune convergence
you will have to go in the service mode. be careful as you could damage the tv if wrong settings are changed. with the tv off push on the remote display 5 vol+ power. now hit the 1 button until you see pje fdis on the upper left. now push the 9 button to enter convergence. you should now have a cursor on the screen. usr the 3 button to switch colors. use the directional pad on remote to move the cursor and the enter button in the center of dir pad to select or deselct a point in the screen. push muting and then enter to save convergence. now restart the tv and all done
Sep 19, 2007 | Sony KP-48S65 48" Rear Projection...
Sony KP48V85GRAY 48" Rear Projection Television Logo
151 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
