Question about Frigidaire Ovens
  • 213 Answers
SOURCE: replacing broken oven door handle
whats the model number?
Posted on Nov 21, 2007
  • 288 Answers
SOURCE: Hotpoint range door doesn't unlock after the clean cycle.
It is possible that the lever has been bent somehow. If you can lift the top of the oven as if you were cleaning it. look at the lever mechanism, move it to the other position and push it back carefully, to bend it back. I have seen this happen a lot, people lean on the oven, the lever is in the open position and it is pushed a little bending it so when it is moved to close it doesn't go far enough to release it. I am assuming you have waited for the oven to cool down before you tried this first right?
Posted on Dec 06, 2007
  • 943 Answers
SOURCE: Electric oven only works on Broil
just one light. if its not the element, then you could have the oven thermostat. check that
Posted on Oct 13, 2008
  • 3463 Answers
SOURCE: belling oven door not closing fully
Hi. Yes, you will need to replace hinges, and possibly the hinge guides located inside the cookere.
Posted on Nov 20, 2008
  • 725 Answers
SOURCE: What does an F3 code mean on a Tappan
This is your oven temperature sensor on your Tappan Oven.
hese codes are designed to troubleshoot your appliances and prevent further electronic issues from happening to your unit.
It is a simple repair that you can repair yourself and you can save a ton of money, also!
Once this part has been replaced, you oven should close properly and work just fine.
Posted on Oct 20, 2009
  • 5 Answers
SOURCE: whirlpool electric oven problem
thermal fuse to board blows, relays turn fans off, the thermal cut out on rear of oven kills element. change both fuses, install new style oversized blower.
Posted on Oct 26, 2009
0 characters
1 Points
Replace oven door handle
Hi blah_blah894 - Are you trying to replace the oven door handle or need part number? If so, I would like to further assist you but in order to do so; do you happen to have the exact model number?
Sep 27, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
Oven door handle is loose on Model RF366BXD self cleaning range, how do we tighten the door handle?
Extend your door hinges and remove entirely over to a table or other flat surface where you can do a step-by-step dis-assembly. Unfortunately, to get at the interior of the handle unit, it's the final stage of the taking apart. Begin by removing the bolts at the bottom of the door, then the main panel and side flanges can be removed. (You can give your glass a good cleaning at this point also.) There are 2 bolts to remove to free up the handle unit, and now you can easily tighten (or replace as needed) the 2 pairs of handle bolts. Reverse your order to re-assemble, and put your door back on the oven. It's not as bad an exercise as it would appear. Just take your time and watch what you're doing. I used the hinges as a shim, and had it laid out on a pool table for easy, elevated examination.
Dec 09, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
GE Oven door lock 'engaged' while door was open and door will not close - how do I release the lock?
If your oven door has gotten bent or warped (maybe you rested something heavy on it...), you need to remove the door, disassemble it, and straighten it. You can lift most oven doors off of their hinges by opening the door several inches to its first "stop," and lifting the entire door straight up. If the hinges have become worn, damaged, or bent, you probably need to replace them. We recommend replacing both hinges at the same time, to prevent uneven wear of the undamaged hinge.
Dec 06, 2010 | GE JTP27 Electric Double Oven
Took apart glass oven door on a whirlpool. Where
Hello, bd_lft_up.gif bd_top_bg.gif bd_rt_top.gif bd_lft_bg.gif OVEN DOOR bd_rt_bg.gif bd_wpl_oven_door1.gif bd_wpl_oven_door2.gif clear.gif bd_lft_btm.gif bd_btm_bg.gif bd_rt_btm.gif Oven Door
#1 -- Oven door liner
#2 -- Oven inner glass
#3 -- Oven door hinge
#4 -- Retainer, glass
#5 -- Bracket, handle
#6 -- Door glass seal, top
#7 -- Door glass seal, side
#8 -- Oven outer door glass
#9 -- Door handle
Hope this helps.
May 30, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
I did a self clean on my tappan electric oven; cant get the door to open.... what can i do?
MaryAnn, If you try to push the locking lever/handle towards the "lock" position first, then pull it back towards the open position, it should unlock for you.
However if that doesn't work, you can turn off the breaker for the electric range, in most electric panels, it is marked as "Range" or "Stove" but is typically a double pole 50 Amp Breaker (It takes up 2 spaces). If you look at the handles of the breakers, you should be able to see the numbers "50" on the handle.
Once you turn off the power, you should be able to unlock the oven. Some ranges require that the power be on in order to unlock it, but first try to open it with the power turned off, and it that doesn't work, turn the breaker back on and the door should be able to be unlocked.
Remember that it will take a little bit of effort to get the door to unlock in some cases, so give it a good tug.
Hope you find this Very Helpful and best regards!
Oct 25, 2009 | Tappan Ovens
Whirlpool oven door won't open.
You can try unplugging the over for a while and seeing if that helps. But if that doesn't help you will have to let the oven complete the cleaning cycle in order to regain use.
Jun 23, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
I accidently pressed self clean instead of boil on my oven
The oven door lock needs approximately 1 hour to cool down before the oven door can be opened after a self cleaning cycle has finished. If the lock does not open after the oven has cooled down, you can try....1) Unplugging the range or shut off the circuit breaker for 5 minutes. Plug the range back in or turn on the circuit breaker. Set the clock and try moving the door lock lever or opening the door. 2) Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever or opening the door.
Most ranges today use 3 different types of door is a solenoid controlled lock ( you hear a loud buzz noise when setting or unlocking the lock and has a arm that you must move to set the lock )...another is a heat sensitive lock ( has a arm that you must move to lock and un-lock, makes no noises and has a spring that slowly moves to lock the door will the oven is heating up )...Some locks are motorized ( no handle to move, the motor locks the door by it's self when you set the range for self clean )... If the motorized and heat sensitive locks fails to open after the self clean cycle, you must access the lock and move it yourself to open the door. On the free standing ranges, most times you must lift the cook top to access the lock mechanism. On built in ovens, the oven must be pulled out to remove the top access panel to get at the lock mechanism. Some build in ovens can have the control console removed to access the lock system. On the heat sensitive style of lock, there are no electrical parts to operate the lock, usually you will need to replace the lock. On the motorized style of lock, you will have to use a ohm/volt meter to test why the motor will not work. On the solenoid style of lock, the solenoid is often mounted on the back of the range and can be accessed by removing the rear panel, some may be mounted at the front, such as in a built in oven. The failure of the solenoid style of lock is normally caused by a bad lock solenoid. In order to get your door open, you must operate the door latch mechanism manually. Unplug or remove power from the range. Take the rear cover off the range. Locate the door latch assembly and operate it manually and open your door. Then check continuity of the solenoid. Some of the latch assemblies have micro switches to supply power also. You may need to check them. You should be able to get the door open and use your range until you can get a tech to repair if you can not repair yourself.
There may be a door activated* switch on the front face of the oven. In this case you may need to manually press that door switch with your finger while at the same time canceling the clean cycle to get the latch to retract so the door can close fully again.
*On -some- Frigidaire built ranges, the switch is located behind the right hand side panel and activated by the right hand door hinge. On this model, the side panel may need to be removed to access a malfunctioning door switch.
Please do rate the solution as FixYa and revert for further assistance.
Apr 27, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
KEBS208DSS6 doors wont close compleat
Place a hammer handle between the door and the frame at the hinge location.
Carefully apply pressure on the door to push the door closed.
This will often re-set range door hinges.
Mar 08, 2009 | KitchenAid KEBC208 Electric Double Oven
Cleaning Inside Glass Oven Door of KitchenAid KEMC308KSSO
To dismantle the kitchenaid pro line oven door: there is a lever over the hinges that attach a door to the oven. The lever is right on top of the hinge. Pull the lever up. When that lever is in the up position, you can pull the door out.
Jan 10, 2008 | KitchenAid Architect Series KEMC308KSS...
Ovens Logo
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
Michael Thomas
Michael Thomas
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
