Question about Panasonic KX-TG2432 Twin Cordless Phone
How do I erase numbers?
I am trying to figure out how to erase old stored phone numbers from my handset. Does anyone know how I do this? Thanks, Sandra C.
Enter the phone menu and the name/number you want to delete.
press the edit button and then press and hold the clear button till the stored number and name are erased
Posted on Mar 15, 2008
How do I erase speed dial phone numbers from a corded phone? GE No: 2-9267A
1. Pick up the handset.
2. Press the store button.
3. Press the memory location (0-9) to be erased.
4. Press delete for three seconds until the number in the display is erased.
5. Hang up the handset.
If you need a manual, you can download one at
http://www.home-electronics.net/ge/pc/IB/29267GE1_IB.pdf
Jul 15, 2011 | GE 29322GE1 Corded Phone
I have a VTECH phone model Vt 1122 and I do not have manual still and I need to know how to insert numbers in memory.
You can get the manual here. Here's what it says about storing numbers:
Storing a Phone Number in the One-Touch Memory Locations
  1. Lift the handset.
  2. Press the PROG button.
  3. Dial the telephone number you want to store (up to 16 digits).
  4. Press the one-touch button (M1, M2, M3) where you want to store the number.
Storing a Phone Number in the Two-Touch Memory Location
  1. Lift the handset
  4. Press the MEM button.
  5. Press the dial button (0 to 9) where you want to store the telephone number.
  6. Hang up the handset.
Please take a moment to rate this solution if it's what you needed. Thanks for using Fixya!
Jul 04, 2011 | Vtech Lands Phones
I have a samsung solstice SGH A887 and i bought the phone and it already had a security code set On it and i can't figure out what my security code is. i tried everything.
no worries it happens alot infact it happened to me on my samsung as well lol! its a quick fix but it will delete all your info:( i found the info at tmobile.com/forums but its universal on ALL samsungs!
f your Samsung handset has a security code or phone lock on it follow these steps to disable the code.
NOTE: This code is not used for Subsidy unlocks, Application Locks or PUK (PIN) code lock outs. Call Customer care for these.
A phone lock or security code on most Samsung handsets can be overridden by performing a full reset on the device. This will set the security codes on the handset back to the default eight zero's (00000000).
Important: This reset restores the original factory settings and will erase all downloaded content, including ringtones, images, programs, and contacts stored in the internal memory. It does not erase data stored on the SIM card or memory card (if available). Make sure you have backed up contacts, calendar appointments, and other data before continuing.
1. Power off the handset
2. Remove the battery
3. Remove the SIM card
4. Reinsert battery ONLY
5. Turn handset on
6. At the Insert SIM prompt screen enter the following code: *2767*2878#
NOTE: If using a handset that was released after July 2009 use this code: *2767*3855#
7. The handset should display E2P custom reset
8. Power off handset
9. Reinsert SIM card
10. Power on handset
11. The phone should be unlocked
NOTE: If you didn't get a E2P custom reset or a Full reset message on the handset your Samsung model may need an MCK code. You will have to call technical support for this code. Please have your IMEI number ready to expedite the process for this code. Your IMEI number is located on a label on the back of the phone,under the battery.
Dec 24, 2010 | Samsung Solstice SGHa887
I need to know how to program the numbers into the speed dial option. My mother's phone is a table set with large numbers #29267A ... close enough?
Before you store a telephone number in memory, make sure the dialing mode is
correctly set for the type of service you have. The default dialing mode is tone
(touch-tone), so if you have pulse (rotary) service, you must first change the dialing
mode. See “To Set the Dial Mode.” The following buttons can be stored into any
memory location: 0-9.
STORING FREQUENTLY CALLED NUMBERS
2.Press the store button.
3. Push the desired memory location button.
4. Press the store button.
5.Use the handset number keys to enter the telephone number (up to 16-digits)
and press the store button.
6.Hang up the handset.
NOTE: If you make a mistake, use the delete button to delete wrong digits.
CHANGING A STORED NUMBER
Repeat the storage sequence above. The new number replaces the old number at
the memory location.
ERASING A STORED NUMBER
3.Press the memory location (0-9) to be erased.
4.Press delete for three seconds until the number in the display is erased.
5.Hang up the handset.
DIALING FREQUENTLY CALLED NUMBERS
1. Pick up the handset and press the mem button.
2. Press 0-9 for the memory location. The number dials automatically.
OR
1. Pick up the handset and press the dial button.
2. Press the review button for the desired memory location.
3. Press the dial button to dial the number.
OR
1. Press dial button while the handset is still in the cradle.
2. Press the review button for the desired memory location, lift the handset and the
Download User Manual
If this information was helpful, please give me a big thumbs-up when you rate my answer. Thank you.
Feb 02, 2010 | GE 29267GE3 Corded Phone
Cable & Wireless CWB200H Speed Dial
1. lift the handset.
2.press store
3. pin in number to be phoned.
4. press store
5. press one of quick dial buttons
Mar 12, 2008 | Lands Phones
Emmerson Phone Manual EM2248
Emerson (EMSEM2646WH) I need to know how I can set up the speaker phone and in a way that will be clear and loud. I lost my manual, could you send another one to me?
thanks
Nov 05, 2007 | Emerson EMSEM2646WH Phone
Storing numbers in memory
1) Pick up the handset and press the STORE button
2) Dial in the number you wish to store
3) Press the STORE button again to indicate that you have completed the number
4) Press the location where you want to store the number (i.e. 1, 2, …9, or 0)
Oct 21, 2007 | Uniden EXP4241 (050633300466) Cordless...
Programming the "Memory Dialer"
You may try this: 1. Pick up the handset and listen for a dial tone. 2. Press and release the STORE button. 3. Enter the phone number(up to 16 digits)you want to store into memory(The telephone number will not dial out) 4. Press and release the STORE button. 5. Press a one-digit number(0 - 9)on the keypad to store the phone number into the desired memory location. 6. Hang up the phone by returning the handset to the handset cradle on the base. 7. To store more phone numbers in memory, repeat steps 1 - 6 Good Luck !!
Jun 27, 2007 | Northwestern Bell Classic Favorite 52860...
Handset unit keys sticking really bad
I have the kx-tg2248s panasonic phone and my keys stick also. I emailed Panasonic for a solution and they suggested I mail it to a service center for repair. But I don't know what I would do without a phone in the meantime. Can anybody help? It would be greatly appreciated!
Apr 10, 2007 | Panasonic KX-TG2336S Cordless Phone
Storing Speed Dial Phone Nmbers
Emergency/quick dial numbers: Pick up handset, push store, enter the phone number (it will not call the number), push store again, Push A,B or C. hand up handset. Frequently called numbers, pick up the handset, push store, enter the phone number, push store again, push key pad 1, or 2, etc. for memory location. Hang up handset. How to change a stored number. just repeat the sequence. How to clear a stored number, repeat the storage skip step 3 (do not enter the phone number). How to correct an error while storing, just hang up and repeat.
Feb 26, 2007 | GE Telephone pr521w
Panasonic KX-TG2432 Twin Cordless Phone Logo
231 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
