Question about SanDisk Sansa e250 MP3 Player
The blue light in the middle wher you change the volume and that only turns on how do i fix it
  • 820 Answers
How to get the player recovered from the 'blue ring' follow the steps on this link:
http://kb.sandisk.com/app/answers/detail/a_id/4
Only perform the actions that are related to the model and version
of your player ( see the back side for model and version)
With the general indication 'e200 series' is meant all versions and all players e.g. e250, e260 and e280.
Need more help ? Just post a comment.
Posted on Sep 28, 2009
Headset will not re-set according to instructions. Indicator light is half red, half blue. What should I do?
I had the same issue with green light always on and not turning off. Call button plus volume up button did not work when the unit was not plugged in. When I plugged the unit in to charge, the volume up and call button (together) did reset the unit.
Oct 14, 2015 | AUVIO Bluetooth Headphones
My Panasonic smart tv had a thin blue line running down the middle of the screen earlier today. When a tv show was playing the right side of the blue line was fuzzy. Tonight I came home and now when I turn...
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to both LCD & Plasma TV screen are given with illustrations. You can get an idea about the fault to an extent.
Mar 28, 2015 | Panasonic Televison & Video
How do i change a bulb on a zephyr verona range hood
I could not turn the bulb, and the rubber glove approach did not work. I unscrewed and removed the middle cover, which meant I could easily reach inside and turn the whole light bulb fixture.
Apr 18, 2014 | Zephyr Kitchen Ranges
How do I turn up the volume?
The volume keys are the silver keys on the top and bottom. Simply push the volume up button to adjust the volume If you are not sure which button is volume up, or simply want to change which is which, you can change the button orientation.
Here's how:
-Close the boom to turn the headset off.
-Press and hold down the desired "volume up" button and open the boom. Keep the button pressed until the indicator light flashes blue three times.
If you just want to see the user's manual it's here...MANUAL
Aug 18, 2010 | Motorola Mobility H710 Bluetooth Headset
Turn signal flasher
It's undre the dash, right under were thr radio sets. You have to drop the lower part of the dash. They set in the middle. They are round and one is the hazzard light the other the turn signal.
May 11, 2010 | 1995 Chevrolet Blazer
"The blue light around my volume dial does not light
Try resetting the receiver (you will lose your setup). I recently reset my receiver and the blue light returned. It's possible that the Audacity setup turns off the blue light because the volume is now being "regulated" by the equalizer.
Mar 26, 2009 | Onkyo TX-SR705 Receiver
Large Black Box Showing up in middle of screen.
Try and turn off the closed captioning. I had the same problem and it turned out that the closed captioning was on t1 instead of OFF. Hope this helps!!!!
Feb 19, 2009 | Zenith C27A24T 27" TV
Ipod shuffle second generation, volume has dropped to where the volume has to be at max just to hear it. Factory volume settings were never changed, it just kept getting quieter every time i used it. Do i...
Your battery might be going out. If you are sure that your battery is OK, then go to iTunes and make sure that you can see your iTunes library.
  1. Go to the menu bar and click on Edit. Then click on Select all. All of your music will be selected and turn blue.
  2. Right Click anywhere in the music library.
  3. You will get a message that asks if you want to edit all of your music library. You will click 'Yes'.
  4. A new window will open. There will be 4 tabs. Pick the one that says Options. There you will see a slider to adjust the volume in all of your music. The slider will be set in the middle. You can slide it to the right to about 80-90.
  5. Close your window. iTunes will begin changing the volume on all of your music.
  6. When it is finished, plug in your iPod and see how much different it sounds. Turn down the volumn on your iPod until you can readjust it.
Hope that helps.
Dec 08, 2008 | Apple iPod shuffle Second Gen. Silver (1...
Bright blue spot in the upper middle of the screen
Light Engine is bad, Hitachi might replace it for free if you had a repairman diagnois the problem
This TV type is junk
Aug 20, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Screen and volume problem
Hello, the problem regarding horizontal blue line can be around vertical output stage with IC(LA78045). Please check for cold soldering, resolder the suspected solderings. Best regards.
Apr 27, 2007 | Sony KP-46WT520 46" Rear Projection...
SanDisk Sansa e250 MP3 Player Logo
57 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
