Question about Water Heaters
My relief valve is leaking pretty bad. why is it dripping constantly?
  • 557 Answers
Before disassembling your valve try activating it a couple of times. Sometimes, especially if its dirt or sediment, it will clear the valve.
Posted on Sep 29, 2009
  • Water Heaters Master
  • 3,051 Answers
Hello there
the relief valve works on spring pressure
if the seat that seals the valve closed gets dirt or junk in it it will constantly lift and drip or leak
also if the spring gets weak will not work like it should so i would start their by removing the valve and dissasembeling the valve if you are positive that you can do itand check the spriing or the seal and replace as nessassary or just replace the valve they are not usually too expensive
ok best regards michael
Posted on Sep 28, 2009
  • Michael Thomas
    Michael Thomas Sep 28, 2009
    Hello there
Water dripping from blowpipe
It is normal for water to drip out sometimes from the pressure relief valve outlet pipe. If it drips continuously then open and shut the pressure relief valve several times so the pressure relief valve shuts off properly.
If this does not fix the dripping problem then the pressure relief valve is faulty and needs to be replaced.
Apr 02, 2013 | Water Heaters
Leaking hot waterheater relief valve
you can try opening it into a bucket most of them are threaded to hook a hose to it. opening it and closing it might fix the leak but if not just turn the power and water coming in and take a wrench and turn the old one out. and get a new one at your local hardware store or home supply store like a do it best store or lowes or home depot.
Dec 31, 2011 | Water Heaters
Pressure releif valve leaking
Hot water pressure relief valves serve two functions. The first is to remove high-pressure water from the hot water tank. The second function is to act as a high temperature valve to remove water that exceeds a predetermined point for the valve. Both of these relief settings are preset at the valve factory. Many pressure relief valves will come with a metal tag that identifies these release points. If you're attempting to remove the hot water heater pressure relief valve, pay careful attention to ensure that you replace with the correct valve.
Your hot water heater has a pressure relief valve safety mechanism. When pressure inside the water tank exceeds certain limitations, the valve opens up to allow the pressure to be released. A faulty pressure relief valve will not release excess pressure, which could cause extensive damage to your home. You should test the hot water heater pressure relief valve once every six months to ensure proper operation. If the pressure relief valve fails the test, replace the valve with a new one immediately
Locate the pressure relief valve on your hot water heater. The pressure relief valve has a lever handle on top with a drain pipe attached to it. The pressure relief valve is most often on the side of the water tank toward the top. Newer models of hot water heaters have the pressure relief valve on top of the water tank.
  • Inspect the area around the pressure relief valve for signs of leaking water. If there is leaking water near the relief valve connection, replace the relief valve. If no leaking is evident, proceed with testing the pressure valve.
  • 3
    Examine the area below the pressure relief valve drain pipe. Most water heater closets either have a drain in the floor below the pipe or the pipe is inserted into another pipe to direct the water out of the home. If the end of your drain pipe is not in another pipe or there is no drain in the floor, place a bucket under the drain pipe to catch water when you test the pressure relief valve.
  • 4
    Pull the lever handle on the top of the pressure relief valve up with your fingers. A working lever will lift up without difficulty.You should begin to hear water going through the drain pipe. Slowly release the lever to shut off the pressure relief valve. The pressure relief valve is good. If you did not hear water running through the drain pipe, lower the lever on the pressure relief valve and replace the valve. If the lever is difficult to raise, do not force the lever. Replace the pressure relief valve.
  • Now with all that said if you have a closed loop water supply system and you have a pressure vessal/expantion tank it may have gone bad and is making the TP valve leak. you can call your water provider to see if you have closed loop system.
    Feb 04, 2011 | Whirlpool Water Heaters
    I have a small leak and it is dripping on the ground
    You'll obviously have to determine where leak is coming from, then we can decide how to stop it. If it's the pressure relief valve outside, and it's only a small drip, that is normal, but you can try lifting arm on relief valve and cleaning it out a little to see if that helps clean it out. BE CAREFUL when water is hot, that you don't burn yourself, thus better to try it when cooled down. If it's dripping, or running out too much, it may be that water is too hot, or water pressure is too high as well, so check that as well. Usually smart to install a pressure regulator in line from hose to trailer. If your running off on board pump, not very likely that pressure is too high as they are usually set at 40-50 psi, which shouldn't cause that. If water doesn't feel hotter than before, then best to replace pressure relief valve, if that's where dripping (excessive) is coming from.
    Dec 07, 2010 | RTO Atwood Water Heater - 6 Gal LP
    It quit working and I removed panel and reset it.now it seems to make the water hoter and it is making constant noise and leeking a little from the pressure relief valve
    The pressure relief valve is bad if it is leaking due to too hot of temp or it has gone bad. If it is hotter turn down the temp on thermostat and see if it quits dripping..
    If it's making a noise it may be heating the water the way above the limit for the relief valve.
    If it is the relief valve they have them at most hardware stores and can be replaced. When installing use teflon tape on threads if this is the problem.
    May 21, 2010 | Water Heaters
    Pressure relief valve
    The pressure relief valve only leaks when there is excess pressure in the system, possible causes could be excessive static pressure, overheating, faulty pressure vessel or undersized pressure vessel.
    Apr 11, 2010 | Rheem 50 Gallon FVR NATGAS Water Heater...
    Boiler pressure
    If there is no leak anywhere in the system [pipes & radiators] Check the emergency pressure relief valve. It usually is at the base of the boiler and drains to outside [15mm pipe] where, if the valve leaks, water drips can be seen.. Looks similar to the picture with your query
    Renew the valve
    You can take it apart and clean it but I've never found that to be successful in the long term
    Dec 29, 2009 | Watts 3/4 Pressure Relief Valve
    Relief valve constantly releasing water.
    lower your thermostats a bit. If your temperature is set to the hottest setting, then chances are no relief valve will do
    Jan 08, 2009 | Rheem 50 Gallon FVR NATGAS Water Heater...
    Vulcan everhot water heater leaking at pressure relief valve
    look can look to wear the water nis comeing from
    Dec 13, 2008 | Water Heaters
    Water Heaters Logo
    95 people viewed this question
    Top Water Heaters Experts
    Donni Steen
    Gil Shultz
    Are you a Water Heater Expert? Answer questions, earn points and help others
