Question about Sharper Image Ionic Breeze 3.0 Air Purifier
Can someone tell me how the two wires in the bottom of the unit are supposed to be attached? I have not opened the unit, but see that one end of the two wires are attached to the two little plastic ''spool'' like things, and the other ends are loose and just unattached to anything. can I fix this if I open the unit, and how? thanks k.bradley, chicago
    President:
  • 1,489 Answers
The wires you see are the high voltage grid wires -- these burn thru and break -- the more often the unit is cleaned the longer these wires last, but 18 months max is my experience.
There is no easy way to fix this -- even if one does the complicated, extremely nerve wracking reapir (with titanium wire) the unit will fail again soon.
Far as I know, there is no longer a repair service for these units.
Charlie
Posted on Oct 01, 2009
I have an older model Flair unit. I took it apart to try and give it a good cleaning and noticed that there was a small glass bulb-looking part with one of the thin wires was broken. Of course the other...
It's attached to the pulse radio-wave ionizer. It comes on when the unit is on to show the radio wave is working. It's not needed and I've never seen a replacement but Radio Shack could probably help you replace it if you wanted.
Jun 23, 2011 | Ecoquest Flair Air Purifier
The string inside my ionic breeeze quadra is broken. Is it possible to fix it
Not so fast with the screwing part. Go to a music store, buy the G string wire(008)gauge- at least 41 inches long- for a guitar.
If you have a digital camera make a video/pics history of your dis-assembly steps.
Remove the ozone eliminator-by pulling it off the tower.
Start with the base 4 screws, followed by the 2 collar screws at the base.
NOTICE that there is a space between the two halves at the bottom. I paid NO attention to this space-boy did I ever try to snugly close that one before I looked at another one to see that this separation is there for a reason.
Next: remove the "TINY"12 screws - 6 on the front/back side of the units ribs-look for these.
Take pics of each step. You will be happy you did this.
Store all of these diff. screws in separate jars.
Open the unit now like a wallet. Notice that the sloped top control button/light module can now be removed. See those 2 black square plastic covers-they hide a spring and an upside down W shaped wire holder. The broken wire can now be removed. If you are lucky, you may be able to to twist your new wire-after pushing it through the cleaning bead -with the one going down to the bottom module. Mine was too brittle and broke apart as soon as I touched it.
Remember: The 2 wires you see are just one 41 inch long 008 gauge guitar string.
They thread through a signal contact bracket at the bottom of the unit that is activated by the breaking of the wire to turn the unit OFF. Getting to this bracket is somewhat difficult and requires patience. Take a lot of pics to be able to reassemble the S 1637. I pulled the 41 inch long string under this signal bracket, evened off the ends, moved the top module down 2 inches and twisted the ends around the W shaped bracket that compresses the spring.
Honestly, I had to adjust the spring two times because I left off the cleaning bead. Now just reverse the steps and you got your unit working. The new string seems to push a lot more air.
Before you replace all of the screws, fold the unit together, insert the blades , put 2 sets of veggy rubber bands around the top and bottom and plug in/turn it on. Mine works now better than new. Did I mention that I had to do 2. The second was done in 2 hours.
Good luck.
totrosko@yahoo.com
Mar 28, 2011 | Sharper Image Ionic Breeze® Quadra® 4.0...
Unit will not go on.
Without actually seeing the unit I can tell you the power cord that you plug into the wall, the first thing that happens is the hot a/c wire (black) solders to a fuse at the bottom of the unit into a pc board. Then on the load side of the fuse a (red) wire travels up to the top of the unit and is series through 2 micro switches. The first switch is to monitor the collector grid that is the part you pull in on the lever at the handle to remove and clean about every 2 weeks. Then from that switch still at the top of the unit the (red) wire travels around to the back of the unit and that switch monitors the rear back cover to be in place. From there it goes back down to the bottom of the unit into the circuit control board. Enough said about the power lead. I am sorry if I am a little technical, but that is the only way I know how to help you. I have been an electrician/elect tech for over 37 years. Now with all that being mentioned remember I told you about the soldered in fuse, well its been my experience over the years that if the manufacturer wanted you to change that fuse easy it would not have been soldered. What I am saying is that if it is blown, it is well beyond the scope of the end user to repair. Some things to look for is back cover and grid collector seated properly. Then you could check switches for broken wiring or maybe a switch is misaligned. This requires some disassembly if your not sure of yourself there three levers you can choose from when attacking this unit A,B,&C. It is best to use lever b and do not attempt tearing it down if you do not trust your working on it. I hope this might help you this the best i can do without tearing into unit myself.
Dec 16, 2010 | Sharper Image SI830 Ionic Breeze Pro...
After cleaning my electronic filter, it runs well for about a day. Then, it begins to continuously arc until I wipe the wires clean. Again, no arc for awhile, then, continuous arcing. Is there something I...
It is normal to hear occasional snapping from your Electronic Air Cleaner. This occurs when larger particles are caught by the ionizer wires. Continuous snapping is not normal however, and should be investigated as outlined below: Please note that the metal electronic cells may have some sharp edges; use care when handling the cells. Wear gloves to protect your hands from being cut if needed. Remove both electronic cells. Make sure that there is no hair, dirt, sand or any debris on the bottom inside the Electronic air cleaner. If there is, remove what you can by hand. If a lot of debris is left in bottom of the Air Cleaner, you may want to use a vacuum attachment to see if you can vacuum up what you can. Do not vacuum the Pre-filter or Post filter this may damage it. Close the access door, and then turn on the Electronic Air Cleaner and the system fan. If the snapping continues with the cells removed, contact your heating and cooling contractor for service on the unit and turn off the Electronic Air Cleaner’s power. If snapping does not continue, make sure the electronic cells are clean, dry and properly installed. Inspect the electronic cells for bent collector plates, broken wires between the plates, dirt on the insulators, and damaged collector contact tabs located on the top of the cells. Make sure the pre-filters are in good condition and are in the cabinet slot farthest from the furnace (The order of the Electronic Air Cleaner Filters are from the return duct to the furnace is: Pre-Filter, electronic cell, and then Post filter, if your Electronic Air Cleaner has one). If the snapping persists and you are unable to locate any physical cause, please contact your heating and cooling contractor for service on the unit and turn off power to the Electronic Air Cleaner.
Jan 25, 2010 | Honeywell Enviracaire Elite F300E-1019 Air...
I have si 637 quadra. cleaning the unit both little thin plates at the end of filter fell off. the unit works. how important is repair this ?
If you're talking about those little plastic tabs at the bottom, they aren't important. Their job is to wipe the ionizing wires when you take the grid out or replace it.
Jan 15, 2010 | Sharper Image Ionic Breeze® Quadra® 4.0...
Ionic breeze quadra not functioning
I had the same problem and could not find an answer anywhere. So here's what I figured out. The small wires running from top to bottom just inside the cover are your problem. Not the metal grid with plates that you can remove. The buzzing sound you heard is the resistance one or more of the wires is causing. The resisitance tells the pc board that your grid must be wet and therefore the unit goes into drying mode. I replaced my small wires and my unit is working better than ever. The wire is .005 diameter( important so that you keep the same resistance flowing to the pc board) and can be purchased at any good suppy house. I have since repaired another unit with an even simplier fix. I took the unit into a dark room and then turned it on. Watching the grid I could see the wire arching that was causing the resistance. Unplugged the unit, turned it over and with a flat head screw driver pushed the wire off its base connedtion. Turned the unit right side up and removed the wire from its top support. The unit works fine without the troubled wire. Hope this helps.
Apr 04, 2009 | Sharper Image Ionic Breeze 3.0 Air...
How to reset air purifier
(from the manual) Turn off the unit. Look just below the last light on the "filter change indicater meter". You'll see a very small hole and the words "reset". Use a sharp object, such as the end of a paper clip (opened up) and stick the paper clip or sharp object into the hole. This is suppose to reset the unit. However, I have heard of cases when people of done what I just described but the indicator late still will not reside to green. I hope this helps you.
Apr 26, 2008 | GE HEPA 106653 Air Purifier
Sizzle
I had the same problem and found that the mylar on the tabs at the bottom of the plate assembly was damaged (torn). I was able to repair the part myself using mylar tape. This solved the sizzle problem. I
Nov 22, 2007 | Sharper Image Ionic Breeze 3.0 Air...
Problem
"A blinking light indicates when the blades should be wiped clean with a damp cloth." I actually had a "handyman" contract last year to visit an elderly gentleman once a month and clean all 9 of his Ionic Breeze GP air purifiers. Before I did that for him, they would make hissing noises and he really didn't like that. Here's how to clean the operative compnents of these machines: First, unplug the machine and place on a work surface, such as a table or kitchen counter. Second, remove the metal blade insert from the top by gripping the release tab and lifting it up and out. Also remove the front and back grilles by pressing on the plastic tab at the bottom and lifting up on them. Third, use a damp rag or paper towel to wipe the three metal blades clean. Do not immerse this assembly in water, because it has to be completely dry when re-installing it in the machine. Fourth, use a small piece of damp paper towel to VERY GENTLY wipe clean the two thin wires inside the unit. These are located behind the two rubbery flat blades just inside the unit and can be accessed from the front side. You won't damage these rubbery flat blades by pushing your hand gently between them, but be VERY CAREFUL when wiping the wires clean. (This step is important, as the wires must be clean.) Fifth, using another bit of damp paper towel, carefully clean the wire attached to the inside of the front grille. Dry this off with a dry bit of paper towel, then clean any accumulated dirt off the front & back grilles. Check the metal contact near the bottom of the front grille (attached to the wire) to verify that it's clean and will make good electrical contact. Sixth, pick the unit up and turn it upside-down & right-side up about 6 to 8 times. The two wires inside have plastic beads on them that slide up and down the wires. This brushes any bits of leftover dust or lint off of the wires. (Again, these wires must be VERY clean.) Seventh, replace the front and back plastic grilles by placing them in their slots and sliding them down to snap into place. Verify that the assembly with the three metal blades is COMPLETELY dry, using a hair dryer if necessary to dry off damp areas, then slide it back into place from the top of the machine. Now the cleaning process is done, so plug the unit in and turn it on to test operation. If it makes ANY noise, then some component is not completely cleaned off, or still has a presence of moisture, which must be completely dried off before the machine is ready for operation. Hope this helps! ;)
Aug 05, 2007 | Sharper Image Ionic Breeze SI719 Air...
Sharper Image Ionic Breeze 3.0 Air Purifier Logo
115 people viewed this question
Top Sharper Image Air Purifiers Experts
Daniel Dollive
Daniel Dollive
Mike Squire
Are you a Sharper Image Air Purifier Expert? Answer questions, earn points and help others
