Freeview box (Duraband)
Can recieve itv2+1 but can't get itv2.Plus my ordinary channels are not too great. I've changed the aerial twice now with no avail.
Thankyou Sandra
  • 28 Answers
To check the signal strength when tuning in any STB during the scan under "instalation menu" the will be a scale indecating the signal strenght its only a idecation so it should show over say 75% and if you can then receive channel 5 the aerial is OK
Posted on Jul 30, 2009
  • 4 Answers
Hi Sandra , it could be poor signal ,worth trying another box on your aerial , also the aerial lead could cause this even the one from the wall plate to the Freeview box ,if your analogue picture is snowy then I would suspect the aerial have you looked for a signal strength meter in the menu , might show how good the signal is
hope this helps
cheers John
Posted on Dec 24, 2007
Freeview probs
can you try a external antenna on it?
Jun 19, 2008 | Televison & Video
Connecting up CRT TV, VCR, DVDR and digital box
I think the better task is (A)
You can try switch scart's!! Then try to record on DVDR or leave as it is and look out for picture on your VCR!!! If you do (B) you will lose a picture quality!
good luck
Jan 31, 2008 | Televison & Video
Cannot find freeview/digital on our new TV
You can only get the freeview / digital channels through cable by subscribing to a package which includes them. They will then supply the necessary decoder to get the channels. Otherwise you will need a digital aerial and a freeview box if you tv is not dtv ready.
Jan 03, 2009 | Televison & Video
Do not understand how to set up my alba digi box to my television and recieve basic digital channels help!
Hi.
Ok
1) plug aerial in to the antena in sock on freeview box.
2) plug short aerial type lead in to rf out socket on freeview & antena in socket on TV.
3) plug A scart lead in to the socket marked TV on freeview box & the other end of scart in to one of the scart sockets on the TV.
If your TV has more than one socket plug it into the one marked AV1 or AV2.
4) plug in freeview to mains electricity & switch box on.
5) Turn TV on freeview should appear automatically if it doesnt look on your TV remote for A button marked AV or a button with either A circle or square with an arrow going through it you may need to press this several times until you see digi picture come up.
Thats basically it but do check that you dont need a new aerial etc to be able to get digi signal in your area.
http://dysonmanuals.llc.nu/
Jul 26, 2008 | Televison & Video
Similar problem as you helped me solve before.
OK, I think I see the problem there.
The aerial lead from the DVDR to TV should be removed.
You should have it setup the same as the other Freeview - VCR - TV
Nutshell time:
Main aerial to Freeview input.
Loop aerial from freeview output to DVDR areial input (all this does is allow you to watch freeview, or standard both out of the DVDR)
So..
Scart from Freeview to DVDR input
Scart from DVDR output to TV
Set DVDR to AV input mode.
Set TV to AV (whatever number you need for that..you now won't get anything on screen unless you have the right input selected)
If you can now see the Freeview picture on the TV and change the channels with the Freeview remote then you should be set for recording.
Having the aerial and a scart lead both going to the TV is not needed.
Apr 14, 2008 | Philips VR550 VHS VCR
Philips DTR220/05 digital freeview reciever not recieving anymore
If the box is still receiving some channels, then the box is probably not at fault.
If you have done the full "First time Installation" rather than search for new channels, then eithe the aerial, connection or signal is likely to be to blame.
There have been several changes with the Freeview service over the last few months, and there will be more in the run up to analogue switch off.
In some cases, channels have moved, and in other cases the service has been switched off for a short period, low power etc.
Check the aerial on a standard analogue signal, if the quality is poor, then this rules out the box.
Feb 23, 2008 | Televison & Video
RECORDING PROBLEM
Connectivity problem. Without knowing your models and their available channels etc., it's very difficult to advise you exactly.
Broadly though ...... you need to get the input signal routing sorted.
Plug your aerial into the Freeview box. Make a connection from its RF out, (beside the aerial 'in' socket) to the aerial 'in' socket on the JVC. Run yet another co-axial connection from the JVC RF 'out' to the television.
Now - connect a scart lead between the JVC and the TV. Power off the freeview. Switch your TV to accept A/V - to show the JVC on screen. Read/go through the 'Set up' procedure on the JVC to scan in the available broadcast channels. When done - connect using a scart between the Freeview box and the JVC. This will be located on either the L1 or L2 channel selection.
IF as it seems you are using the freeview to watch all your programmes - and record in then you are simply watching and recording 'live' change the Freeview programme and the JVC gets that same one arriving in (and sending to the TV)
Unless you need to record Freeview only output - always record from the aerial input. You select via the television remote (and 'TV' selected) and the appropriate channel.
Complex to explain - hope it helps. The one thing to remember - is to make one set of changes at a time - check the result is okay, before moving to the next.
Jan 07, 2008 | JVC DRMH20 DVD Recorder
Can't tune stations from freeview box to DVDR3380/5
You can only record freeview channels through your box.
Assuming the digi-box has two scart sockets, connect as follows:
  • Scart 1 or TV scart of the digi-box to the TV.
  • Scart 2 or VCR/DVD scart of the digi-box to scart 1 of the DVDR3380.
The TV aerial should already be connected through the digi-box and DVDR3380 to the TV
To record from the digi-box, select AV1 / E1 / EXT1 on the DVDR3380
If you are doing timer recordings, you will also need to leave the freeview box on the channel you wish to record, or set the freeview box timer.
Dec 15, 2007 | Philips DVDR3380/05 DVD Recorder
Televison & Video Logo
119 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
