Question about Philips 27PT5445 27" TV
I have problems with this 27pt5445/37 philips tv when I turn on the screen with vertical problems and within seconds it turns off and replace some capacitors and no improvement
  • Philips Master
  • 1,212 Answers
Did you replace cap 2465, 100volt 10Mf to cure the vertical problem? and You may still have a bad cap at location 2415, 160 or 200volt 2.2 at 85 degrees. Check this out! When the tv tries to come on does it make a very good effort with the picture tube cracklin on and then shuts down? If this is true you may need a mosfet, located at 7404. Part# 934054713215. Good Luck! This is a smd!
Posted on Apr 07, 2010
Philips Tv always returns to menu screen
ssb board failing need to be replaced encompass.com
Sep 17, 2009 | Insignia 42" LCD Flat-Panel HDTV
Problems with on/off button
Your Problem is the Hot transistor, it is short circuit. Causing the tv to go into protection. I f you say this is the second time the same problem tell the technician who works on the tv to replace all the caps on the collector of the Transistor and check the lopt transformer causing the HOT transisistor to fail thank you
May 16, 2009 | Philips 20PT91S 20" TV
Tv Switchs off automatically
Hello SpyTan,
You have a vertical deflection problem. This is either caused by the vertical yoke transformer going bad or the vertical coupling capacitor going bad. It may even be one of the components in the biasing circuit that delivers the vertical deflection signal. In any event this may be causing excessive current which then causes the shutdown circuit to activate. I would have a qualified TV technician check the vertical defelection section of the TV.
I hope This helps,
Thank you,
Shuttle83
Oct 04, 2008 | Televison & Video
Philips 50P8341 green light
I believe its the vertical output IC. Diodes would tend to blow fuses . I would replace the vertical output and see if that takes care of the problem.
Aug 20, 2008 | Philips 50P8341 50" Rear Projection...
TV FIX
A line across the screen means a loss of vertical sweep. This could be as simple as an IC or as difficult as a deflection yoke. These are not do it yourself repairs.
Nov 30, 2007 | Philips Magnavox TP3285C 32" TV
Tv turns off
is the timer set. or does it have an automatic shut off. I would check your settings.
Oct 23, 2007 | Televison & Video
Horizontal Lines Moving Through Screen
your tv has a carry in only warranty. i would ask philips for the closest authorized servicer. i find i hard to believe there wouldnt be an authorized servicer within a few hours away.
Sep 26, 2007 | Philips 23PF5320 23 in. HD-Ready LCD...
RCA F36674ET - Only beeps when turned on
Clearly shows problem in deflection area both horizontal and vertical section. Horizontal lines is due to vertical section problem and making bbzzzz is due to horizontal output transistor short and sometimes LOT SHORT.
Aug 23, 2007 | RCA F36668 36" TV
Sony KV-35S42 35" TV
Check first for bad solder on the vertical IC, Im not sure for your set as I do not have the service manual, but it may be location IC301. If after resoldering it does not fix it you may have to replace it and you should replace the electrolytic capacitors in the vertical section. Hope this helps. Don
Jul 31, 2007 | Sony KV-35S42 35" TV
Picture problem
Usually that symptom is caused by cracked solder joints on the vertical output IC. As the IC starts heating up, the picture starts breaking up at the top with several "dancing" dark lines appearing, the top scrunches down and then when the vertical quits altogether, the screen goes completely black. A good slap on the side of the TV might make it happen faster or clear it up temporarily. If you have experience working on PC boards then you can resolder the pins of the vertical output IC but if you have never soldered parts on PC boards then allow a qualified tech to handle it for you.
Nov 20, 2006 | Sony KV-35S42 35" TV
Philips 27PT5445 27" TV Logo
284 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
